12 Customer Order Management
This chapter is divided into the following sections:
Customer Orders Mobile Quick Flow
The Customer Order quick flow is a simplified continuous flow for web order type customer orders.
Customer Orders that are executed in the Quick Flow on the mobile are designated as “quick flow”. They can be viewed in the full flow customer order dialog.
The differentiation between a full flow customer order and a quick flow customer order is defined by the “Customer Order Flow Default” store option that is set at the time a web customer order arrives in the system. POS orders are always considered full flow orders.
  • Accept a customer order
  • Reject a customer order
  • Pick a customer order
  • Ship or Pickup a customer order
  • Accept a reverse pick
  • View customer information
  • Print a customer order
  • Enter values for CFAs (Custom Flexible Attributes)
Figure 12-1 Customer Order Quick Flow Screen Flow
Customer Order Quickflow starts by accessing the web order type customer order in open transactions. A customer order can be accepted, if successful will move the customer order to the Customer Order Pick process. In customer order pick the user can pick the order. A physical holding location may be required to put the items for later pickup. Once picking has been complete the user will move to the shipment/pickup/curbside pickup process dependent on the type of delivery. If a reverse pick exists for the customer order, it will need to be acknowledged to continue the process. At any point the customer order can be rejected which will cancel any quantities which have not yet been picked. Note: Customer Order Quick Flow can also be accessed from Recently Edited and navigating to a transaction from Notifications.
Customer Order
Figure 12-2 Customer Order Items Screen
The Customer Order screen is accessed by selecting a customer order that is a web order in ‘New’ status from Open Transactions. If the customer order was previously accepted and it was unsuccessful in progressing forward to the picking stage, then ‘Picking Required’ will also be available. User must have Access Customer Order Quick Flow permission to access this flow and Edit Customer Order Quick Flow to make any updates.
The screen contains header information for the store order ID, delivery type, release date, and status. It lists the items with item ID, description, image (per preferences) location and order quantities for the customer order.
Selecting an item will navigate to the Item Detail screen. Scanning an item will navigate to the Item Detail screen if the user preference “Scan Navigate” is set to ‘Yes’.
Footer Menu
Close: will close the screen and no changes are made.
Pick: Pick will be available for ‘Picking Required’ status customer orders. If successful, the Pick option will generate a pick for the customer order and navigate the user to the Customer Order Pick Items screen for the new pick. All picking rules apply.
Accept: Accept will only be for customer orders of status 'New'.
  • It will validate the Customer Order Fulfillment Restriction system admin setting
  • It will try to create the pick, all picking rules will apply.
    • If successful, the customer order will be updated to ‘Pick in Progress’ and navigate to the Customer Order Pick Screen.
    • If unsuccessful the customer order will be in ‘Picking Required’ status.
    • It is assumed that picking is required in the Customer Order Quick Flow.
  • Notes: The Notes option accesses the notes common dialog to capture notes. Notes will always be available for viewing and user can create notes regardless of the status of the customer order, provided the user has Create Notes permission.
  • Print: Print will display the common print dialog to print the customer order report. Information: Information will access the Customer Order Information popup.
  • Info: Information will access the Customer Order Information popup.
  • Holding Location: will prompt the user with the Holding Location popup.
  • Reject: All item quantities will be canceled/rejected. A system generated reverse pick will be created for the rejected items. Order will be set to ‘canceled’ status.
Item Detail (Customer Orders)
Figure 12-3 Item Detail Screen
Item Detail Screen
The Item Detail screen is accessed by selecting or scanning an item (user preferences is set to Scan Navigate) that is on the customer order on the Customer Order Items screen.
Scanning or entering an item on this screen will refresh the item detail screen for the item on the customer order. The user can page through the items on the customer order. This screen is view only.
The scan details at the top displays the details of the last scanned barcode.
The item information includes:
  • Item ID and description
  • Item Image (per user preference)
  • Order Line - if the order contains duplicate line numbers
  • Location - the location for the item
    • Only displayed if “Display Sequence Fields” is set to ‘Yes’
    • If the item has stock in the backroom, then the first backroom location will be displayed if there is one, otherwise it will display “backroom”.
    • If the item has stock in the shopfloor, then the first shopfloor location will be displayed if there is one, otherwise it will display “shopfloor”.
    • If items have no stock in the backroom or the shopfloor, the first backroom location will be displayed, otherwise the first shopfloor location, and if that doesn’t exit it will display “No Location”.
  • Order Quantity
  • Pack Size
  • Remaining
  • Picked
  • Delivered
  • Canceled
  • Last Update
  • Comments
Information (Customer Orders)
See Customer Orders Mobile Full Flow – Information (Customer Orders).
Customer Order Pick
Figure 12-4 Customer Order Pick Screen
The Customer Order Pick Screen is the next step in the process after the Customer Order screen. It is accessed by successfully creating a pick by selecting the Accept or Pick options for the Customer Order. The Customer Order Pick screen is for customer orders that are in ‘Pick in Progress’ status as well as for customer orders that are in ‘Ready to Ship’ and ‘Ready to Pickup’ status where the delivery record has not been generated yet. Customer Order Picks are accessed automatically within the process flow or from Open Transactions. User must have ‘Access Customer Order Quick Flow’ user permissions.
The header will contain the Store Customer Order ID, Delivery Type, Release Date and Order Status. The Holding Location can be entered via the link on the top or also from within the overflow menu.
The list will have the items on the customer order with item, description, and image (per preferences).
If Display Sequence Fields equals Yes, the macro location and area for the item will be displayed. If it set to No, this field is not displayed. Note: screenshot above is not showing this.
If there is stock on hand in the backroom:
  • It will display the first available backroom location.
  • If no backroom location, it will display Backroom.
If there is no stock in the backroom and stock exists in the shopfloor:
  • It will display the first available shopfloor location.
  • If there is no shopfloor location, it will display Shopfloor.
If there is no stock on hand in the backroom or the shopfloor:
  • It will display the first backroom location.
  • If no backroom location, the first shopfloor location is displayed.
  • If no shopfloor location, it displays no location.
Items will be ordered by macro locations that have stock on hand with backroom locations first, followed by shopfloor and no location.
If the quantity needed for the item is the suggested pick quantity generated by the system. When the needed quantity has been satisfied a check mark will be displayed. The user can enter in the quantity to pick (Edit Quantity Customer Order Quick Flow permission) or use the scan bar to scan in the quantity.
Footer Menu
Notes: The Notes option accesses the notes common dialog to capture notes. The note will be saved on the customer order and not the pick.
Print: Print will display the common print dialog to print the customer order pick report.
Info: Info will access the Info popup.
Holding Location: will open the Holding Location popup
Reverse Pick: will navigate to the Reverse Pick. Only available if customer order is in ‘Reverse Pick’ status.
Cancel: Exits to the quick flow and no changes will be saved. Save and Exit: Saves the pick as ‘In Progress’ status and exists the quick flow.
Complete Pick: Completes the pick and moves the pick to Completed status. If there are any unpicked quantities, the user will be prompted to reject them. Only one pick can be created per customer order in the quick flow process.
  • If the delivery type is a ‘Customer Pickup’ the system will navigate to Open Transactions and the order will be ‘Ready for Pickup’. If holding location is required per store configuration and the user has not captured it, the system will prompt for this first.
  • If the delivery type is ‘Ship to Customer’
    • System will validate store parameter, ‘Navigate to Shipment’.
    • If it is set to ‘Yes’, the system will navigate directly to the Shipment screen and the order will be in ‘Delivery in Progress’
    • If it is set to ‘No’ the system will navigate to the Open Transactions screen and the customer order will be in ‘Ready for Shipment’ status.
Create Shipment / Pickup: This option will be available for customer orders that are in ‘Ready for Pickup’ or ‘Ready for Shipment’ and it will generate the pickup / shipment and navigate to the corresponding screen.
Quantity Validation
Upon confirm, the system will check the system admin, Customer Order Fulfillment Restriction:
  • If it is set to Restricted, the entire customer order must be picked in its entirety.
  • If it is set to Line controlled, any item that is getting picked must be picked in its entirety.
  • If it is set to Transaction Controlled, no restrictions as above.
Tolerances
When the item has a variable unit of measure, i.e. Lbs, pounds, it can be difficult to pick the exact amount suggested. For example: picking 2 Lbs of bananas might end up truly being 2.2. The quantity picked may exceed the needed if the defined tolerances are setup to allow for such.
