XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the XSD Wizard > Structure of XSD XML Integration Object > XSD Specific Integration Component User PropertiesTable 12 lists integration component user properties for representing XSD as an XML integration component. |
XML Reference: Siebel eBusiness Application Integration Volume V |
