JDeveloper provides several debugging windows (for example, Breakpoint, Heap, and Stack) that enable you to identify problem areas in your code. In addition, the various JDeveloper debugger and runner icons available from areas in the JDeveloper user interface are described.
This chapter includes the following sections:
JDeveloper offers several techniques to monitor and control the way Java programs run. When running Java programs, JDeveloper keeps track of processes that are run and debugged, or profiled. In addition, JDeveloper offers both local and remote debugging of Java, JSP, and servlet source files.
JDeveloper supports two types of debugging: local and remote. A local debugging session is started by setting breakpoints in source files, and then starting the debugger. When debugging an application such as a servlet in JDeveloper, you have complete control over the execution flow and can view and modify values of variables. You can also investigate application performance by monitoring class instance counts and memory usage. JDeveloper will follow calls from your application into other source files, or generate stub classes for source files that are not available.
Remote debugging requires two JDeveloper processes: a debugger and a debuggee which may reside on a different platform. Once the debuggee process is launched and the debugger process is attached to it, remote debugging is similar to local debugging.
The Processes window keeps track of processes that are run, debugged, or profiled. When two or more such processes are active at the same time, the Processes window is automatically displayed. When a process has completed, it is automatically removed from the Processes window.
To open the Processes window, choose Window > Processes from the main menu.
To terminate a process within the Processes window, right-click a process in the Processes window and choose Terminate from the context menu.
To view the Run Log, right-click a process in the Processes window and choose View Log from the context menu.
Settings that control the way programs are run - such as the target, launch options, and the behavior of the debugger, logger, and profiler - are collected in run configurations.
A project may have several run configurations, each set up for a specific facet of the project or phase of the development process. A run configuration can be bound to the project and be available to all who work on the project, or it can be custom configuration, for your use only.
Java programs that are run from JDeveloper, for example the Oracle ADF Model Tester, do not inherit the JDeveloper IDE Java options. Therefore in most cases you should set the run/debug Java options you want to use in the run configuration.
A default run configuration is created for each new project. You can select it or any other configurations you have created to run a selected project.
To choose a run configuration:
You create a new run configuration by copying an existing one, for example, Default. Then you modify the settings for the new configuration
To create a run configuration:
After compiling your project or file, you can run it. For more information about building a project or file, see Building Java Projects The log window displays any warning or error messages that may occur during the run.
To run a project or file:
In order to run a project from the operating system command line:
The project must be a standalone executable.
You must select the class file containing the application main()
method.
To launch an application, enter the following:
java -cp <jdev_install>\jdeveloper\jdev\mywork\Workspace1\Project1\classes package1.Application1
To launch the executable JAR file from the command line, enter the following:
java -jar <application>.jar
where <application>
is your JAR file name.
You may need to change the Java Virtual Machine (VM) for which you are developing because of operating system considerations. For example, for client-side applications, you would use the HotSpot Client VM, whereas for executing long-running server applications, you would use the Server VM.
To change the Java Virtual Machine:
When you run a Java program from the command line, you must provide the Java Virtual Machine (JVM) with a list of the paths to the class files and libraries that comprise your application. The form of the classpath changes depending on the method you use to run the Java program.
Your Java classes can be stored in Java Archive (*.jar
) files, or as separate class (*.clas
s) files in their package directory. There are differences in the ways Java handles JAR files and package directories.
When you refer to JAR files in your CLASSPATH
, you use the fully qualified path to the JAR file. When you refer to package directories in your CLASSPATH
, you use the path to the parent directory of the package.
You can refer to both JARs and package directories in a CLASSPATH
statement. When you refer to more than one CLASSPATH
in the same statement, each CLASSPATH
is separated with a semicolon(;).
Once you have defined the classpath, you pass the value to the JVM in different ways, depending on how you run your Java program.
Set the CLASSPATH
environment variable to run a standalone application using java.exe
Set the CLASSPATH
environment variable to.use the -classpath
option of java.exe
Embed the CLASSPATH
in the <APPLET>
tag of an.html
file to run an applet in an Internet browser.
You have the option of using either the -classpath
option when calling an SDK tool (the preferred method) or by setting the CLASSPATH
environment variable.
The java.exe
file is included as part of the Java2 Standard Edition (J2SE). It is intended to be used as a development tool, and is not licensed for distribution with your Java programs. It is used to test your Java applications from the command prompt.
In order to run a Java application from the command prompt, the system environment variable CLASSPATH
must be defined to include all of the classes necessary to run your program. This includes any library classes provided with JDeveloper that your program uses.
JDeveloper ships hundreds of library classes to help you generate your Java programs. The classes come from J2SE, third-party developers, and Oracle Corporation. Each of the libraries is kept separate for easy upgrade. As a result, many archive files may need to be included in your classpath to ensure that any program you create in JDeveloper can be run from the command prompt.
Oracle recommends that you list only the paths to each of the libraries that your project uses. If you list paths that your project does not use, your program will still run, but for performance reasons, you will want to eliminate any unnecessary libraries.
Never use quotation marks in the classpath even when there is a space character in one of the paths.
If you have used the default directory for your output path, you can test your Java application using java.exe by appending the following directory to your classpath:
C:\<jdev_install>\jdeveloper\jdev\mywork\Workspace1\Project1\classes
Having set this variable, you can use java.exe
to run your application from the output directory mywork
If you have deployed your Java program to any other directory, you need to add the path to the parent directory of the application package.
The CLASSPATH
variable is a long string that can be difficult to type accurately. To save time and reduce errors, you can set the CLASSPATH
as a system environment variable.
The Java Runtime Engine (java.exe
) doesn't use the CLASSPATH
environment variable. The CLASSPATH
must be included as a parameter to the java.exe command. The format for the command is:
java -cp <classpath> package.Application
Where classpath is the complete CLASSPATH
to your Java program and the dependency classes it uses. Quotation marks are optional if there are no spaces in any of the CLASSPATH
directory names.
The Debugger provides you with a number of features to investigate your code, and identify and fix problem areas. Two types of debugging are available to analyze your code - local and remote.
Table 12-1 contains the special-purpose debugging windows that enable you to efficiently identify the problematic areas in your code.
Table 12-1 Debugging Windows
Window | Description |
Breakpoint |
Displays the breakpoints for the current workspace and project. For more information, see How to Use the Breakpoints Window. |
Smart Data |
Displays the data which is being used in the code that you are stepping through. For more information, see How to Use the Smart Data Window. |
Data |
Displays the arguments and local variables for the current context. Note that Full Debug Info must be selected in the Compiler page of the Project Properties dialog. For more information, see How to Use the Data Window. |
Watches |
Displays the watches created for fields or variables. A watch evaluates an expression according to the current context. If you move to a new context, the expression is reevaluated for the new context. For more information, How to Use the Watches Window. |
Inspector |
Displays a single data item in its own floating window. An inspector evaluates an expression according to the current context. For more information, see How to Use the Inspector Window. |
Heap |
Displays information about the heap in the program you are debugging and helps you to detect memory leaks in your program. For more information, see How to Use the Heap Window. |
Stack |
Displays the call stack for the current thread. For more information, see Using the Stack Window. |
Classes |
Displays information about the classes which have been loaded as your application runs, including the name and package of each class. The debugger can also display the number of live instances of each class and the amount of memory being consumed by those instances. For more information, How to Use the Classes Window. |
Monitors |
Displays information for active monitors in your application, as well as information about the status of threads accessing those monitors. This window is useful for examining deadlocks and other thread synchronization problems. For more information, see How to Use the Monitors Window. |
Threads |
Displays the threads and the thread groups, highlights the current thread, and shows the name, status, priority, and group of each thread. For more information, see How to Use the Threads Window . |
Table 12-2 contains the various JDeveloper debugger and runner icons. These icons are available from areas in the JDeveloper user interface, including the Debugger window and the Log window.
Table 12-2 Debugger and Runner icons
Icon | Name | Description |
Array |
Represents an array class in any JDeveloper data-related window. |
Add Breakpoint |
Represents the Breakpoint toolbar button used to create a breakpoint. |
Breakpoints menu |
Represents the View > Debugger > Breakpoints menu option or the tab icon for the Breakpoints window. |
Class |
Represents the View > Debugger > Classes menu option, the tab icon for the Classes window and a class in the Classes window (grayed if the class has tracing disabled). |
Class Without Line Number Tables |
Appears in the Classes window. Represents a class which does not have line number tables (obfuscated class). |
Current Execution Point |
Represents the current execution point shown in the source editor margin which you can display by choosing the Run > Show Execution Point menu option. |
Current Thread |
Represents the current thread in the Threads window. |
Data |
Represents the View > Debugger > Data menu option; the View > Debugger > Smart Data menu option; and the tab icon for the Data window and Smart Data window. |
Debug (Shift + F9) |
Represents the Run > Debug <project_name> menu option; the debug toolbar button, a debugging process contained in the processes folder in the Processes window, a log page for a debugging process, the debug layout, and the Remote Debugging and Profiling Project Wizard. |
Debug Listener Node |
Represents a debug listener node in the Processes window. |
Delete Breakpoint |
Represents Delete Breakpoint in the toolbar. Click to remove a breakpoint. |
Disable |
Represents a disabled breakpoint in the source editor margin and a disabled breakpoint in the Breakpoints window. The icon also represents the Disable Breakpoint command in the toolbar. Click to disable a breakpoint. |
Disable All Breakpoints |
Represents Suspend All Breakpoints command in the toolbar. Click to run the application without stopping at the breakpoints, then return to debugging mode. |
Edit Breakpoint |
Represents the Edit Breakpoint command in the toolbar, which you can use to edit the selected breakpoint. |
Enabled |
Represents an active breakpoint in the source editor margin and the Enable Breakpoint command in the toolbar. Click to enable the selected breakpoint. When the debugger is not running, the enabled breakpoint icon looks same as the unverified breakpoint icon. |
Garbage Collection |
Represents the Run > Garbage Collection menu option and the Garbage Collection command in the toolbar, which you can click. |
Interface |
Represents an interface in the Classes window. |
Heap |
Represents the View > Debugger > Heap menu option and the tab icon for the Heap window. |
Heap Folder |
Represents a folder in the Heap window. |
Method |
Represents a method in the Stack window. |
Monitors |
Represents the View > Debugger > Monitors menu option and the tab icon for the Monitors window. |
Object |
Represents an object in any JDeveloper data-related window. |
Package |
Represents a package in the Classes window (grayed if the package has tracing disabled). |
Pause |
Represents the Run > Pause menu option and the Pause toolbar button which you can click. |
Primitive |
Represents a primitive item in any JDeveloper data-related window. |
Resume |
Represents the Run > Resume menu option and the Resume toolbar button which you can click. |
Run |
Represents a running process in the Processes window, in a log page for a running process, and in the toolbar to run the selected node. |
Run to Cursor (F4) |
Represents the Run > Run to Cursor menu option. Lets you run to a specified location and execute the code until it reaches that location |
Stack |
Represents the Window > Debugger > Stack menu option and the tab icon for the Stack window. |
Stack Folder |
Represents the static folder in the Data window |
Step to End of Method |
Represents the Run > Step to End of Method menu option and the Step to End of Method toolbar button which you can click. |
Step Into (F7) |
Represents the Run > Step Into menu option and the Step Into toolbar button which you can click. |
Step Out (Shift + F7) |
Represents the Run > Step > Out menu option and the Step Out toolbar button which you can click. |
Step Over |
Represents the Run > Step Over menu option and the Step Over toolbar button which you can click. |
Terminate |
Represents the Terminate toolbar button which you can click to stop debugging your application. |
Threads |
Represents the Window > Debugger > Threads menu option and the tab icon for the Threads window. |
Thread Group |
Represents a thread group in the Threads window. |
Unverified Breakpoint |
Represents an unverified breakpoint in the source editor margin, and an unverified breakpoint in the Breakpoints window |
Verified Breakpoint |
Represents the verified breakpoint in the source editor margin. |
When debugging an application deployed to an integrated WebLogic Server, you can make changes to files and they will be reflected in the running application without you having to stop and redeploy the application. To debug the application, start the server in debug mode. Go to ORACLE_HOME/jdeveloper/jdev/bin
and run java -?
to see the run configuration options available for the version of the JDK you are running.
Modify JSF files
Save and refresh the browser if you are currently viewing the page that you modified, or navigate to the page if you were not on it. The page will reflect the changes you just made.
Save and recompile them. You can see the changes the next time the altered code is executed without having to re-start the application.
If you are stopped at a break point, you can:
Modify the class you are currently stopped in including the method that you are currently stopped in.
Right-click in the editor and rebuild the individual class.
Select the Stack tab (by default grouped with the Structure tab under the Applications window). At the top of the stack you will see that the method you are stopped in is obsoleted.
Right click on the previous method and select the Pop back to here menu item. JDev will re-position the cursor to the code that invoked the obsolete method.
When you restart execution, the changes you made to the class or method will be reflected.
you can only modify code that is private to the class. Review the console output after re-compiling. The output will make it clear whether of not the recompiled code is available for run-time.
Your code must be compiled with debugging information before you can make use of some of the debugger features such as viewing arguments and local variables in the Data window. This saves time when debugging and testing an application.
To set breakpoints and step through your code:
While debugging, use the HotSwap feature to fix errors and substitute corrected class definitions, without stopping and restarting your application. HotSwap is an enhancement to the Java Platform Debugger Architecture (JPDA) in Java 2 SDK v1.4, and has been implemented in JDeveloper's Java virtual machine, OJVM.
When the debugger is paused you can recompile classes. When the debugger resumes after code has been HotSwapped, threads that are currently executing old method definitions will continue to do so until those methods return. For subsequent method calls, the class definition will be used. However, existing instances of the class will not be modified, and class variables will not be reset. Use HotSwap to modify the logic of class methods. In most cases you cannot use HotSwap to make more substantial changes, such as adding or removing fields or methods.
Today's Web application developers expect to make changes to a deployed application and see those changes immediately by refreshing the browser. On the Java EE side, developers typically have to go through the following cycle to see their changes in action.
Edit -> Build -> Deploy -> Test
These steps, along with the many required descriptor elements, makes developing applications with Java EE seem complex and top-heavy. Among these steps, the build and deploy cycles are necessitated by Java and by the application server being employed. IDEs are trying to make the edit and build steps seamless by providing incremental compilation support. On the server side, the WebLogic Server FastSwap deployment feature, available in JDeveloper, makes the deploy and test cycles just as seamless.
Java EE 5 introduced the ability to redefine a class at run time without dropping its classloader or abandoning existing instances. This allowed containers to reload altered classes without disturbing running applications, vastly speeding up iterative development cycles and improving the overall development and testing experiences. The usefulness of the Java EE dynamic class redefinition is severely curtailed, however, by the restriction that the shape of the class – its declared fields and methods – cannot change. The purpose of FastSwap is to remove this restriction in WebLogic Server, allowing the dynamic redefinition of classes with new shapes to facilitate iterative development.
With FastSwap, Java classes are redefined in-place without reloading the classloader, thereby having the decided advantage of fast turnaround times. This means that you do not have to wait for an application to redeploy and then navigate back to wherever you were in the Web page flow. Instead, you can make your changes, auto compile, and then see the effects immediately.
The following application configurations are supported when using FastSwap deployment:
FastSwap is only supported when WebLogic Server is running in development mode. It is automatically disabled in production mode.
Only changes to class files in exploded directories are supported. Modifications to class files in archived applications, as well as archived JAR files appearing in the application's classpath are not supported. Examples are as follows:
When a Web application is deployed as an archived WAR within an EAR, modifications to any of the classes are not picked up by the FastSwap agent.
Within an exploded Web application, modifications to Java classes are only supported in the WEB-INF/classes
directory; the FastSwap agent does not pick up changes to archived JARs residing in WEB-INF/lib
To enable FastSwap in your application, create an Oracle WebLogic deployment descriptor weblogic-application.xml
and enable Fast Swap.
FastSwap can also be enabled for a standalone Web application by creating the WebLogic deployment descriptorweblogic.xml
and enabling Fast Swap.
The following steps describe how the FastSwap deployment process works:
Once FastSwap is enabled at the descriptor level, an appropriate classloader is instantiated when the application is deployed to WebLogic Server.
Open a browser to see the application at work. Modify (add/edit/delete) the methods and/or classes (see Limitations When Using FastSwap) and then compile them.
Note that the FastSwap agent does not compile Java files.
Refresh the browser or send a new request to the application.
The FastSwap agent tries to find all classes that have been modified since the last iteration by looking at all directories in the classpath. Considering an exploded application with a single Web application, the following directories are examined for any class file modifications based on their timestamps:
ExampleApp/APP-INF/classes ExampleApp/webapp/WEB-INF/classes
The FastSwap agent redefines the modified classes in the application and then serves the request.
FastSwap is supported with POJOs (JARs), Web applications (WARs) and enterprise applications (EARs) deployed in an exploded format. FastSwap is not supported with resource adapters (RARs).
The following types of changes are supported with FastSwap:
Addition of static methods
Removal of static methods
Addition of instance methods
Removal of instance methods
Changes to static method bodies
Changes to instance method bodies
Addition of static fields
Removal of static fields
Addition of instance fields
Removal of instance fields
The following table lists detailed change types supported with FastSwap:
Table 12-3 Supported Application Types and Changes
Scope | Java Change Type | Supported | Notes |
Java Class |
Add method |
Yes |
Addition of the |
Instance (non-abstract) |
Remove method |
Yes |
Addition of the |
a) Add field |
Yes |
b) Remove field |
Yes |
c) Change method body |
Yes |
d) Add constructor |
Yes |
e) Remove constructor |
Yes |
f) Change field modifiers |
Yes |
g) Change method modifiers |
Yes |
Class-level (static) |
Add method |
Yes |
Remove method |
Yes |
Change body method |
Yes |
Class Hierarchy Changes |
Change list of implemented interfaces |
No |
Change extends "SuperClass" |
No |
Abstract Java Class |
Add abstract method |
Yes |
Delete abstract method |
Yes |
All other supported changes (a–g) listed in |
Yes |
"final" Java Class |
Same supported changes (a–g) listed in |
Yes |
"final" Java Method |
Yes |
"final" Java Field |
Yes |
Enum |
Add constants |
No |
Remove constants |
No |
Add/remove methods |
No |
Anonymous Inner Class |
Add/remove fields |
NA |
Not supported by the Java language |
No |
Static Inner Class |
Yes |
Member Inner Classes (non-static inner classes) |
Yes |
Local Inner Classes |
Yes |
Java Interface |
Add method |
Yes |
Java Reflection |
Access existing fields/methods |
Yes |
Access new methods |
No |
New methods are not seen using Reflection and some synthetic methods are exposed. |
Access new fields |
No |
New fields are not seen using Reflection. |
Annotations on Classes |
Add or remove method/field annotations |
No |
Annotation Type |
Add or remove methods/attributes |
No |
Exception Classes |
Yes |
EJB Interface |
No |
Changes to EJB interfaces involve Reflection, which is not fully supported. |
EJB 3.0 Session/MDB EJB Implementation Class |
No |
Any support classes referenced by the EJB classes can be modified. |
Add/remove fields |
No |
EJB 3.0 EntityBean |
No |
Add/remove fields |
No |
EJB Interceptors |
No |
Add/remove fields |
No |
The following limitations apply when using FastSwap deployment:
Java reflection results do not include newly added fields and methods and include removed fields and methods. As a result, use of the reflection API on the modified classes can result in undesired behavior.
Changing the hierarchy of an already existing class is not supported by FastSwap. For example, either a) changing the list of implemented interfaces of a class; or b) changing the superclass of a class, is not supported.
Addition or removal of Java annotations is not supported by FastSwap, since this is tied to the reflection changes mentioned above.
Addition or removal of methods on EJB Interfaces is not supported by FastSwap since an EJB Compilation step is required to reflect the changes at run time.
Addition or removal of constants from Enums is not supported.
Addition or removal of the finalize method is not supported.
When you change a field name, the object state is not retained. This type of change occurs as follows: the field with the old name is deleted and a field with the new name is added. As such, any state in the old field is not carried over to the renamed field. You should expect an instance value to be reset when you change a field name.
When FastSwap is enabled, after you recompile a class, FastSwap attempts to redefine classes in existing classloaders. If redefinition fails because your changes fall outside the scope of supported FastSwap changes, the JVM throws an UnsupportedOperationException
in the Log window and in the server log file. Your application will not reflect the changes, but will continue to run.
To implement your changes, you can redeploy the application or affected modules (partial redeploy), depending on the application type and the extent of your changes.
JDeveloper allows you to debug with breakpoints using the ADF Declarative Debugger. If an error cannot be easily identified, you can use the ADF Declarative Debugger in JDeveloper to set breakpoints. When a breakpoint is reached, the execution of the application is paused and you can examine the data that the Oracle ADF binding container has to work with, and compare it to what you expect the data to be. Depending on the types of breakpoints, you may be able to use the step functions to move from one breakpoint to another.
Table 12-4 contains the windows that JDeveloper provides for debugging ADF components.
Table 12-4 ADF Component Debugging Windows
ADF Data |
Displays relevant data based on the selection in the ADF Structure window when the application is paused at a breakpoint. For more information, see How to Use the Data Window. |
EL Evaluator |
Evaluates EL Expressions when a breakpoint is reached during a debugging session. Only JSF applications can use the EL Evaluator. |
ADF Structure |
Displays a tree structure of the ADF runtime objects and their relationships when the application is stopped at a breakpoint. For more information, see Structure Window . |
You can control what type of information is displayed in each of the debugger windows. To see what options are available in each window such as which columns to display, right-click in a window and choose Preferences from the context menu. Or, you can choose Tools > Preferences from the main menu and expand the Debugger node to display a preferences page for each debugger window. You can also save the debug information as text or HTML output file. For more information. see How to Export Debug Information to a File.
