XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the XSD Wizard > Structure of XSD XML Integration Object >
XSD Specific Integration Component Field Properties
Table 13 lists the integration component field property for representing XSD as an XML integration component.
Table 13.  Integration Component Field Properties for Representing XSD
Name
Data Type
Length
External Name
External Length
XML Literal Value
XML Tag
DTYPE_TEXT
maxLength or length
Attribute or element name
Length
fixed or default