Holding Location
See Customer Orders Mobile Full Flow – Customer Order Picking – Holding Location.
Confirm Item
Figure 12-5 Confirm Item
Confirm Item
If the pick quantity is manually entered, rather than scanned, the system will require the user to enter/scan the item to confirm the proper item is being picked. This is not necessary when scanning in the item quantity.
Information (Picking)
See Customer Orders Mobile Full Flow – Customer Order Picking – Information (Picking).
Shipment/Pickup/Curbside
Figure 12-6 Shipment Screen
Shipmen Screen
Figure 12-7 Curbside Pickup Screen
Figure 12-8 Pickup Screen
Pickup Screen
The functionality of these screens is the same. The Shipment screen is for delivery types of ‘Shipment’ it will be accessed from Open Transactions, or if the store configuration, ‘Navigate to Shipment’ is set to ‘Yes’, the system will automatically continue on to this screen after completing the pick. The status of the customer order will be ‘Delivery in Progress’. The Pickup and Curbside Pickup screens will be accessed from Open Transactions. The status of the customer order will be ‘Delivery in Progress’.
Curbside Pickup will contain information in the header about the pickup. It will include the customer’s current wait time and any other information that came in on the curbside pickup notification.
The Holding Location (if it exists) will display in the header. A Default Quantities option will default in the delivery quantities on the delivery to what is remaining to be delivered. A Clear Quantities option is available to clear out the quantities and set them to blank. The items are listed in descending order by item ID. The list will have the items on the customer order with item, description, and image (per preferences).
A UIN icon will be displayed for items that are UIN items when the store is configured to use UINS.
The user can enter in the delivery quantity (Edit Quantity Customer Order Quick Flow permission). Quantity must be less than the Needed quantity, which is the remaining order quantity. Or, if more was picked than what was needed due to tolerances, the delivery quantity must be less than or equal to the picked quantity. If the item is a UIN item, then the quantity field will be disabled and selecting the quantity will navigate to the UIN screen to capture UINs. The quantity will be updated per the captured UINS.
If any item in the customer order has Customer Order Ship Alone indicator set to Yes, then the system will not allow the user to deliver this item along with other items. Those items will need to be shipped alone. This indicator is communicated to SIOCS by the OMS system.
Footer Menu
Notes: The Notes option accesses the notes common dialog to capture notes. The note will be saved on the customer order.
Print: Print will display the common print dialog to print the customer order delivery report.
Holding Location: will access the Holding Location screen.
Bill of Lading: will access the Bill of Lading screen.
Customer: will access the Customer screen.
Cancel Submit: Sets a 'Submitted' status delivery back to 'In Progress'. The user must have Cancel submit permission. Additionally, if the system is configured to use Fiscal Doc ID/E-way Bill ID, this option will be enabled only if one of the following conditions is met.
  • Fiscal Doc ID = Null and Fiscal Request Status = 'Rejected'
  • Fiscal Doc ID != Null and Fiscal Request Status = 'Approved'
Submit: Submit will submit the delivery and set it to Submitted status and not allow for editing. Submit is only available when store configured for Dispatch Validate to Ship Submit and when the customer order delivery is in ‘In progress’ status.
  • The only step possible will be to cancel Submit or Pickup/Dispatch.
  • When the system is configured for Ship Direct, submitting is not possible. Reverse Pick: will navigate to Reverse Pick. Only available if customer order is in ‘Reverse Pick’ status.
Reject: All unpicked item quantities will be canceled/rejected. A system generated reverse pick will be created for the rejected items. Cancel: Exits to the screen and no changes will be saved.
Save: Saves the delivery as In Progress status and return to the Open Transactions screen.
Pickup/Dispatch:
  • If Allow Partial Indicator is set to No, it will validate that the entire order is being delivered together. Those users with certain privileges will be able to override this.
  • If Allow Partial Indicator is set to Yes, the customer order can be delivered partially.
    • If system parameter 'Customer Order Fulfillment Restriction' is set to 'Line Controlled', the item has to be delivered fully. Partial delivery of an item is not allowed.
  • Upon dispatch of the delivery the delivery will move to Completed status, and user returns to the Open Transactions.
  • The stock on hand and customer order reserved quantities will be decremented by the delivered quantities.
  • The customer order fulfillment order will have the delivered and remaining quantity updated.
  • If the entire customer order has been fulfilled, meaning there is no remaining quantity, the customer order will be set to Completed status.
  • Multiple deliveries can be created in the customer order quick flow process, but each delivery needs to be closed before another can be started.
Customer
Figure 12-9 Customer Popup
Customer Popup
The Customer screen has read-only information about the customer on the customer order. It is accessed through the Customer menu option in the overflow menu. User must have Access Customer Details permission. Customer information is not held in SIOCS, and it is accessed via a web-service to an external system.
Information (Shipment/Pickup/Curbside)
See Customer Orders Mobile Full Flow – Customer Order Deliveries – Information (Shipment/Pickup/Curbside) .
Bill of Lading
See See Customer Orders Mobile Full Flow – Customer Order Deliveries – Bill of Lading.
Reverse Pick
Figure 12-10 Reverse Pick Items Screen
The Reverse Pick Items screen is accessed from Customer Order Pick and Shipment/Pickup/Curbside. Reverse picking is the action of indicating to the OMS that a previous pick is now being unpicked and inventory is moved back to the shopfloor. It also can indicate a confirmation of the cancel request from the OMS. It will be available when the customer order is in Reverse Pick status, and a system generated reverse pick exists.
Items will be listed with ID, description, image (if set in preferences), primary location (if Display Sequence Fields = ‘Yes’), and the reverse pick/canceled quantity.
Items will be listed that have been picked and that have a remaining order quantity (meaning they have not been shipped/picked up or canceled). They will be sorted by item description.
The user will be able to select ‘cancel’ to leave without changes. Or, ‘Reverse Pick’ which will move the reverse pick to ‘completed’ status. Customer order picked and reserved quantities are decremented and canceled quantity is incremented.
The Customer Order full flow is used to execute web order type customer orders that are designated as “Full Flow”. “Quick Flow” customer orders can be searched for and displayed in the list of orders, but accessing a quick order will bring the user to the quick order flow.
‘Web Orders’ as well as POS Orders, On Hold, and Layaway can be viewed in this dialog.
Features include:
  • Search for customer orders
  • View an existing customer order
  • Pick a customer order by a specific customer order
  • Access Shipment or Pickups dialog for a customer order
  • Access Reverse Pick dialog for a customer order
Figure 12-11 Customer Order Full Flow Screen Flow
Customer Orders can be viewed, accepted, and rejected. The information and customer details can also be viewed as well as CFAs can be defined. Single order picks can be created from within a customer order. Deliveries and Reverse Picks can be accessed from within the customer order.
Customer Orders
Figure 12-12 Customer Orders Screen
The Customer Orders screen is accessed by selecting the Customer Order menu option from within the Customer Order Management menu in the drawer/menu. It can also be accessed by selecting Customer Orders within the Quick Actions menu. The user must have permissions.
The screen will display the Active status customer orders by default which is all customer orders which are in New, In Progress, Picking Required, Pick In Progress, Reverse Pick, Ready to Ship, Ready for Pickup, Delivery In Progress, Under Review. It also displays orders that are “full flow” and “quick flow”.
The user can click the magnifying glass to direct to the Search Criteria (Customer Orders) screen. Selecting a customer order will navigate to the details for the customer order. If it is a “full flow” order it will navigate into the details for the order in the full flow dialog. If it is a “quick flow” order, it will navigate into the details in the quick flow dialog.
Important Fields include:
  • Release Date – the date the order needs to be ready to leave the store.
  • Store Customer Order ID
  • Delivery Type – ‘Ship to Customer’, ‘Customer Pickup’, ‘Layaway’, ‘On Hold’ and ‘POS Order’.
  • Status – ‘New’, ‘In Progress’, ‘Picking Required’, ‘Pick In Progress’, ‘Reverse Pick’, ‘Ready to Ship’, ‘Delivery In Progress’, ‘Ready for Pickup’, ‘Under Review’, ‘Completed’, and ‘Canceled’. See section Customer Order Status Flow.
  • Number of SKUS
Figure 12-13 Search Criteria Screen (Customer Orders)
The Customer Order Search Criteria screen is accessed by the magnifying glass on the Customer Orders screen. After applying the search criteria, the results will be listed on the Customer Orders screen and the criteria applied will show.
  • Date Range
  • From/To Release Date
  • Customer Order ID
  • Fulfillment Order ID
  • Bin ID
  • Item
  • Status
  • Reservation Type
  • Delivery Type
  • Tracking ID
  • Search Limit
Figure 12-14 Customer Order Items Screen
The Customer Order Items screen is accessed by selecting a customer order from the Customer Orders screen. It is also accessed from Open Transactions, Recently Edited, and from Notifications. A user must have proper permission.
The filter can be used to narrow down the list of items. Filtering can occur by item ID, item description, or UOM. The list can be sorted.
The Holding Location can be defined by selecting the Set Holding Location link. It is also available in the footer menu. Holding Location is not required at this point in the process. See section Holding Location.
Header Fields include:
  • Store CO ID
  • Delivery type for Release Date
  • Status – of customer order
  • Number of items
Item Fields include:
  • Item ID
  • Item Description
  • Item Image – per user preference
  • Order Line – if duplicate line items exist
  • Pick Quantity
  • Pack Size
  • Ordered Quantity
  • Remaining Quantity
  • Substitute Items - If an item has substitute items there will be an expander icon that when selected the substitutes will be displayed.
Selecting a line item will navigate to the item details of that item. Scanning or entering an item in the scan bar will either keep the user on this screen or navigate to the Item Detail (Customer Orders) screen for that item dependent on the Scan Navigate user preference. Items are not added, and quantities are not updated in Customer Orders.
Accept, Pick, or Pickups/Shipments will be the action buttons in the footer bar dependent on the status that the customer order resides in.
The ellipsis in the lower right hand corner will access the Footer menu which will contain all of the functions that can be performed on a customer order.
If the order has duplicate items, meaning an item exists on the customer order more than once, the items will appear multiple times in the list with the corresponding line numbers listed as well. This applies to all screens that display the item within customer orders, customer order picking, customer order deliveries, and customer order reverse picking.
The footer menu is accessed from the ellipsis footer menu on the Customer Order Items screen. The menu functions will include the following.
Notes: will access the notes common dialog to capture notes. Notes will always be available for viewing and user can create notes regardless of the status of the customer order, provided the user has Create Notes permission.
Print: will display the common print dialog to print the customer order report.
Info: will access the Information popup.
Back: will return to the Customer Orders screen, no changes made to status.
Customer: will display the customer information popup for the customer order, view only. The user must have proper permission. This uses a web service call to access the customer information.
Holding Location: will access the Holding Location popup.
Pick: will be available for ‘Web Orders’ that are still in an open state. The user must have Create Customer Order Pick permission. Selecting the pick option will generate a pick for the customer order and navigate the user to the Customer Order Pick Items screen for the new pick. If picking by Area is configured for the store, the user will navigate to the Create Pick popup to select an Area first. All picking rules apply. See section Customer Order Picking.
Reverse Pick: will be available for all status of ‘Web Orders’. The user must have the Access Customer Order Reverse Pick permission. The user will navigate to the Reverse Picks screen for the current customer order.
Shipments/Pickups: will be available for all status of customer orders (web orders, customer pickup, layaway, POS order, On Hold). The name of the button, shipments or pickups, is determined by the delivery type. This option navigates to the Delivery dialog for the current customer order. The user must have Access Customer Order Delivery permission. See section Customer Order Deliveries.
Accept: will only be available for ‘web order types’ of customer orders of status 'New' or 'New but in Under Review mode' . The status of the customer order will update as follows: if the store is configured for picking to be required, the status will be set to ‘Picking Required’. If it is not configured for picking required, the status will be updated to ‘In Progress’.
Reject: will be available for web order types of customer orders that are in an open state. The user must have the Reject Customer Orders permission. All item quantities that have not yet been picked will be canceled/ rejected. A system generated reverse pick will be created for the rejected items. For more information, see section Customer Order Reverse Picks.
Figure 12-15 Item Detail Screen
Item Detail Screen
The scan details at the top display the details of the last scanned barcode. The arrows at the top allow the user to page to the next and previous items.
Fields include:
  • Location – the location for the item
    • Tapping on the location will navigate to the Locations popup.
  • Substitute For – will only be displayed if the item was added as a substitute for another item. This will show the original item that it was substituted for. Tapping on this field will navigate to the item details for that item.
  • Ordered Quantity
  • Pack Size
  • Remaining
  • Picked
  • Delivered
  • Canceled
  • Last Update
  • Comments
  • <X> Substitutes - <X> is the number of substitutes for the item.
    • Selecting this expander icon will display the substitute items for this item.
    • Tapping on a substitute item will navigate to the details of that item.
Figure 12-16 Information (Customer Orders)
The Information screen contains information about the header level of the customer order. It is accessed through the Information menu option in the Footer menu on the Customer Order Items screen. Details include:
  • Customer Order ID
  • Status
  • CFAs (Flexible Attributes). The user can capture CFAs on this screen. Security permission is needed for entering CFA values.
  • Reservation Type – web order, layaway, POS order, on hold
  • Delivery Type – ship to customer, customer pickup, layaway, POS order, on hold.
  • Carrier
  • Service
  • Allow Partial Delivery
  • Create/Release/Delivery Dates
  • Comments
Customer
Figure 12-17 Customer Popup
Customer Popup
The Customer screen has read-only information about the customer on the customer order. It is accessed through the Customer menu option in the overflow menu. The user must have Access Customer Details permission. Customer information is not held in SIOCS, and it is accessed via a web-service to an external system.
The Picking process is a formal process of the system telling the user what items need to be picked and the user going out, physically picking the items, and setting them aside. Once the items are set aside, they will then be used during the fulfillment process for shipping to, or pick up by the customer.
Features:
  • Search for customer order pick
  • View/edit an existing customer order pick
  • Delete a customer order pick
  • Create a customer order pick
Figure 12-18 Customer Order Picking Screen Flow
The user will access the Customer Order Picking dialog from the Customer Order Management menu in the drawer. The Pick List screen will display the list of Active picks. The user can go to the Search Criteria screen to search for picks using alternate criteria.
From the Customer Order Picks screen, the user can select a pick to go to the Pick Items (detail of pick) for viewing or editing purposes.
Also from the Customer Order Picks screen, the user can Create a pick. The pick may be created by bin or customer order. When creating by customer order, the user will need to specify which order is being picked and, once that is done, the system will generate a pick and navigate to the details of that Pick on the Pick Items screen. When creating by bin if the system is configured to automatically generate the bins, the user will go to the details of the Pick (Pick Items). Otherwise, if manual bin capture, the user must first capture the bins before going to the Pick Details.
Once in a pick, the user can pick items, add substitutes, print, add notes, view info, modify bins, save, or complete the pick.
Figure 12-19 Customer Order Picks Screen
The Customer Order Picks screen is accessed by selecting the Customer Order Picking menu option from within the Customer Order Management menu in the drawer/menu as well as in the Quick Actions menu. The user must have ‘Access Customer Order Picks’ permission. The screen will display the Active status customer orders picks by default which is all picks which are in ‘New’ or ‘In Progress’ status. The user can click the magnifying glass to go to the Search Criteria screen. Create will display the Create Pick popup. There is also a sort to sort the results.
Picks that have customer orders that are “Full flow” and “Quick flow” will appear in the list and can be searched. Selecting a pick that has “Full flow” will navigate to the Pick Items screen in the customer order full flow dialog. Selecting a pick that has customer orders that are “Quick flow” will navigate into the quick flow customer order dialog for that order.
Fields on this screen include:
  • Date - Date that the pick was last updated.
  • User - User that created the pick.
  • Pick ID - System-generated Pick ID.
  • Type - Either Bin or Store Customer Order.
  • Status - Status of the customer order pick.
  • Suggested Pick Quantity - Total quantity suggested to be picked across all line items.
Search Criteria (Pick List)
Figure 12-20 Search Criteria Screen (Pick List)
The Search Criteria for Customer Order Picking is accessed by the magnifying glass on the Customer Order Picks screen. After applying the search criteria, the results will be listed on the Customer Order Picks screen and the criteria applied will show.
Search criteria includes:
  • Date Range
  • From/To Date
  • Status
  • Pick ID
  • Customer Order ID
  • Bin ID
  • Area – only displayed when the store is configured for Allow Picking by Area is set to ‘Yes‘ and the system config for Customer Order Fulfillment Restriction is set to ’Transation Controlled‘
  • Item
  • User
  • Search Limit
Create Pick
Figure 12-21 Create Pick Popup within Picking
The Create Pick popup is accessed by selecting the Create button from the Customer Order Picks screen.
The create pick allows for the creation of a customer order pick by either Store Customer Order ID or by bin. The type will default per the store setting Default Customer Order Picking Method.
When selecting Store Customer Order, the user must enter in the Store customer order ID to be picked or use the search function to select one from the list. There is an Auto Select button that can be used in which the system will select the “best” customer order to pick based upon status, dates, etc. It is the same logic that is used as when picking by bin for a single bin. When creating a pick by Store Customer Order ID, there will only be one Customer Order Fulfillment Order per pick transaction.
When creating a pick by bin, the user will define the number of bins to be put on the pick. Initially, the bin quantity will be defaulted based upon the store admin setting Default Number of Bins. The user has the potential to override this quantity if the store admin setting Override Bin Quantity is set to 'Yes'. Picks created by Bin allow for multiple customer orders to be put on the pick; one store customer order per bin. It will first look to all store customer orders that are the oldest based upon release date.
A user can also do a create pick from within the customer orders dialog by selecting Pick from the footer menu. In this case the user goes directly into the pick, unless Area is configured, then the user will be prompted to capture the Area first. All other rules for creating the pick will be the same as those above for picking by store customer order ID.
In both picking types, by Store Customer Order ID and by bin, a pick can be created by Area. Picking by Area allows a user to create a pick for a customer order that is for a specific Area of the store. This is only possible if the store configuration Allow Picking by Area is set to 'Yes' and the system admin of Customer Order Fulfillment Restriction is set to 'Transaction Controlled' (meaning that the entire customer order does not have to be picked in one pick). Areas are set up in the desktop application in the Area dialog. If Area is an option, the system will give a list of 'Completed' status Areas, with one of the options being None for no area.
Customer Orders that will be available for picking will follow these rules:
  • Customer order must be a web order type.
  • Customer order must still be open.
  • There cannot be an existing open pick for the customer order.
    • If Area is being used, open picks are allowed for the customer order, as long as it is not for the same area.
  • Customer order must have at least one item on the order with items remaining to be picked.
  • If the system admin Customer Order Fulfillment Restriction equals ‘Transaction Controlled’, the system will also need to check that there is stock available to be picked for at least one item.
    • If the pick is by Area of None, all items from the customer order will be put on the pick.
    • If the pick is for a specific area, the system will put the items from the customer order which are in the selected area.
  • If Customer Order Fulfillment Restriction equals ‘Restricted’, there must be enough available stock for all items on the pick to be fully picked in their entirety.
  • If Customer Order Fulfillment Restriction equals 'Line Controlled, the user will not be able to create the pick if there is not enough available stock to pick at least one item fully.
  • Items that allow for substitutes will have their stock ignored. This is because they can have items substituted for them.
Upon selecting Create, for picks created by customer order, the user will navigate to the Pick Items screen for the generated pick. For picks created by bin, if the system is configured for manually capturing bins, it would go to the bins screen first to capture the bins. For system generated bins, the system navigates to the Pick Items screen and the bins would be system generated.
If any of the items that are to be generated on the pick are on an open “Investigate” item basket, they will not get added to the pick.
Figure 12-22 Bins Screen
Bins Screen
The Bins screen applies to those picks which are created by bin. Picks by bin will have bins manually or system generated per the store admin setting. For manually-captured bins, the user will be directed to the Bin List screen immediately upon creating the pick prior to going to the Pick Items screen.
Bins can be added by typing them in or scanning a barcode. Bins must be unique across all open picks. Bins are only editable for manually-captured bins. System and manually captured bins can be viewed from the Bin option within the footer menu of the Pick Items screen. The bins can be printed by selecting the Print button.
Figure 12-23 Pick Items Screen
Pick Items Screen
The Pick Items screen is accessed by selecting an existing pick from the Customer Order Picks screen, or by creating a new pick. It can also be accessed from Open Transactions, Recently Edited and Notifications. Proper permissions are required.
The Filter allows the user to narrow down the list of items by: Item ID, Item description, bin, and UOM. Sorting is also available. When selecting location as a sort option: the items are listed in order with those items with stock on hand in the backroom being displayed first, followed by items with shopfloor stock on hand, and lastly those that do not have stock on hand in either the backroom or the shopfloor. All items are ordered by macro sequence location.
The Pick Items screen displays all of the items on the pick. If an item has substitutes there will be an expander icon that can be selected that will display the substitutes below the original item.
Header fields include:
  • Pick ID
  • Store CO ID (if the pick was created by customer order ID)
  • Status
  • Number of Items
  • Holding Location – displays the holding location of the picked items, if one is assigned, and can be selected to add/edit the holding location.
Item fields include:
  • Item ID
  • Item Description
  • Item Image (per user preferences)
  • Pack Size
  • Bin – if the pick was created by bin
  • Pick Quantity – the quantity picked by the user
  • Needed Quantity – the quantity suggested to be picked by the system
  • … (overflow menu) – Add and Remove from Item Basket. Allows user to add and remove the item to an open ‘Investigate’ item basket. If one does not exist, it will be created.
  • Pick Icon (circle with checkbox) – displayed when the item has been fully picked
Selecting an item will navigate to the Item Detail screen for that item. Scanning is also allowed. For picks by customer order, if the user preference Scan Navigate is set to ‘Yes’ the user is directed to the Item Detail screen. If it is set to ‘No’, the user is taken to the scanned item in the list. For picks created by bin, the user is directed to the Confirm Bin popup to validate the bin prior to going to Item Detail. The quantity may be updated per the quantity scanned.
Complete: The user can select Complete from the footer to complete the pick. The user must have proper permissions.
  • The pick will be moved to ‘Completed’ status, and the user returns to the Customer Order Picks screen.
  • Holding location may be required per store configuration Holding Location Required.
  • When completing, if any of the store customer order quantities on the pick transaction have been canceled or delivered since the pick was created, and the total pick quantity for the item is now greater than the remaining pick quantity:
    • The Adjusted Pick Qty field (on Item Detail) will be updated to indicate to the user how much is needed to pick based upon the changes (delivery and cancels) that were made on the customer order.
  • Upon complete, the system will check the system admin, ‘Customer Order Fulfillment Restriction’:
    • If it is set to ‘Restricted’, the entire customer order must be picked in its entirety.
    • If it is set to ‘Line controlled’, any item that is getting picked must be picked in its entirety.
    • If it is set to ‘Transaction Controlled’, no restrictions.
  • Tolerances
    • When the item has a variable unit of measure (not Units), it can be difficult to pick the exact amount suggested. For example: picking 2 pounds of bananas might end up truly being 2.2 lbs. The quantity picked may exceed the suggested if the defined tolerances are setup to allow for such.
  • Substitute Items
    • Substitute Items are considered in the Total Pick Qty when doing all quantity validations.
    • The reserved quantity for the original item is decreased by the rolled up pick quantities.
    • The substituted items that have an actual pick quantity greater than zero will have their reserved quantity increased for the amount being substituted.
  • Upon successful completion
    • The Customer Order record is updated with the picked quantities.
    • If more was picked than what was ordered/reserved, the reserved quantity will be updated (in the case of over picking due to tolerances for non unit items).
    • Substitute items are added to the customer order.
    • The pick is published out.
The footer menu is accessed from the ellipsis footer menu on the Pick Items screen. The menu functions will include the following:
Notes: will access the notes common dialog to capture notes. Notes can only be added for picks by Store Customer Order ID. The note will be saved on the customer order and not the pick.
Print: will display the common print dialog to print the customer order pick report.
Back: is only applicable to view only picks and will exit to the Customer Order Picks screen.
Cancel: will exit to the Customer Order Picks screen and no changes will be saved.
Delete: will allow deleting a 'New’ or ‘In Progress’ status pick and moves it to ‘Canceled’ status. The user will return to the Customer Order Picks screen.
Refresh: will refresh the customer order pick and pull in any delivered or canceled quantities that have happened for the delivery.