To use the JDeveloper debugger to control the execution of a program:
When finished, you can modify program values as a way to test hypothetical bug fixes during a program run. If you find that a modification fixes a program error, exit the debugging session, fix your program code, and recompile the program to make the fix permanent.
JDeveloper allows you to control how your program is debugged, including enabling and disabling packages and classes and configuring remote debugging options.
To configure debugger and remote debugger options in JDeveloper:
By setting up the debugger start option, you are specifying how you would like the debugger to behave when you start a new debugging session. Specifically, decide if you want the debugger to execute until a breakpoint is reached, or if you want the debugger to stop when it reaches your project's code (for example, at the beginning of your application's main method).
To set the debugger start options:
You can press F7 to display a choice of methods you want to step into. When there are multiple methods, they are highlighted when you press F7. You can click the one you want to step into.
This feature is useful there can be multiple method calls on a line, and you may be interested in a specific one that might not be the first one encountered.
You must build the project before debugging it. The project is built using options you specify on the Compiler page of the Project Properties.
To build a project and start the debugger:
If the project builds successfully, the debugger starts.
You can export debug information generated by the JDeveloper debugger to either a text or HTML output file from within any of the debugger windows.
To export debug information to a file:
.html
or .htm
(case-insensitive).When the debugger stops (for example, at a breakpoint after completing a step command, or when paused), the source file for the current class will open in the source editor and will be marked with the execution point, as shown in Figure 12-1.
Figure 12-1 Execution Point Icon
If JDeveloper cannot locate the source file for the class while debugging, the Source Not Found dialog is displayed prompting you for the source file location.
You can use the source editor to debug to:
Hover over a variable name to see its value.
Set a breakpoint, click in the source editor's margin.
Remove a breakpoint, click the breakpoint in the source editor's margin.
Figure 12-2 Breakpoint Icon
The debugger adds several menu items to the source editor's context menu, including those shown in Table 12-6.
Table 12-6 Debugger Context Menu Items
Item | Function |
Run to Cursor |
Run to the current location of the cursor and execute the code until it reaches that location. |
Watch (Ctrl+F5) |
Add an expression to the Watches Window. |
Inspect |
Open up a floating Inspector window. |
Step Into Method at Cursor |
Executes Run to Cursor, and then steps into the method that the cursor is currently on. |
The debugger displays tooltips in the source editor if you hover the mouse over the name of a data item. By default, the tooltip will show the name, value, and type of the data item; providing an easy way to quickly inspect a data item without adding it in Data window or Watches window. If the data item is an array or object, you can inspect children of the selected item deep in the object hierarchy. The tooltip displays 20 children data items, use the navigation buttons to view remaining data items.
The columns that display in the tooltip depend on the column settings that were enabled in the Tools > Preferences – Debugger – Tooltip page.
Java expressions are used in the Watches window, Inspector window, Breakpoint Conditions, and Breakpoint Log Expressions. You can specify a Java expression that you want the debugger to watch or inspect. The expression must be a legal Java expression that the debugger can evaluate. The debugger accepts Java expressions in the forms shown in Table 12-7.
Table 12-7 Java Expressions Accepted by Debugger
Java Expression | Form |
Simple variable name |
Field access |
Method call |
Array element |
Array length |
Comparison operation |
Arithmetic operation |
Logical operation |
Instance of operator |
Shift operator |
Binary Operator |
Question-colon operation |
Static field name |
Fully qualified class name |
j |
The JDeveloper debugger lets you control the execution of your program; you can control whether your program executes a single line of code, an entire method, or an entire program block. By manually controlling when the program should run and when it should pause, you can quickly move over the sections that you know work correctly and concentrate on the sections that are causing problems. For more information, see How to Set the Debugger Start Options.
The debugger lets you control the execution of your program by:
Stepping into a method
Stepping over a method
Controlling which classes are traced into
Locating the execution point for a thread
Running to the cursor location
Pausing and resuming the debugger
Terminating a debugging session
The Step Into and Step Over commands offer the simplest way of moving through your program code. While the two commands are very similar, they each offer a different way to control code execution.
The smallest increment by which you step through a program is a single line of code. Multiple program statements on one line of text are treated as a single line of code – you cannot individually debug multiple statements contained on a single line of text. The easiest approach is to put each statement on its own line. This also makes your code more readable and easier to maintain.
The Step Into command executes a single program statement at a time. If the execution point is located on a call to a method, the Step Into command steps into that method and places the execution point on the method's first statement.
A warning dialog appears if you attempt to step into a line with multiple methods. Currently there is no way to turn this warning back on if you turn it off.
The Step Into action will highlight methods on a line any time it is invoked on a line with multiple methods. The current execution point determines what line of code the debugger will step into. Moving the cursor does not alter the execution point or cause a different set of methods to become available to step into.
This feature is particularly useful when a selected outer method belongs to an interface and you do not know beforehand where the method that will actually get called is implemented.
If the execution point is located on the last statement of a method, choosing Step Into causes the debugger to return from the method, placing the execution point on the line of code that follows the call to the method you are returning from.
The term single stepping refers to using Step Into to run successively though the statements in your program code.
You can step into a method in any of the following ways:
Select Run > Step Into.
Press the F7 key.
Click the Step Into button from the toolbar.
Figure 12-3 Step Into Button
Step Into will only cause stepping on an already-started debugging process.
When you set the debugger to start by stepping into, the debugger will let the program you are debugging execute until a method in a tracing-enabled class is reached.
As you debug, you can step into some methods and step over others. If you are confident that a method is working properly, you can step over calls to that method, knowing that the method call will not cause an error. If you are not sure that a method is well behaved, step into the method and check whether it is working properly.
The Step Over command, like Step Into, enables you to execute program statements one at a time. However, if you issue the Step Over command when the execution point is located on a method call, the debugger runs that method without stopping (instead of stepping into it), then positions the execution point on the statement that follows the method call.
If the execution point is located on the last statement of a method, choosing Step Over causes the debugger to return from the method, placing the execution point on the line of code that follows the call to the method you are returning from.
Select Run > Step Over.
Press the F8 key.
Click the Step Over button on the toolbar.
Figure 12-4 Step Over Button
Unlike previous releases of JDeveloper, you cannot start debugging by clicking the Step Over button. Step Over will cause stepping only on an already-started debugging process.
When you set it to start by stepping over, the debugger will let the program you are debugging execute until a method in a tracing-enabled class is reached, but it will not stop in class static initializer method.
As you debug, you can step into some methods and step over others. If you are confident that a method is working properly, you can step over calls to that method, knowing that the method call will not cause an error. If you aren't sure that a method is well behaved, step into the method and check whether it is working properly.
Normally, you should set the tracing include and exclude lists in the project properties before you start debugging. However, if you need to change the tracing include and exclude lists, you can do so from the Classes window. Right-click in the Classes window and choose Tracing from the context menu. The Tracing dialog appears in which you can adjust the tracing include and exclude lists.
When you specify a package to be included or excluded from tracing, all descending classes within that package are included or excluded as well unless you've specified them individually.
To closely examine part of your program, you can enable tracing on only the files you want to step through in the debugger. For example, you usually don't want to step through classes that are in the J2SE library because you're not going to troubleshoot on them; you usually only want to trace into your own classes.
If you exclude a class or package, and you instruct the debugger to step into that class, the debugger runs straight through that code without pausing. The debugger pauses at the next line of code in a class which has not been excluded. The tracing include and exclude lists are used for all step commands including Step Into, Step Over, Step Out, and so on. Using these lists does not prevent you from setting a breakpoint in a class which has been excluded. If the debugger stops at such a breakpoint, the step commands will be disabled. To enable tracing for a class, you can adjust the tracing include or exclude list by adding or removing a class or package:
To adjust the tracing include or exclude list:
By leaving the include lists blank, you are actually specifying that you would like to enable tracing in all packages except for those specifically listed in the exclude list. For example:
include: exclude:java;javax
When you're debugging, the line of code that is the current execution point for the current thread is highlighted and the execution point icon appears in the left margin of the source editor.
The execution point marks the next line of source code to be executed by the debugger.
To find the current execution point:
When stepping through your application code in the debugger, you may want to run to a particular location without having to single step or set a breakpoint.
To run to a specific program location:
Any of the following conditions may result:
When you run to the cursor, your program executes without stopping, until the execution reaches the location marked by the text cursor in the source editor.
If your program never actually executes the line of code where the text cursor is, the Run to Cursor command will cause your program to run until it encounters a breakpoint or when your program finishes.
You can pause your program when the program is running in the debugger. You can then use the debugger to examine the state of your program with respect to this program location. When you have finished examining that part of the program, you can then continue running the program.
When you are using the debugger, your program can be in one of two possible states: running, or paused by the debugger. When your program is waiting for user input, it is still considered to be running. When your program is in the running mode, Pause is available. When your program is paused by the debugger, the available debugger buttons include Resume, Step Over, and Step Into.
You can pause the debugger in the following ways:
Choose Run > Pause from the main menu.
Click the Pause icon from the debugger toolbar.
Figure 12-5 Pause Icon
Your program may be paused at a location for which there is no source available. In this case, the Source Not Found dialog displays, prompting you for the source file location or whether to generate stub files.
Also, your program may be paused at a location where tracing is disabled because the class is on the tracing exclude list. For example, your program may be paused in the java.lang.Object.wait
method.
While the debugger is paused, you can force garbage collection to occur. The results of the garbage collection are immediately reflected in the Classes and the Heap window. This enables you to find memory leaks in your application.
To resume the debugger when it is paused, choose Run > Resume.
Sometimes while debugging, you will find it necessary to restart the program from the beginning. For example, you might need to restart the program if you step past the location of a bug.
To terminate the current debugging session:
Choose the Run > Terminate - <target> menu option, or
Click Terminate in the debugger toolbar.
Terminating a debugging session closes all debugger windows. However, this action does not delete any breakpoints or watches that you have set, which makes it easy to restart a debugging session.
The Debugger log displays information about the debugging process. You can view the Debugger log at any time while the debuggee process is still active.
To view the Debugger log while the process is still active:
Select Window > Debugger > Log
In the Processes window, right-click the process and select View Log in the context menu.
JDeveloper provides a number of special-purpose debugging windows to help you analyze your code and identify problem areas. You can control what type of information is displayed in each of the debugger windows. To see what options are available in each window such as which columns to display, right-click in a window and choose Preferences from the context menu. Or, you can choose Tools > Preferences from the main menu and expand the Debugger node to display a preferences page for each debugger window. You can also save the debug information as text or HTML output file.
You open a Debugger window by setting a breakpoint and starting a debugging session. When the Debugger stops at the breakpoint, select Window > Debugger > deubugger_window. For example, Window > Debugger > Threads. You can access the Breakpoints windows by simply starting a debugging session (it is also accessible from Window > Breakpoints)
Select one of the following Debugger windows depending on the information you want to see: Classes, Heap, Data, Log, Monitors, Stack, Smart Data, Threads, and Watches. See the following sections for information on using these windows.
Information about set breakpoints can be viewed in the Breakpoints window. For more information about this window including its context menu options, press F1 in the Breakpoints window.
To open the Breakpoints window to display a list of set breakpoints:
Choose Window > Breakpoints from the main menu. The Breakpoints window appears.
You use the Data window to display information about variables in your program. In the current context, which is controlled by the selection in the Stack window. If you move to a new context, the Data window is updated to show the data for the new context. If the current class was compiled without debug information, you will not be able to see the local variables. The debugger analyzes the local variable memory locations in the stack frame to show you as much information as possible.
The Data window also displays the current return value of a non-void method when you set a breakpoint in the method and issue a Step to End of Method command or Step Out command. The return value is not displayed for Step Over or Step Into commands.
Unlike the Data window which displays all arguments, local variables, and static fields for the current method, the Smart Data window displays only the data that appears to be relevant to the source code that you are stepping through. Specifically, the debugger analyzes the source code near the execution point and finds the variables, fields, and expressions, that are used in the lines of code that you are stepping through.
For more information, see How to Locate the Execution Point for a Thread.
The Smart Data window also displays the current return value of a non-void method when you set a breakpoint in the method and issue a Step to End of Method command or Step Out command. The return value is not displayed for Step Over or Step Into commands.
By default, the debugger analyzes only one line of code for each location and analyzes up to two locations. You can adjust these settings in the Tools > Preferences - Debugger - Smart Data page which you can also access by right-clicking in the Smart Data window and choosing Preferences from the context menu.
A watch enables you to monitor the changing values of variables or expressions as your program runs. After you enter a watch expression, the Watches window displays the current value of the expression. As your program runs, the value of the watch changes as your program updates the values of the variables in the watch expression.
A watch evaluates an expression according to the current context which is controlled by the selection in the Stack window. If you move to a new context, the expression is reevaluated for the new context. If the execution point moves to a location where any of the variables in the watch expression are undefined, the entire watch expression becomes undefined. If the execution point returns to a location where the watch expression can be evaluated, the Watches window again displays the value of the watch expression.
You can add a watch to an expression in the source editor.
To add a watch from the Source Editor:
You can also add a watch in the following ways:
Right-click an item in the Data window and choose Watch from the context menu.
Drag and drop variables, fields, and objects from the Data window to the Watches window.
To watch a static field:
Enter the full name of the class followed by a period (.) and the name of the field. For example:
java.io.File.separator
To watch the current exception while stopped at an exception breakpoint, enter:
_throw
You can edit a watch by selecting its expression in the Watches window.
To edit a watch:
The Inspector window enables you to single out a selected variable, field or object, and display the same information that is available in the Watch or Data windows. For more information about this window, including its context menu options, press F1 in the Inspector window.
The Inspector window is slightly different from the other windows in that it floats by default, and you can have multiple instances of Inspector windows. Each Inspector window contains one data item. You can drag one Inspector window into another and dock them together.
To open the Inspector Window:
The Inspector window will appear floating in the center of your screen, but you can dock the Inspector window with other windows. To prevent docking, press the Ctrl key while moving the window. An inspector evaluates an expression according to the current context of the Stack window. For more information, see Using the Stack Window.
If you move to a new context, the expression is reevaluated for the new context. If the execution point moves to a new location where any of the variables in the expression are undefined, the entire expression becomes undefined. If the execution point returns to a location where the expression can be evaluated, the inspector again displays the value of that expression.
The Heap window displays information about the heap in the program you are debugging and helps you to detect memory leaks in your program. You can view all instances of a class as well as why an object has not been garbage collected.
Two types of folders display in the Heap window:
Class Folder
Displays the name of the class and how many instances of the class exist in memory, and when expanded lists the specific instances and their addresses in the heap.
Reference Path Folder
Contains all the "root" references which point, either directly or indirectly, to a specific object. Root references are static fields, stack variables, pinned objects. The garbage collector will not discard an object if there are any root references. Expanding a root reference will show you the reference path from the root reference to the specified object.
To use the Heap window:
Right-click in the Heap window and choose Add New Type from the context menu. Alternatively, drag a class node from the Classes window into the Heap window. Or, right click on a class node in the Classes window and choose Display in Heap from the context menu. Information about the classes appears in the Heap window.
The Stack window displays the call stack for the current thread. When you highlight a line in the Stack window, the Data window, Watches window, and all Inspector windows are updated to show data for the highlighted method.
In the Stack window, you can highlight a line in the stack thread to update values in the Data, Watches, and Inspector windows.
The Classes window displays which classes have been loaded and may also include useful information, such as the number of instances of a class and how much memory that number of instances requires. In conjunction with the Classes window, the debugger also includes a garbage collection tool when you want to force a run of the Java garbage collector. When you run the garbage collector, the impact is shown immediately in the Classes window. You can only force a run of the garbage collector when you are using a virtual machine that allows the debugger to do so.
You can change the order in which items in each column of the Classes Window displays.
To change the ascending or descending view order:
Click at the top of a column to change the sort order. You can sort by:
Name
Count
Memory
File
If the Show Packages check box is selected, by default the classes display in a tree structure, where each branch represents a package. Also, the icon and entry next to each class or package indicates whether the class is included or excluded from tracing. The special icon shown in Figure 12-6 for a class without line number tables is used for classes to indicate that tracing is not possible because the class has been stripped or obfuscated.
Figure 12-6 Icon Indicating Tracing Is Not Possible
In the Classes window, choose Preferences from the context menu to select which columns to view from the following available options:
Count
Memory
File
Java supports multithreading at the language level through the use of synchronization. Synchronization is the coordinating of activities and data access among multiple threads. The mechanism that Java uses to support synchronization is the monitor. The Monitors window displays status and control information for active monitors.
The Monitors window will also open automatically if the debugger is in a deadlock state.
The Threads window displays the names and status of all the threads and thread groups in your program. The columns that display in this window depend on those column settings that are enabled in the Tools > Preferences > Debugger > Threads page or by choosing Preferences from the Threads window context menu options which you can access by right-clicking in the Threads window
The step commands including Step Over, Step Into, and Set Next Statement apply to the current thread. To select a different thread, right-click a thread and choose Select Thread from the context menu.
When you highlight a thread in the Threads window, the Stack window is automatically updated to show the stack for the highlighted thread.
You can choose to customize various debugger window settings including the column resize mode and other options you want to display.
Tip:
If the debugger has trouble connecting to the debuggee (the program you are debugging), try increasing the connection retry setting.
To set any of the Debugger window preferences:
You can choose which columns display in each of the debugger windows. *
To specify which columns display in the window:
Right-click in the window and choose Preferences from the context menu. Under Columns, select the columns you want to be displayed in the Breakpoints window.
Or, in the window, right-click on the columns heading and select column names.
A breakpoint is a trigger in a program that, when reached, pauses program execution allowing you to examine the values of some or all of the program variables. By setting breakpoints in potential problem areas of your source code, you can run your program until its execution reaches a location you want to debug. When your program execution encounters a breakpoint, the program pauses, and the debugger displays the line containing the breakpoint in the source editor. You can then use the debugger to view the state of your program. Breakpoints are flexible in that they can be set before you begin a program run or at any time while you are debugging. Figure 12-7 displays an example breakpoint in a Java Application source file.
Figure 12-7 Breakpoint in Source Editor
Breakpoints set on comment lines, blank lines, declarations, and other non-executable lines of code are invalid and will not be verified by the debugger.
The JDeveloper debugger supports a number of different types of breakpoints:
Source breakpoints
Exception breakpoints
Method breakpoints
Class breakpoints
File breakpoints
Deadlock breakpoints
Deadlock breakpoints are useful in situations when you find it difficult to locate the source of the deadlock. When a deadlock breakpoint is encountered, the debugger halts. The deadlock breakpoint is automatically enabled when you start debugging.
While debugging, you can place a breakpoint to the left of any line of code in the source editor. However, for a breakpoint to be valid, it must be set on an executable line of code. Before a method is first executed, the debugger verifies all valid breakpoints in the method. Breakpoints set on comment lines, blank lines, declarations, and other non-executable lines of code are invalid and will not be verified by the debugger.
When a breakpoint has been verified as valid, the icon displayed in the source editor margin and in the Breakpoints window changes to the icon shown in Figure 12-8.
Figure 12-8 Verified Breakpoint Icon
A deadlock occurs when one or more threads in your program are blocked from gaining access to a resource or waiting on a condition that cannot be satisfied. A common deadlock in Java is a monitor block cycle deadlock.
A monitor block cycle deadlock occurs when two or more threads are unable to proceed because each is waiting to enter synchronized code that one of the others has already entered.
The following example shows a typical Java synchronization deadlock:
synchronized (a) { ... synchronized (b) { ... } ... }
At the same time, thread 2 is executing the following code:
synchronized (b) { ... synchronized (a) { ... } ... }
A deadlock will occur if thread 1 enters the synchronized (a)
as thread 2 enters the synchronized (b)
. Thread 1 will be blocked from entering synchronized (b) until thread 2 finishes the synchronized (b)
and thread 2 will be blocked from entering synchronized (a) until thread 1 finishes the synchronized (a). A deadlock is also called a "deadly embrace." This example is for two threads but the same situation could occur for 3, 4, 5, and so on threads. The deadlock breakpoint can detect this type of deadlock.
Another kind of deadlock is where one thread calls the wait method on a particular object and no other threads call the notify method on that object. The most common cause of this kind of deadlock is timing. The notifying thread may have called notify before the waiting thread called wait. The important thing to know about calling wait is that even if notify was already called many times before, the wait method waits until notify is called again. Also, notify doesn't return any kind of error if there was no thread waiting. The deadlock breakpoint cannot detect this type of deadlock.
If you think your program is hanging, click Pause to pause your program in the debugger, and open the Monitors window. Perhaps you can see that one thread is waiting, investigate the code. If you can see that another thread probably called notify before the first thread called wait, there is a deadlock. This kind of deadlock is very hard to detect. You must know your code well in order to figure out which other thread should have called notify.
The JDeveloper debugger sets a persistent deadlock breakpoint when it starts running. A deadlock breakpoint is useful in situations when you find it difficult to locate the source of the deadlock. When the debugger encounters a deadlock breakpoint, the debugger halts. It can detect a monitor block cycle deadlock as described above. The Monitors window can be useful when working with deadlocks.
The deadlock breakpoint has the following characteristics:
It is a persistent breakpoint that is created automatically when you use JDeveloper.
It cannot be deleted, but it can be disabled.
It pauses the debugger if a monitor block cycle deadlock is detected. A monitor block cycle deadlock occurs when two or more threads are unable to proceed because each is waiting to enter synchronized code that one of the others has already entered.
The JDeveloper debugger automatically creates a persistent deadlock breakpoint; this breakpoint will occur whenever a monitor block cycle is detected. You cannot delete a persistent breakpoint. You cannot create a new deadlock breakpoint, but you can edit the existing persistent deadlock breakpoint.
Not all Java Virtual Machines support deadlock detection; for example, the HotSpot VM does not support deadlock detection.
