Renaming a Project (CLI)
You can rename a project with file retention if the project is empty and has an unexpired grace period. If retention is set on an empty project and the grace period is met or not set, you cannot rename the project until the expiration period has been met. A non-empty project cannot be renamed until all retained filesystems within the project have an expired retention value. For more information, see File Retention Management.
Caution:
Changing a project name will disrupt active client I/O operations.Related Topics