Holding Location: will navigate to the Holding Location screen.
Bins: will access the Bins screen.
Save & Exit: will save the pick as ‘In Progress’ status and return the user to the Customer Order Picks screen.
Item Detail (Picking)
Figure 12-24 Item Detail Screen
Item Detail Screen
The Item Detail screen contains the details for the specific item on the customer order pick. Entering/scanning an item on this screen will refresh the screen and update item and the pick quantity for the item. If the pick is by bin, first the user will have to Confirm the bin before refreshing the details for the item.
The scan details at the top displays the details of the last scanned barcode. The arrows at the top allow the user to page to the next and previous items.
Fields Include:
  • Bin – bin associated with the pick/customer order. Only displayed if the pick was created by bin.
  • Substituted – will display as ‘Yes‘ if this item has items that were substituted for it. If this item does not have substitutes, then it will display as ‘No‘.
    • The field only displays if the item is flagged on the customer order to allow for substitute items.
    • Tapping on this field will navigate to the Substitute Items screen. Security permissions must exist.
  • Substitute For – will only be displayed if this item was added as a substitute for another item.
    • This will show the original item that it was substituted for.
    • Tapping on this field will navigate to the item details for that item.
  • Pick Quantity – is editable by the user and represents how many of this item is being picked.
    • Editing the quantity is controlled by security.
    • If the quantity is edited, the user will be prompted with the Confirm Items popup to confirm the proper item and also the confirm bin (if pick is by bin).
  • Needed Quantity – displays the quantity the system suggests to be picked.
  • Pack Size
  • Store CO ID – displays the customer order ID associated to the item on the pick.
    • This is displayed for picks created by order or by bin.
  • Adjust Quantity – is the suggested pick quantity that is updated by the system upon refresh or trying to complete the pick.
    • It reflects any deliveries or cancellations that have occurred on the customer order since the time the pick was generated.
  • Total Picked – is the total amount picked for the item along with all of its substitute items.
  • <X> Substitutes – <X> is the number of substitutes for the item.
The footer menu provides Add and Remove from the Item Basket options. This allows the user to add and remove the item from an open ‘Investigate’ item basket. If one does not exist, it will be created.
Confirm Item/Confirm Bin
Figure 12-25 Confirm Item/Confirm Bin Popup
After editing the pick quantity the user will be required to confirm the item in the Confirm Item popup. This is to validate the proper item is being picked. This is not required when scanning an item.
For picks that are by bin, the user also needs to validate that the items are being placed into the proper bin. When scanning/entering an item or editing the pick quantity, the user will be directed to the Confirm Bin popup to scan the bin for the item. This is only the case when in scan increase or decrease mode and not applicable to when in review mode.
The confirm bin will occur after the Confirm Item (if applicable).
Substitute Items
Figure 12-26 Substitute Items Screen
The Substitute Items screen is accessed by selecting the Substituted field on the Item Detail (Picking) screen. This screen is only available for items that are flagged to allow for substitute items, and the pick must be in an editable state.
This screen will list all of the related items that are substituted items with available stock for the item being picked (if there are any). If the Item Substitution - Store Discretion equals 'Yes', the user does not have to use one of the items in the list, and can also enter/scan any item for substitution. It will be added to the pick as well as to the Substitute Items list. If the user does not have store discretion, only items from the list can be selected.
Figure 12-27 Information (Customer Order Pick) Screen
The information screen is an informational popup that contains information about the header level of the customer order pick. It is accessed through the Info menu option in the Footer menu on the Pick Items screen. Details include:
  • Pick ID
  • Status
  • CFAs (Flexible Attributes) will be displayed. The user can capture CFAs on this screen. Security permission is needed for entering CFA values.
  • Area – the area that needs to be picked. Only displayed if Customer Order Fulfillment Restriction is set to ’Transaction Controlled‘ and an area is assigned to the pick.
  • Create Date and Create User
  • Complete Date and Complete User
Holding Location
Figure 12-28 Holding Location
Holding Location
The Holding Location is used to define where the items for the customer order will be “held” once being picked by the associate until they are picked up or shipped. Customer Orders will have one holding location field associated with them.
Customer Order picks that are for multiple customer orders (picked by bin), will have potentially more than one holding location. There will be one holding location associated to each bin/customer order. The user can scan or enter the bin and then capture the holding location. The system will validate the store configuration Holding Location Required. If it set to ‘Yes’, and the user has not entered a holding location, then upon completing the pick, the system will navigate to the holding location screen to capture the holding location. If it set to ‘No’ the holding location is not required.
Delivering of a customer order consists of collecting the items that have been picked and then getting them to the customer (shipment or pickup). This might be for a customer pickup in the store / curbside or shipping them to the customer.
Features:
  • View customer order delivery (web order and non-web orders)
  • Edit an existing customer order delivery (web order)
  • Delete a customer order delivery (web order)
  • Print a customer order delivery
  • Create a customer order delivery (web order)
Throughout the Deliveries dialog the screens will display dynamically as Pickup / Curbside / Shipment dependent on the delivery type. They are referred to as “Delivery“ generically for ease.
Figure 12-29 Customer Order Delivery Screen Flow
Customer order deliveries will be accessed from the Customer Order dialog on the Customer Order Items footer menu via the Pickups / Curbside Pickups / Shipments menu option. The user must have proper permission. Customer order deliveries can be created and edited for web order types. Non web orders can only be viewed and are fulfilled through the POS system. Customer order deliveries will allow for viewing, creating, editing, saving, submitting, dispatching, printing, BOL, and deleting of customer order deliveries. A shortcut to create a customer order delivery can be created via the Quick Actions menu (with proper permission).
Pickups / Curbside Pickups / Shipments (List screen)
Figure 12-30 Deliveries (List) Screen
The Deliveries screen will be called Pickups, Curbside Pickups, or Shipments depending on the delivery type of the customer order. It will be accessed by selecting the corresponding Delivery menu option within the footer menu of a specific customer order. The user must have proper permissions. The screen will display all of the customer orders deliveries for the specific customer order. The deliveries displayed may be for web orders that were created within the system, a third-party system such as POS, or they may be for POS on holds and layaways.
Since there will never be a large number of deliveries for a specific customer order, there is no search criteria screen. There is however a filter bar, which allows for filtering by: delivery ID, status, date, user, tracking ID, and Fiscal Doc ID. Records can also be sorted.
Selecting a delivery will navigate to the details for the customer order delivery.
The Create button will attempt to create the delivery and navigate to the corresponding Delivery Items screen. Create Delivery is also available from within the Quick Actions menu. The user must have proper permissions to create a delivery.
New Deliveries can only be created for web order customer orders that are not in 'Completed' or 'Cancelled' status, which means there is remaining quantity yet to be fulfilled.
If open Reverse Picks exist for the Customer Order, that option will be available rather than the Deliveries option. The Reverse Pick will need to be processed prior to creating the delivery.
In case the system is configured to require picking, it will validate there are item quantities on the customer order that have been picked which have not yet been delivered prior to creating the delivery. Next, the system will check the Allow Partial Delivery indicator which is on the customer order fulfillment order. If this is set to 'No', it means that the entire order must be delivered together. The system would not allow the creation of the delivery unless the entire order has been picked. If picking is not required, the delivery will be created. The Allow Partial Delivery indicator will then be validated again upon dispatch of the delivery.
Once the system creates the delivery, the delivery will consist of all of the items that were auto populated from the customer order fulfillment order including substitutes.
This screen gives a quick view of the list of deliveries for the customer order along with the details such as delivery ID, status, status of the Fiscal Doc/E-way bill request(if the system is configured to use Fiscal Doc ID/E-way Bill ID), etc.
Important fields on this screen include:
  • Store CO ID
  • Delivery Type for Release Date – the type of delivery being ‘Ship to Customer’, Customer Pickup’, ‘Layaway’, ‘POS Order’, or ‘On Hold’
  • Release Date – the date and time the customer order needs to leave the store
  • Status – of the customer order
  • Number of deliveries
  • Each Delivery Record will include:
    • Last Update Date
    • User
    • ID
    • Status – of the delivery. ‘New’, ‘In Progress’, 'Submitted', ‘Canceled’, and ‘Completed’
    • E-way bill status
    • Number of SKUs
Create Delivery
Figure 12-31 Create Delivery Screen
The Create Delivery screen is displayed when selecting Create Delivery from the Quick Actions menu. The user must have Create Customer Order Delivery permission.