Grouped breakpoints let you enable a set of breakpoints. When the debugger reaches a certain point in your code, you can instruct the debugger to enable a breakpoint or a group of breakpoints that was previously disabled.
For example, even though your code might be catching a NullPointerException
, it may not be behaving correctly. In some cases, NullPointerExceptions
occur more frequently than expected which causes the debugger to stop repeatedly for NullPointerExceptions,
including those that are of no consequence to your code. This situation can be resolved by creating a breakpoint group, adding this breakpoint to the group, and disabling the breakpoint group so that the debugger does not stop at this breakpoint when debugging.
Next, you can create a source breakpoint in some code that you know is executed just before the problematic NullPointerException
is thrown. You can set the actions for this source breakpoint so that when the source breakpoint occurs, it will automatically enable the breakpoint group which contains the exception breakpoint.
JDeveloper allows you to edit the options of a breakpoint after you have added it in the source code. From the Edit Breakpoint dialog, you can:
Set a breakpoint option.
Set the threads to which the breakpoint will apply.
Set a pass count for the breakpoint.
Put the breakpoint in a breakpoint group.
Choose what actions the debugger will take when the breakpoint occurs.
To view and modify the options of a breakpoint:
You can right-click to edit a breakpoint located in the source editor. The Edit Breakpoint dialog shown in Figure 12-9 displays, where you can specify the definition of the breakpoint. In the dialog, you can edit some of the most important breakpoint attributes, such as enabled/disabled, condition and more.
Figure 12-9 Edit Breakpoints Dialog
You can also hover over a breakpoint in the source editor to display the dialog in Figure 12-9.
A source breakpoint is the most common type of breakpoint. It is set on a line of the source code and program execution is paused when it hits that line.
To set a source breakpoint, do one of the following:
In the source editor, click in the left margin next to a line of executable code.
In the source editor, right-click in the left margin next to a line of code, then choose Toggle Breakpoint (F5).
Choose Window > Breakpoints to display the Breakpoints window. Then, right-click anywhere in this window and choose Add Breakpoint from the context menu. From the submenu, select Source Breakpoint as the breakpoint type, then complete the package, source file name, and line number information in the dialog. The source filename should not include any directory information, but must include the extension of the file. For example:
Application1.java or MyWebApp.jsp
You might want to set a least one breakpoint before you start debugging, but it is not necessary. While your program is running in the debugger, you can set a breakpoint. The program pauses when it reaches the breakpoint.
You can control how the debugger behaves when a breakpoint occurs.
To control how the debugger behaves when a breakpoint occurs:
When you no longer need to examine the code at a breakpoint location, you can delete the breakpoint. You can delete breakpoints either using the source editor or in the Breakpoints window.
To delete a breakpoint, do one of the following:
In the left margin of the source editor, click the breakpoint you want to delete.
In the left margin of the source editor, right-click the breakpoint you want to delete, and choose Toggle Breakpoint.
In the source editor, place the cursor in the line of code containing the breakpoint, and press F5.
To delete all currently set breakpoints, right-click in the Breakpoints window and select Delete All.
Select the breakpoint in the Breakpoints window and click Delete Breakpoint on the toolbar.
Caution:
You cannot undelete a breakpoint.
When you disable a breakpoint, all the breakpoint settings remain defined, but the breakpoint is not triggered when your program is run; your program will not stop on a disabled breakpoint. Disabling a breakpoint is useful if you have defined a breakpoint that you don't need to use now, but might need to use at a later time.
To disable a breakpoint, do one of the following:
In the source editor, right-click the breakpoint symbol in the left margin and choose Disable Breakpoint.
In the Breakpoints window (Window > Debugger > Breakpoints) right-click the breakpoint you want to disable and choose Disable.
To disable a group of breakpoints in the Breakpoints window, select the group that you want to disable, right-click and choose Disable Group.
You can also disable breakpoints from the Breakpoint toolbar. Select the breakpoint or breakpoint group, and click Disable on the toolbar.
To disable all current breakpoints, right-click in the Breakpoints window, and choose Disable All from the context menu.
You can reenable a disabled breakpoint.
To reenable a disabled breakpoint:
To enable a breakpoint that is disabled, right-click the disabled breakpoint symbol (or entry in the Breakpoints window), and choose Enable.
To enable all breakpoints that have been set, right-click in the Breakpoints window, and choose Enable All.
To enable a group of breakpoints, right-click a breakpoint group in the Breakpoints window, and choose Enable Group.
You can also enable breakpoints from the Breakpoint toolbar. Select the breakpoint or breakpoint group, and click Enable on the toolbar.
Breakpoints typically have effect whenever they are reached. An instance breakpoint is associated with a specific instance of the class that defines the method where the breakpoint appears.
An instance breakpoint is a source breakpoint that has been associated with an instance filter that identifies the selected instances. Instance breakpoints do not persist between runs of the debugger. Instance filters are shown in the Instance Filters column of the Breakpoints window.
To set an instance breakpoint:
Breakpoints are typically attached to a particular line of code; they pause the debugger when a particular line of code is about to be executed. In addition, you can set a breakpoint to be activated when a certain type of exception is thrown. Exception breakpoints are not associated with a particular line of code.
To set an exception breakpoint:
The debugger will now pause if an exception of the specified type is thrown.
By default, the debugger automatically creates a persistent exception breakpoint for uncaught throws for java.lang.Throwable
. This breakpoint will occur whenever an uncaught exception is thrown. You cannot delete a persistent breakpoint, although you can disable it.
When you make a breakpoint conditional, the debugger pauses when a certain condition is met. When a breakpoint is first set, the debugger pauses the program execution each time the breakpoint is encountered. However, using the Edit Breakpoints dialog, you can customize breakpoints so that they are activated only in certain conditions.
The Conditions tab in the Edit Breakpoint dialog is where you enter an expression that is evaluated each time the debugger encounters the breakpoint while executing the program. If the expression evaluates to true, then the breakpoint pauses the program. If a breakpoint condition cannot be evaluated, the debugger will stop at the location as if it was an unconditional breakpoint.
When the debugger stops at a line with a conditional breakpoint, a ghost window appears next to the breakpoint icon showing the breakpoint condition. If the debugger stopped because the condition was true, the condition is shown with a green checkmark icon; if it stopped because the condition could not be evaluated, the condition will be shown with a question mark icon.
For example, suppose you want a breakpoint to pause on a line of code only when the variable mediumCount
is greater than 10.
To set a breakpoint condition:
mediumCount > 1
You can enter any valid Java language expression in the Edit Breakpoint dialog, but all symbols in the expression must be accessible from the breakpoint's location, and the expression cannot contain any method calls. For an exception breakpoint, you may want to use the exception object in your condition by using _throw
You can also right-click a breakpoint located in the source editor to set conditions. Or, with your mouse cursor, hover over a breakpoint icon in the gutter of an editor window. For more information, see Editing a Breakpoint..
The Pass Count field specifies the number of times that a breakpoint must be passed for the breakpoint to be activated. Pass counts are useful when you think that a loop is failing on the nth iteration. The debugger pauses the program the nth time that the breakpoint is encountered during the program run. The default value is 1.
If the Pass Count column is shown in the Breakpoints window, you can see the pass count value decrement each time the breakpoint line of code is encountered during the program execution. If the pass count equals 1 when the breakpoint line is encountered, the breakpoint is activated, and the program pauses at that line.
When pass counts are used together with breakpoint conditions, the breakpoint pauses the program execution the nth time that the condition is true
; the condition must be true for the pass count to be decremented.
To see the list of breakpoints, choose Window > Debugger > Breakpoints from the main menu. Breakpoints that have been verified as valid by the debugger are indicated by the icon shown in Figure 12-8. You can use the Breakpoints window to quickly find the breakpoint location in your source code.
To use the Breakpoints window to locate a breakpoint in the source editor:
You can enable or disable several breakpoints with a single action, by creating a breakpoint group and putting breakpoints into it. Once you've created a breakpoint group, you can enable, disable, or remove it like a single breakpoint.
You create a breakpoint group by first creating a breakpoint, then editing it to create a breakpoint group. This enables all the breakpoints contained in the selected group. When a breakpoint is enabled, it means that the conditions and actions are executed when the breakpoint is encountered.
To create a breakpoint group:
To move a breakpoint, you can either drag-and-drop it into the breakpoint group, or follow these steps.
To move a breakpoint into a breakpoint group:
To enable, disable, or remove a breakpoint group, in the Breakpoints window, right-click a breakpoints group, and choose Enable Group, Disable Group, or Delete Group from the context menu.
You can also enable or disable a group from the Breakpoint toolbar. With the group name selected in Breakpoints window, click the Enable or Disable icon on the toolbar. All the breakpoints of the selected group will be enabled or disabled.
Even though you can view your program by running and stepping through it, you usually need to examine the values of program variables to uncover bugs. For example, it is helpful to know the value of the index variable as you step though a loop, or the values of the parameters passed in a method call. When your program is paused in the debugger, you can examine the values of variables, arguments, fields, and array items.
You can inspect and change the values of data items using the Data, Smart Data, Inspector, or Watches windows during the course of your debugging sessions.
JDeveloper also allows you to inspect a data item without adding it in Data window. When the debugger has stopped at a breakpoint in the Source Editor, hover the mouse over a data item to view the its name, value, and type. If the data item is an object or an array, you can inspect children of the selected item deep in the object hierarchy.
When you inspect a data item, you evaluate it with different expressions while your debugging session is running. You can then modify program data values as a way to test hypothetical bug fixes during a program run. If you find that a modification fixes a program error, you can exit the debugging session, fix your program code accordingly, and recompile the program to make the fix permanent.
To inspect a data item:
You can modify program data values during a debugging session as a way to test hypothetical bug fixes during a program run. If you find that a modification fixes a program error, you can exit the debugging session, fix your program code accordingly, and recompile the program to make the fix permanent.
Some object types cannot be modified while the program is running. A warning appears if you attempt to modify such an object type.
When you modify the value of a variable, the modification is effective for that specific program run only; the changes you make through the Data or Watches windows do not affect your program source code or the compiled program. To make your change permanent, you must modify your program source code in the source editor, then recompile your program.
The new value needs to be type-compatible with the variable you want to assign it to. A good rule of thumb is that if the assignment would cause a compile-time or run-time error, it is not a legal modification value.
To modify the value of a variable in the Data window:
You can modify an existing expression in the inspector window.
To modify an expression in the Inspector window:
While debugging, you can use filters to reduce the number of fields that are displayed when you expand an object in a data-related debugger window. You can perform this task in the Smart Data window, the Data window, the Inspector window, the Watches window, and the left-hand side of the Monitors window through the Object Preferences dialog. Displaying fewer fields narrows your focus when debugging and may make it easier to locate and isolate potential problems in your program.
For example, you can create filters for classes in the data windows so that the debugger displays only the fields of interest to you. This drastically reduces clutter and allows you to find the relevant data more quickly.
To show or hide fields in the filtered classes list:
In addition to debugging code locally in the JDeveloper IDE, you can also debug code which is located on a remote machine or running in a different VM instance. This means that you can use the debugger to debug code that has already been deployed. The debugger can simultaneously attach to multiple remote VMs, so you can seamlessly debug distributed applications, such as JSPs deployed to a web server accessing EJBs deployed to an application server.
The main difference between remote debugging and local debugging is how you start the debugging session. For local debugging, JDeveloper automatically launches the program you want to debug (called a debuggee process) and then attaches the debugger to that program. For remote debugging, you must manually launch the program you want to debug. Also, if you are debugging a JSP or a servlet, you must manually start a browser to invoke your JSP or servlet.
Once the debuggee is launched and the JDeveloper debugger is attached to it, remote debugging is very similar to local debugging. Remember that you can use remote debugging when the debuggee process is running on the same machine as JDeveloper or when the debuggee process is running on a different machine.
Unlike local debugging, you must choose which protocol to use before you start your remote debugging session. The remote debugging protocols are configured in Debugger - Remote page of the Edit Run Configuration dialog.
You can also debug Web pages such as JSPs or servlets using the HTTP Analyzer. For more information, see Auditing and Monitoring Java Projects.
Select Attach to JPDA to attach to the debugger application at a specified address. For more information about the Sun Java Platform Debugger Architecture (JPDA) Connection and Invocation, see http://docs.oracle.com/javase/6/docs/technotes/guides/jpda/conninv.html
Select Listen for JPDA to specify that the debugger listen for a debuggee to attach to the debugger. Also, choose this option if you are debugging remote PL/SQL programs.
After you have configured a project for remote debugging, you can start your remote debugging session by issuing the appropriate command based on the debugging protocol and the environment.
To start the Java process, enter the following at the command line:
java [-client|server] -cp <project_directory>\classes -agentlib:jdwp,<option1>[=<value1>],<option2>[=<value2>]... <java_main_class>
The available options are:
server(=n/y)
If set to y, then the Java process waits for a Debugger to attach. If set to n (default), the process attaches itself to the debugger application at the specified address.
address
Specifies the port for the connection. Defaults to 4000.
timeout
Time interval after which the connection attempt times out. Defaults to 2 seconds.
suspend =(y/n)
If set to y (default), the Java process runs after the debugger connects to it. If set to n, the debuggee process starts right away without waiting for the debugger to connect to it.
The options shown are applicable if you are running JDK 1.6 or later. See the documentation for the version of JDK you are running if earlier than JDK 1.6.
Command line examples:
java -cp <project_directory>\classes -agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=4000
Listen for a debugger connection on port 4000, but begin execution without waiting for the debugger. Timeout after 2s (default). Implement the Client VM (default).
java -server -cp <project_directory>\classes -agentlib:jdwp=transport=dt_socket,server=n,suspend=y,timeout=3,address=8000
Attach to a debugger connection on port 8000. Begin execution only after connecting to the debugger. Timeout after 3s. Implement the Server VM.
For more information about the Sun JPDA Connection and Invocation, see http://www.oracle.com/technetwork/java/javase/documentation/ index-jsp-135444.html
Any project can be configured to perform remote debugging.
To configure a project for remote debugging:
This section describes how to configure JDeveloper for Java Platform Debugger Architecture (JPDA) remote debugging.
To configure your project for remote debugging:
Make changes in the JSP section of global-web-application.xml as follows:
<init-param> <param-name>debug</param-name> <param-value>class</param-value> </init-param>
Start commands for Integrated WebLogic Server (make sure -server is the first parameter).
value="-server -agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=4000 -Xms512m -Xmx750m -XX:PermSize=128m -XX:MaxPermSize=256m -Djava.security.policy=$ORACLE_HOME/j2ee/home/config/java2.policy -Djava.awt.headless=true -Dhttp.webdir.enable=false"/>
To configure JDeveloper for remote debugging:
