4 Profile Management
The goal of the Profile Management component of Configuration Manager
is to define Store Personalities for your organization. The Store
Personalities allow you to easily maintain portions of your configuration
paths using a GUI format in Oracle Retail Xstore Office. Behind the
scenes, these Store Personalities are translated into the various
configuration paths specified in configPath.properties. For more information on Personality Maintenance and configuration
paths, seeAppendix: Personality Maintenance and Config Paths
The Configurator component of Configuration Manager is used to create, maintain, and deploy Oracle Retail Xstore Point-of-Service configuration changes selectively, or globally across the entire organization. Refer to Configurator for more information about making configuration changes and deploying the information to your stores.