The user can enter or scan the Customer Order ID or Bin and the system will look for customer orders in the system. If there is only one, the system will navigate to the Delivery Items screen to create a new delivery. If there is more than one, then the user will select the proper customer order from the list. The user must have the proper Create Customer Order Delivery for Shipment or Pickup permission that matches the delivery type of the customer order.
Delivery Items
Figure 12-32 Delivery Items Screen
The Delivery Items screen is accessed by selecting an existing Delivery from the Deliveries (list) screen, or by creating a new delivery. It is also accessible by selecting an existing delivery from Recently Edited or from Notifications. The user must have proper permissions. Deliveries are not directly accessible from Open Transactions.
The Delivery Items screen displays all of the items on the delivery including the order and remaining quantities.
Selecting an item will navigate to the Item Detail (Customer Order Deliveries) screen for that item. Scanning an item will also navigate to the Item Detail screen for that item and the quantity may be updated per the quantity scanned or it will stay on the current screen and increment the quantity depending on the user preference Scan Navigate. If the item scanned is a UIN item, the user will navigate to the UIN tab within the Item Detail screen.
A Filter bar will allow to filter by Item ID and Item Description. Sorting of the items is also available.
  • Delivery ID
  • Customer Order ID
  • Status – of delivery
  • Curbside Pickup Information – populated for delivery types of curbside pickup when this information has been populated by an external system
  • Number of Items
  • Quantity – total quantity of items on the delivery
  • Default Quantities – defaults the quantity to what can be delivered, what is remaining
    • It will only update those items that do not have a quantity entered.
    • This button does not apply to UIN items.
  • Clear Quantities – will clear out all entered quantities on the delivery.
  • Holding Location
  • Item
  • Item Description
  • Order Line – if the order contains duplicate line numbers
  • Comments – line level comments from the customer order
  • UIN icon – will be displayed if the store allows for UINS and the item is a UIN item
  • Extended Attributes icon – will be displayed if the item has extended attributes associated to it
  • Order quantity
  • Remaining quantity
  • Pack Size
  • Delivery Quantity – the delivery quantity to be entered by the user (editable)
    • Disabled for UIN items. UIN items must have UINS captured by selecting the quantity field.
  • Needed Quantity – the remaining quantity to be delivered
  • Ship Alone – will state if the item is a ship alone item
  • Substitute Items – will have an expander icon to display the substitute items for the item, if they exist on the customer order
  • …(Overflow menu) – will have an option to add extended attributes for the item
If any item in the customer order has the Customer Order Ship Alone indicator set to 'Yes', then the system will not allow the user to deliver this item along with other items. Those items will need to be shipped alone.
Pickup / Dispatch:
  • The user must have proper permission.
  • Will check if the Allow Partial Indicator is set to 'No, and if so, it will validate that the entire order is being delivered together. If not, the system will restrict the user from dispatching.
    • Those users with certain privileges will receive a warning and will be able to override this.
    • If the user does not have this privilege, and if there are items that need to be “shipped alone” the delivery cannot be dispatched.
  • If the Allow Partial Indicator is set to 'Yes', the customer order can be delivered partially.
  • If the system parameter Customer Order Fulfillment Restriction is set to 'Line Controlled' and Allow Partial Indicator is set to 'Yes':
    • If an item is getting delivered then it has to be delivered fully. Partial delivery of an item is not allowed.
  • If the store parameter Manifest Customer Order Deliveries is set to 'No' and the system parameter Tracking ID Required is set to 'Yes':
    • The system should check if the Tracking ID has been captured or not. If not, an error message will be displayed.
  • The Holding location may be required per store configuration Holding Location Required.
  • Upon dispatch of the delivery the delivery will move to 'Completed' status, and the user returns to the Deliveries (list) screen.
  • The delivery is published out.
  • UINs will have the status updated to ‘Customer Order Fulfilled’.
  • If the entire customer order has been fulfilled, meaning there is no remaining quantity, the customer order will be set to 'Completed' status.
  • The Transaction History record is written.
  • If the system is enabled to obtain Fiscal Doc ID/E-way bill ID as part of the shipping process, the delivery cannot be dispatched until the Fiscal Doc ID/E-way bill ID is available. The exception is when the user has ‘Allow dispatch without Fiscal Document ID’ security permission.
  • The request of the E-way bill starts once the shipment is submitted.
As part of the delivery process, if the manifest system is called, the system will also make a call to get the address information related to the customer order since this data is not stored in SIOCS.
Submit:
  • Submit will submit the delivery and set it to 'Submitted' status and not allow for edits, and there are no updates to inventory at this point.
  • Submit is only available when the store configuration for Dispatch Validate is set to 'Ship Submit'. It is not possible when set to 'Ship Direct'.
  • The only step possible will be to Cancel, Submit or Dispatch.
  • Submit will check if the Allow Partial Indicator is set to 'No', and it will validate that the entire order is being delivered together. If not, the system will restrict the user from submitting.
    • Those users with certain privileges will be given a warning and will be able to override this.
  • If the system parameter Customer Order Fulfillment Restriction is set to 'Line Controlled' and the Allow Partial Indicator is set to 'Yes':
  • If the store parameter Manifest Customer Order Deliveries is set to 'No' and the system parameter Tracking ID Required is set to 'Yes', the system should check if the Tracking ID has been captured or not If not, an error message will be displayed.
  • If the system is enabled to obtain Fiscal Doc ID/E-way bill ID for the shipment, the process to request the E-way bill starts once the shipment is submitted.
The footer menu is accessed from the ellipsis footer menu on the Delivery Items screen. The menu functions will include the following:
Holding Location: will take the user to the Holding Location screen
Bill of Lading: will access the BOL Info popup
Notes: will access the notes common dialog to capture notes. The note will be saved on the customer order.
Cancel: will exit to the Deliveries (list) screen and no changes will be saved.
Back: is applicable to view only deliveries and will exit to the Deliveries (list) screen
Save & Exit: will save the delivery in 'In Progress' status and return to the Deliveries (list) screen
Refresh: will refresh the delivery by getting the most current customer order/ fulfillment order information. There may be other picks or deliveries that have occurred in the time the delivery was originally created.
Delete: will delete an 'In Progress' status delivery and move it to 'Canceled' status. The user will return to the Delivery List screen.
External Printing: will display the external printing dialog to select a printer for pre-shipment or manifesting
Print: will display the print dialog to print the report
Figure 12-33 Item Detail (Customer Order Deliveries) Screen
The Item Detail screen contains the details for the specific item on the customer order delivery. Entering/scanning an item on this screen will refresh the screen and update the item and the delivery quantity for the item. If the item scanned is a UIN item, the user will automatically navigate to the UIN screen for the item.
If the item has the Customer Order Ship Alone indicator set to 'Yes', then the system will not allow the user to deliver this item along with other items. Those items will need to be shipped alone.
Fields include:
  • Delivery Quantity – how many to be delivered (picked up or shipped) by the user (editable)
    • If picking is required, the quantity will not be allowed to exceed the pick quantity. If picking is not required, the quantity cannot exceed the remaining quantity.
  • Substitute For – will display the original item that this item was substituted for
  • Needed Quantity
  • Ordered Quantity
  • Picked Quantity
  • Delivered Quantity
  • Canceled Quantity
  • Pack Size
UIN
Figure 12-34 UIN Screen
UIN Screen
If the store is configured for UINs, and the item is a UIN item, then UINs must be captured for the items being put on the delivery.
The UIN screen allows a user to add/remove UINs for UIN items (if the store is configured to use UINs and if the item is a UIN item). If the user scans a UIN item, the user will directly navigate to the UIN screen for that item.
Only UINs that are ‘In Stock’ can be put on a customer order delivery.
Figure 12-35 Information Popup
Information Popup
The Information screen contains information about the header level of the customer order shipment/pickup. It is accessed through the Information menu option in the footer menu on the Delivery Items screens. Details include:
  • Delivery ID
  • Status (delivery)
  • Create Date and User
  • E-way Bill Fields:
    • Vehicle Number
    • Vehicle Country
    • Driver Name
    • Driver License Number
  • Holding Location – link to display the holding locations
  • Reservation Type
  • Delivery Type
  • Customer Order ID
  • Order Create Date
  • Order Release Date
  • Order Delivery Date
  • Delivery Create Date and User
  • Delivery Update Date and User
  • Submit Date and User
  • Dispatch Date and User
  • Status (order)
  • Comments
If the customer order is available for Direct Ship to Customer and Fiscal Documentation information is required and integrated, the screen will also display:
  • Fiscal Request ID
  • Fiscal Request Status
  • Reject Reason
  • Fiscal Doc ID
  • Fiscal Doc Link
Bill of Lading
Figure 12-36 Bill of Lading Screen
The Bill of Lading screen contains information about the Bill of Lading (BOL) for the customer order delivery. It is accessed through the BOL Info menu option in the Footer menu on the Delivery Items screen.
Fields include:
  • Bill of Lading
  • Motive
  • Pickup Date
  • Dispatch Date
  • Package Type – list of values. If Manifesting is being used (store admin), and if the carrier/ service is configured to require package type, then the package type will be required.
  • Weight – If Manifesting is being used (store admin), and if the carrier/service is configured to require weight, then the Weight will be required.
  • Tracking ID – may be overwritten by the manifest system
  • Type – Sender, Receiver, Third Party
    • Defaulted to ‘Sender’ for Delivery type of ‘Ship to Customer’ and no carrier is identified on the order.
    • Defaulted to ‘Receiver‘ for Delivery Type of ‘Customer Pickup’ and no carrier is identified on the order.
  • Carrier – list of carriers. The list is controlled by the data permission ‘Shipment Carrier’. Enabled and required for type of ‘Third Party’. If ‘other’ is selected then the Carrier Name and the Address are enabled. May be overwritten by the manifest system.
  • Service – the list of services displayed is controlled by the data permission ‘Shipment Carrier Services’. Only enabled for type of ‘Third Party’. May be overwritten by the manifest system.
    In case the user does not have the permission for a carrier/service, the data will be view only and cannot be changed by the user.
  • Carrier Name and Address – required when the carrier type is 'Third Party' and the carrier is 'Other'
Canceling of customer orders can come in from an external system, such as an Order Management System. When this happens, a reverse pick list will be generated. If there are items that physically need to be unpicked, the user will action the reverse pick list which will then take the items that were canceled and move the picked quantities back to the appropriate area in the store. If the items that are being canceled are not picked, then the system generated reverse pick will just be created in a 'Completed' status with no action required through the application.
A system-generated reverse pick may also get created if the user rejects an open customer order.
A manual reverse pick might also be necessary. This happens when the user discovers that something which was picked has to be unpicked, maybe because it has been damaged. The manual reverse pick will reverse the pick quantities.
Note that reverse picking and canceling is more of an exception process.
Features:
  • View customer order reverse picks
  • Edit an existing customer order reverse pick
  • Delete a customer order reverse pick
  • Print a customer order reverse pick
  • Create a customer order reverse pick
Manual Reverse Pick
  • The user might want to create a manual reverse pick because something that was picked might have become damaged and therefore it must be unpicked.
  • New Reverse Picks can only be created for Web Order customer orders that are in any status except 'New', 'Under Review mode but in New status', 'Completed' or 'Cancelled'.
  • There must be at least one item on the customer order with a physical picked quantity. By physical picked quantity it means a quantity that is still physically sitting there as picked, and it has not been delivered (which means shipped or picked up by the customer).
  • Once the reverse pick is created, it will consist of all the items auto populated from the customer order fulfilment order including the substitute items.
  • The Needed Reverse Pick Quantity will be set to zero for manual picks. For manual reverse picks, the quantity cannot exceed the physical picked quantity.
External System-Generated Reverse Pick
  • When a system generated reverse pick is created, it will put all items on the reverse pick, including the substitute items. However, only those items that have a needed reverse pick quantity will be allowed to be reverse picked.
  • The Needed Reverse Pick Quantity will be populated with what should be reverse picked based upon the cancellation from the external system. For externally system generated reverse picks, the Quantity cannot exceed the remaining quantity or the needed reverse pick quantity.
  • If a cancellation comes into the system that is for more than what is remaining on the order, the cancellation will be rejected and a system-generated reverse pick will not be created.
  • When creating the system generated reverse pick, the system will first try and cancel those items that have not been picked.
    • If this quantity is exceeded, it will cancel those items already picked.
    • When all items that are canceled have not been picked, there will not be anything to un-pick and therefore the reverse pick will be auto completed and put into a ‘Completed’ status and updates will happen to the customer order and inventory as stated below.
When some or all items that are canceled are picked, this creates a system generated reverse pick in ‘New’ status. This occurs so the user can action it and unpick the items. Updates will occur upon confirmation of the reverse pick as described below.
Figure 12-37 Customer Order Reverse Picking Screen Flow
Customer order reverse picking will be accessed from within the Customer Order dialog on the Customer Order Items footer menu. It can also be accessed selecting an existing Reverse Pick in Recently Edited or if there is a Notification. Reverse Picks cannot be directly accessed from Open Transactions. Customer order reverse picks can be created and edited for web order types. Customer order reverse picking will allow for viewing, creating, saving, editing, confirming, and deleting of customer order reverse picks.
Reverse Picks
Figure 12-38 Customer Order Reverse Picks Screen
The Reverse Picks screen is accessed by selecting the Reverse Pick menu option within the footer menu of a specific customer order. The list will contain all of the Reverse Picks for the specific Customer Order. The screen will list both externally created / system-generated reverse picks as well as manually created reverse picks. Reverse Picks are only available for web orders.
The Reverse Pick List screen lists reverse pick records for all statuses. Reverse Picks do not have a search criteria as there normally would not be that many reverse picks for a customer order fulfilment order to search for. There is however a filter, that allows filtering by: Reverse Pick ID, Create Date, Status, and User. A sort option is also available. Selecting a reverse pick record will navigate to the details on the Reverse Pick Items screen.
Fields include:
  • Last Update Date
  • User
  • ID
  • Status
  • Number of SKUS
Finally, the user can create a new manually created reverse pick.
Reverse Pick Items
Figure 12-39 Reverse Pick Items Screen
The Reverse Pick Items screen is accessed by selecting an existing Reverse Pick from the Reverse Picks screen, or by creating a new Reverse Pick. It can also be accessed by selecting an existing Reverse Pick from Recently Edited or from within Notifications. Proper permissions must exist.
Selecting an item will navigate to the Item Detail (Customer Order Reverse Picking) screen for that item. Scanning an item will also navigate to the Item Detail screen for that item and the quantity may be updated per the quantity scanned or it will stay on the current screen and increment the quantity depending on the user preference Scan Navigate .
A Filter bar will allow to filter on: Item ID, Item Description and UOM. Sorting of the items is also available.
  • Reverse Pick ID
  • Store CO ID
  • Status – of reverse pick. ‘New’, ‘In Progress’, ‘Completed’, or ‘Canceled’.
  • Number of Items
  • Holding Location
  • Default Quantities – defaults the quantity to what can be reverse picked
    • Manually Created – defaults to the physical pick quantity
    • System Generated – defaults to the needed (suggested) pick quantity. If there are substitutes, this option will not be available.
  • Clear Quantities – will clear out all entered quantities on the reverse pick
  • Item
  • Item Description
  • Location – primary location for the item. Only displayed if ‘Display Sequence Fields’ is set to ‘Yes’.
  • Need Reverse Pick Quantity – quantity suggested by the system. Only for system generated reverse picks
  • Quantity – the quantity being reverse picked. Entered by the user.
  • Pack Size
The items on the reverse pick are determined based upon the following rules:
  • Manually created reverse picks will put only the items that:
    • have a physical pick quantity, meaning they have been physically picked and therefore can be reverse picked
    • OR, if there is reverse pick qty, meaning one had already been entered by the user on the reverse pick and saved (the PPQ may not exist any longer on the customer order depending on what has happened to the order)
  • Externally generated (system) reverse picks will put all items on the reverse pick that have a needed (suggested) quantity. Meaning the items that are being canceled by the external system. If the item being cancelled has a substitute(s) those will be put on the reverse pick along with the original item.
  • All ‘completed’ and ‘canceled’ status reverse picks will display all items from the customer order.
Confirm: will complete the Reverse Pick and move it to ‘Completed’ status
  • Holding location may be required per store configuration ‘Holding Location Required’.
  • For manual reverse picks:
    • The pick quantity on the customer order will be decremented by what was reverse picked.
    • The reserved quantity and the canceled quantity will not get updated as the items are not being canceled on the order, so they need to remain as reserved. They are simply being unpicked.
  • For the externally (system) generated reverse picks:
    • The pick quantity will be decremented on the customer order.
    • The reserved quantity (if it had been reserved) will be decremented by what was reverse picked and put back to the backroom.
    • The Canceled quantity on the customer order will be incremented by the reverse picked quantity.
    • If all items have been canceled and there have been no deliveries, the status of the customer order will move to ‘Cancelled’.
    • If there is no remaining order quantity on the order, and some of the items have been delivered, the customer order will move to ‘Completed’ status.
The footer menu is accessed from the ellipsis footer menu on the Reverse Pick Items screen. The menu functions will include the following:
Print: will display the common print dialog to the report
Holding Location: will display the holding location
Refresh: will refresh the reverse pick by getting the most current customer order/fulfillment order information. There may be other picks, deliveries, or cancellations that have occurred in the time the delivery was originally created.
Back: is only applicable to view only reverse picks and will exit to the Reverse Picks screen
Cancel: will exit to the Reverse Picks screen, and no changes will be saved.
Delete: will allow deleting of an ‘In Progress’ status reverse pick and moves it to ‘Canceled’ status. The user will return to the Reverse Picks screen.
Save & Exit: will save the reverse pick as ‘In Progress’ status and return to the Reverse Picks screen
Item Detail (Customer Order Reverse Picks)
Figure 12-40 Item Detail (Customer Order Reverse Picks) Screen
The Item Detail screen contains the details for the specific item on the customer order reverse pick. Entering/scanning an item on this screen will refresh the screen and update the item and the reverse pick quantity for the item.
Fields include:
  • Item ID and description
  • Item Image (per user preference)
  • Location – the primary location for the item. Tapping on this navigates to the Locations popup.
  • Reverse Pick Quantity – how many to be reverse picked by the user (editable)
    • For manual reverse picks, the user must enter a quantity less than or equal to the physical pick quantity for the item.
    • For system generated (external) reverse picks the quantity must be less than or equal to the needed (suggested quantity) for items which are units. It must be less than or equal to the remaining quantity for variable UOM items (that is Kg, Lbs, and so on).
  • Needed Reverse Pick Quantity – the quantity suggested by the system. Populated for system generated reverse picks and set to 0 for manually created reverse picks.
  • Pack Size
  • Remaining
  • Ordered
  • Picked
  • Delivered
  • Canceled
Info (Customer Order Reverse Picks)
Figure 12-41 Customer Order Reverse Picks Info Screen
The Info popup contains read-only information about the header level of the customer order reverse pick. It is accessed through the Info menu option in the Footer menu on the Reverse Pick Items screen. Reverse Pick information includes:
  • Reverse Pick ID
  • Status
  • Create Date/User
Order details include:
  • Reservation Type
  • Delivery Type
  • Customer Order ID
  • Create /Release/Delivery Date
  • Status (order)
  • Comment
This flowchart shows a simple, straight forward status flow of a customer order when picking is required.
Figure 12-42 Customer Order Status Flow when Picking is Required
The following table shows the different statuses that a customer order can take when picking is required for the customer order:
Table 12-1 Customer Order Status when Picking is Required
Status Meaning
New
The order is created but not been accepted yet at the store.
Picking Required
When no open pick exists and the Picked quantity is less than the Remaining quantity and Picking is required.
Pick in Progress
A pick is open for an order.
Reverse Pick
A reverse pick is open for an order.
Ready to Ship
If the Picked quantity >= Remaining quantity and the order is not fully shipped yet and the order is of type 'Ship to Customer'.
Ready for Pickup
If the Picked quantity >= Remaining quantity and the order is not fully picked up yet and the order is of type 'Customer Pickup'.
Delivery in Progress
If at least one delivery is available which is either saved or submitted but not dispatched yet.
Completed
This is one of the final states of a customer order. When the customer order is fully shipped or picked up, it goes to 'Completed' status.
Cancelled
This is also one of the final states of a customer order. When the customer order is rejected or cancelled, it goes to 'Cancelled' status.
The following flowchart shows a simple, straight forward status flow of a customer order when picking is not required.
Figure 12-43 Customer Order Status Flow when Picking is Not Required
The following table shows the different statuses that a customer order can take when picking is not required for the customer order:
Table 12-2 Customer Order Status when Picking is Not Required
Status Meaning
New
In Progress
A customer order gets this status when it is being looked at and the order is not fully shipped by the store or picked up by the customer.
Completed
Cancelled
Customer Order Status Update Logic
Picking Required for Customer Orders is set to Yes
When the store parameter Picking Required for Customer Orders is set to Yes, the status of customer orders will need to be checked for update whenever any of the following events occur on the customer order.
  1. When the customer order is accepted at the store.
  2. When a Reverse pick is saved, completed or cancelled, both internally in the system and externally.
  3. When a pick is created, saved, completed or cancelled.
  4. When a delivery record is created, cancelled, saved, submitted or partially/fully dispatched.
  5. When POS sends a fulfilment record against the customer order, which partially/completely fulfilled the order.
  6. When the customer order is rejected by the store or cancelled by the user or at Order management system.
These events can be a manually created, system generated, internally created or externally created event.
After any of the events mentioned above occur, perform the following:
For the Customer Order, check if there is at least one open reverse pick exists:
If Yes, update the status of the customer order to Reverse Pick.
If No, check if there is a Pick in Progress, that is, Pick's status = New or In progress.
  • If Yes, update the status of the customer order to Pick In Progress.
  • If No, check if there is a Delivery In Progress, that is, at least one delivery which is either saved or submitted and not dispatched yet.
    • If Yes, update the status of the customer order to Delivery In Progress.
    • If No, check the Picked Qty of the items on the customer order.
      • If Allow Partial Delivery = No,
        If at least one item is not completely picked, update the status to Picking Required.
        If all items are picked completely, then:
        if the order is of type Ship to Customer, update the status of customer order to Ready to Ship, or,
        if the order is of type Customer Pickup, update the status of customer order to Ready for Pickup.
      • If Allow Partial Delivery = Yes,
        If no item is picked yet, update the status to Picking Required.
        If at least one item is picked partially or completely picked, then:
Picking Required for Customer Orders is set to No
When the store parameter Picking Required for Customer Orders is set to No, the following is true:
If the store has decided to not pick the items before shipping, then if the Customer Order is accepted, the status will show In Progress.
If the store has decided to formally pick the items and ship, the status is derived as per the rules that apply when Picking Required is set to Yes.
Completed and Cancelled
Completed and Cancelled are the final states of a customer order, irrespective of whether picking is required or not.
The customer order moves into Completed status when:
  • a customer order is completely shipped by the store or picked up by the customer
  • a customer order is rejected and some items have been delivered already
The customer order moves into Cancelled status when:
  • a customer order is rejected and none of the items have been delivered
  • a customer order is cancelled by the user or at the Order management system
The customer order will become read-only once it reaches either Completed or Cancelled status.
Under Review Status
When the retailer has chosen to integrate with OBCS (Order Broker Cloud Services) and whenever a customer order goes through payment reauthorization, the Order Broker system informs the Store Inventory system about it and the status of the customer order would move to 'Under Review'. This is to indicate that the customer order is going through payment reauthorization and it is not in the state to be submitted/dispatched. The Store Inventory system would have to wait for the payment reauthorization to be successful in order to submit/dispatch the customer order.
The status of the customer order is not updated to 'Under_Review' at DB rather the status displayed in the UI alone would show 'Under_Review'.
When the customer order moves to 'Under Review' mode, the user can still perform the same actions on the customer order as if it is in New/In Progress/Picking Required/Delivery In Progress, Ready to Ship/Ready for Pickup/Reverse Pick status. that is, the user will be able to approve/reject, create pick/reverse pick/delivery and so on, A validation will be done on Submit/Dispatch of customer order deliveries to ensure that the customer order is not in 'Under Review' mode.
Whenever OBCS informs Store Inventory system that the payment reauthorization has been successful, the status of the customer order moves back to its previous status or to an appropriate status based on the activities that had happened on the customer order while it was in 'Under Review' mode. The customer order would now be available for submit/dispatch. If the payment reauthorization fails, the customer order would get cancelled.
