1 Introduction to JD Edwards EnterpriseOne Transportation Management
This chapter contains the following topics:
1.1 JD Edwards EnterpriseOne Transportation Management Overview
The JD Edwards EnterpriseOne Transportation Management system is the element of the supply chain process that is responsible for moving goods and materials. The movement of raw materials, components, and finished products, from supplier to manufacturer to distribution center to the customer, represents a significant percentage of the final cost of the product. The ability to track these goods while in transit is a part of providing quality service to the customer. The JD Edwards EnterpriseOne Transportation Management system provides features that enable companies to significantly reduce costs. Hence, transportation management is a vital aspect of any product manufacturing and distribution business.
1.2 JD Edwards EnterpriseOne Transportation Management Implementation
This section provides an overview of the steps that are required to implement the JD Edwards EnterpriseOne Transportation Management system.
In the planning phase of implementation, take advantage of all JD Edwards EnterpriseOne sources of information, including the installation guides and troubleshooting information.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne Transportation Management, use the EnterpriseOne and World Change Assistant. EnterpriseOne and World Change Assistant, a Java-based tool, reduces the time required to search and download ESUs by 75 percent or more and enables you to install multiple ESUs simultaneously.
See JD Edwards EnterpriseOne Tools Software Updates Guide.
1.2.1 Global Implementation Steps
This table lists the suggested global implementation steps for JD Edwards EnterpriseOne Transportation Management:
  1. Set up global user-defined codes.
    See JD Edwards EnterpriseOne Tools Foundation Guide.
  2. Set up companies, fiscal date patterns, and business units.
    See "Setting Up Organizations" in the JD Edwards EnterpriseOne Applications Financial Management Fundamentals Implementation Guide.
  3. Set up next numbers.
  4. Set up accounts, and the chart of accounts.
    See "Creating the Chart of Accounts" in the JD Edwards EnterpriseOne Applications Financial Management Fundamentals Implementation Guide.
  5. Set up the General Accounting constants.
    See "Setting Up the General Accounting System" in the JD Edwards EnterpriseOne Applications General Accounting Implementation Guide.
  6. Set up multicounty processing, including currency codes and exchange rates.
    See "Setting Up General Accounting for Multicurrency Processing" in the JD Edwards EnterpriseOne Applications Multicurrency Processing Implementation Guide.
    See "Setting Up Exchange Rates" in the JD Edwards EnterpriseOne Applications Multicurrency Processing Implementation Guide.
  7. Set up ledger type rules.
    See "Setting Up Ledger Type Rules for General Accounting" in the JD Edwards EnterpriseOne Applications General Accounting Implementation Guide.
  8. Enter address book records.
    See "Entering Address Book Records" in the JD Edwards EnterpriseOne Applications Address Book Implementation Guide.
  9. Set up inventory information such as branch/plant constants, default locations and printers, manufacturing and distribution Ayes, and document types.
    See "Setting Up the Inventory Management System" in the JD Edwards EnterpriseOne Applications Inventory Management Implementation Guide.
  10. Set up shop floor calendars.
    See "Setting Up Shop Floor Management" in the JD Edwards EnterpriseOne Applications Shop Floor Management Implementation Guide.
  11. Set up order activity rules.
    See "Configuring the Sales Order Management System" in the JD Edwards EnterpriseOne Applications Sales Order Management Implementation Guide.
1.2.2 Transportation Management Implementation Steps
This table lists the suggested implementation steps for JD Edwards EnterpriseOne Transportation Management:
  1. Activate Transportation Management
    See Activating Transportation Management.
  2. Set up automatic accounting instructions
    See Setting Up Automatic Accounting Instructions.
  3. Set up the workday calendar
    See Setting Up the Workday Calendars.
  4. Set up transportation constants
    See Setting Up Transportation Constants.
  5. Set up load constants
    See Setting Up Load Constants.
  6. Set up mode of transport constants
    See Setting Up Mode of Transport Constants.
  7. Set up items
    See Setting Up Items.
  8. Set up carriers
    See Setting Up Carriers.
  9. Set up rates
    See Setting Up Rate Definitions.
  10. Set up routes
    See Setting Up Routes.
  11. Set up transportation preferences (optional)
    See Setting Transportation Preferences.
  12. Set up document control (optional)
    See Setting Up Document Control.
  13. Set up shipment tracking numbers (optional)
    See Setting Up Shipment Tracking Numbers.
  14. Set up vehicles
    See Setting Up Vehicles.
  15. Set up staff (optional)
    See Setting Up Staff.
1.3 Business Interface Integration Objects
A business interface is a set of components that implementation teams can use to create an integration between JD Edwards EnterpriseOne and an external system. Business interfaces can include one or more of these business interface components:
  • Business Services
  • Real-Time Events
  • Batch Import and Export Programs
For additional information about business interfaces, and the business objects available for this product area, see these topics in the JD Edwards EnterpriseOne Applications Business Interface Reference Guide:
