Skip Headers
JD Edwards EnterpriseOne Applications Transportation Management Implementation Guide
Release 9.1
Part Number E15152-04
Home
Book List
Index
Contact Us
Next
PDF
Mobi
ePub
Contents
List of Figures
Title and Copyright Information
Preface
Audience
JD Edwards EnterpriseOne Products
JD Edwards EnterpriseOne Application Fundamentals
Documentation Accessibility
Related Documents
Conventions and Screen Images
1
Introduction to JD Edwards EnterpriseOne Transportation Management
1.1
JD Edwards EnterpriseOne Transportation Management Overview
1.2
JD Edwards EnterpriseOne Transportation Management Implementation
1.2.1
Global Implementation Steps
1.2.2
Transportation Management Implementation Steps
2
Understanding the JD Edwards EnterpriseOne Transportation Management System
2.1
The JD Edwards EnterpriseOne Transportation Management System
2.2
System Integration
2.2.1
JD Edwards EnterpriseOne General Accounting
2.2.2
JD Edwards EnterpriseOne Address Book
2.2.3
JD Edwards EnterpriseOne Sales Order Management
2.2.4
JD Edwards EnterpriseOne Inventory Management
2.2.5
JD Edwards EnterpriseOne Procurement
2.2.6
JD Edwards EnterpriseOne Quality Management
2.2.7
JD Edwards EnterpriseOne Warehouse Management
2.3
Features of JD Edwards EnterpriseOne Transportation Management System
2.4
Terms and Concepts
2.5
Tables
3
Setting Up the System
3.1
Understanding Transportation Management
3.1.1
3.1.2
Hub Setup
3.1.3
User-Defined Codes
3.2
Activating Transportation Management
3.2.1
Understanding Transportation Management Activation
3.2.2
Forms Used to Activate Transportation Management
3.2.3
3.3
Setting Up Automatic Accounting Instructions
3.3.1
Understanding Automatic Accounting Instructions
3.3.2
Forms Used to Set Up Automatic Accounting Instructions
3.3.3
3.4
Setting Up the Workday Calendars
3.4.1
Understanding Workday Calendars
3.4.2
Forms Used to Set Up the Workday Calendars
3.4.3
Adding Workday Calendars
3.4.4
Changing Workday Defaults
3.4.5
Copying Workday Calendars
3.4.6
Setting Processing Options for Workday Calendar (P00071)
3.4.6.1
Interop
3.5
Setting Up Transportation Constants
3.5.1
Understanding Transportation Constants
3.5.2
Forms Used to Set Up Transportation Constants
3.5.3
3.5.3.1
UOM Defaults/Status Code
3.6
Setting Up Load Constants
3.6.1
Understanding Load Constants
3.6.2
Understanding Load Types
3.6.3
Forms Used to Set Up Load Constants
3.6.4
Setting Up Load Types
3.6.5
Setting Up Load Next Numbers
3.7
Setting Up Mode of Transport Constants
3.7.1
Understanding Mode of Transport Constants
3.7.2
Forms Used to Set Up Mode of Transport Constants
3.7.3
4
Setting Up Items
4.1
Understanding Item Setup
4.2
Setting Up Incompatible Items
4.2.1
Understanding Incompatible Item Setup
4.2.2
Prerequisite
4.2.3
Form Used to Set Up Incompatible Items
4.2.4
4.3
Setting Up Item Shipping Information
4.3.1
Understanding Item Shipping Information Setup
4.3.2
Prerequisite
4.3.3
Form Used to Set Up Item Shipping Information
4.3.4
4.3.5
Setting Processing Options for Item Master (P4101)
4.3.5.1
Defaults
4.3.5.2
Process
4.3.5.3
Workflow
4.3.5.4
Global Update
4.3.5.5
Versions
4.3.5.6
Interop
5
Setting Up Shipment Tracking Numbers
5.1
Understanding Shipment Tracking Numbers
5.2
5.2.1
Understanding Shipment Tracking Number Setup
5.2.2
Forms Used to Set Up Shipment Tracking Numbers
5.2.3
Defining Tracking Number Segments
5.2.4
Defining Next Numbers for Tracking Number Segments
5.2.5
Defining Separators
6
Setting Up Carriers
6.1
Understanding Carrier Setup
6.1.1
Prerequisite
6.2
Setting Up Carriers
6.2.1
Understanding Carrier Master Information Setup
6.2.2
Understanding License and Registration Information Setup
6.2.3
Forms Used to Set Up Carriers
6.2.4
Setting Up Carrier Master Information
6.2.5
Setting Up License and Registration Information
7
Setting Up Rates
7.1
Understanding Rate Setup
7.1.1
Prerequisite
7.1.2
Rates
7.1.3
Rate Setup
7.1.4
Rate Types
7.1.5
Rate Levels
7.2
Setting Up Charge Codes
7.2.1
Understanding Charge Code Setup
7.2.2
Form Used to Set Up Charge Codes
7.2.3
7.3
Setting Up Rate Definitions
7.3.1
Understanding Rate Definitions
7.3.2
Forms Used to Set Up Rate Definitions
7.3.3
Setting Up a Rate Definition
7.3.4
Defining Additional Rate Information
7.4
Setting Up Lookup Types
7.4.1
Understanding Lookup Type Setup
7.4.2
Forms Used to Set Up Lookup Types
7.4.3
Setting Up Look-Up Types
7.5
Setting Up Rate Tables
7.5.1
Understanding Rate Table Setup
7.5.2
Form Used to Set Up Rate Tables
7.5.3
7.6
Setting Up Accessorial Charges
7.6.1
Understanding Accessorial Charges
7.6.2
Form Used to Set Up Accessorial Charges
7.6.3
7.7
Setting Up Rate Parameters
7.7.1
Understanding Rate Parameters
7.7.2
Prerequisite
7.7.3
Form Used to Set Up Rate Parameters
7.7.4
7.8
Setting Up Rate Schedules
7.8.1
Understanding Rate Schedules
7.8.2
Prerequisite
7.8.3
Form Used to Set Up Rate Schedules
7.8.4
7.9
Updating Rates
7.9.1
Understanding Rate Updates
7.9.2
Updating Multiple Rates
7.9.3
Setting Processing Options for Batch Rate Update (R4972)
7.9.4
Updating Rates in Routes
7.9.5
Setting Processing Options for Batch Routing Rate Update (R4950)
8
Integrating to RateWare® XL
8.1
Understanding RateWare® XL
8.2
Setting Up Integration to RateWare® XL
8.2.1
Understanding Web Services (WSC) Callout
8.2.2
RateWare XL Processor Business Service (J4900010)
8.2.2.1
Setup Considerations
8.2.3
Forms Used to Set Up Integration to RateWare® XL
8.2.4
Setting Up Soft Coding Templates
8.2.5
Setting Up Web Service Soft Coding Records
8.2.6
Setting Up Rate Definition to Work With RateWare® XL
8.2.7
Setting Up RateWare XL Rate Constants
8.2.7.1
Discounts Tab
8.2.7.2
Surcharge Tab
9
Setting Up Routes
9.1
Understanding Routes
9.2
Setting Up Routes
9.2.1
Understanding Route Setup
9.2.2
Understanding Routing Hierarchy
9.2.3
Understanding Routing Entry Setup
9.2.4
Understanding Routing Restriction Setup
9.2.5
Understanding Carrier Zone Setup
9.2.6
Understanding Option and Equipment Rule Setup
9.2.7
Understanding Intermodal Route Setup
9.2.8
Prerequisites
9.2.9
Forms Used to Set Up Routes
9.2.10
Setting Up the Routing Hierarchy
9.2.11
Setting Up Routing Entries
9.2.12
Setting Up Routing Restrictions
9.2.13
Setting Up Carrier Zones
9.2.14
Setting Up Options and Equipment Rules
9.2.15
Setting Up Intermodal Routes
10
Setting Transportation Preferences
10.1
Understanding Transportation Preferences
10.2
Understanding How the System Uses Preferences
10.3
Understanding Preference Fields
10.4
Setting Up the Preference Master and Hierarchy
10.4.1
Understanding the Preferences Master and Hierarchy
10.4.2
Understanding Preference Hierarchy Arrangement
10.4.3
Forms Used to Set Up the Preferences Master and Hierarchy
10.4.4
Setting Up Preference Master Information
10.4.5
Arranging the Preference Hierarchy
10.5
Assigning Customers and Items to Groups
10.5.1
Understanding Customer and Item Group Assignment
10.5.2
Prerequisite
10.5.3
Forms Used to Assign Customers and Items to Groups
10.5.4
Assigning Customers to Groups
10.5.4.1
Customer Group 2
10.5.5
Assigning Items to Groups
10.5.5.1
Item Group 2
10.6
Setting Up Preferences
10.6.1
Understanding Basic Preference Setup
10.6.2
Understanding Custom Preference Types
10.6.2.1
Carrier Preference
10.6.2.2
Customer Freight Preference
10.6.2.3
Document Set Preference
10.6.2.4
Example: Document Set Preference
10.6.2.5
Mode of Transport Preference
10.6.2.6
Options and Equipment Preference
10.6.3
Understanding Advanced Preference Setup
10.6.3.1
Advanced Preference Types
10.6.3.2
Advanced Preference Details
10.6.4
Understanding Advanced Preference Schedule Setup
10.6.5
Understanding Advanced Preference Processing
10.6.5.1
How the System Processes Advanced Preferences
10.6.6
Forms Used to Set Up Preferences
10.6.7
Entering Standard Preference Information
10.6.8
Setting Up Advanced Preferences
10.6.9
Setting Up Advanced Preference Schedules
10.6.10
Setting Up Advanced Preference Details
11
Setting Up Document Control
11.1
Understanding Document Setup
11.2
Setting Up Documents
11.2.1
11.2.2
Understanding Document Next Number Setup
11.2.3
Understanding Document Printing Program Setup
11.2.4
Understanding Document Sets
11.2.5
Understanding Document Depot Information Setup
11.2.6
Forms Used to Set Up Documents
11.2.7
Setting Up Document Next Numbers
11.2.8
Setting Up Document Printing Programs
11.2.9
Setting Processing Options for Transportation Bill of Lading Build (R49110)
11.2.10
Setting Processing Options for Transportation Bill of Lading (R49115)
11.2.11
Setting Processing Options for Transportation Bill of Lading (R49118)
11.2.12
Setting Processing Options for Loading Note/Load Tender Report (R49120)
11.2.12.1
Load Status
11.2.12.2
Print Options
11.2.12.3
Print Messages
11.2.13
Setting Processing Options for Shipment Document Workfile Build (R49130)
11.2.14
Setting Processing Options for Shipment Manifest Print (R49135) and Master Bill of Lading Print (R49137)
11.2.15
Setting Processing Options for SSCC Label Workfile Build (R49140)
11.2.16
Setting Processing Options for Shipping Document Print - Loads (R49548) and Shipping Document Print - Shipments (R49549)
11.2.17
Setting Up Document Sets
11.2.18
Setting Up Document Depot Information
12
Setting Up Vehicles
12.1
Understanding Vehicle Setup
12.2
Setting Up Vehicle Information
12.2.1
Understanding Vehicle Type Setup
12.2.2
Understanding Vehicle Information Setup
12.2.3
Understanding Vehicle Dimension Setup
12.2.4
Understanding Vehicle Compartment Setup
12.2.5
Understanding Vehicle Equipment Setup
12.2.6
Prerequisite
12.2.7
Forms Used to Set Up Vehicle Information
12.2.8
Setting Up Vehicle Types
12.2.9
Setting Up Vehicle Dimensions
12.2.10
Setting Up Vehicle Compartments
12.2.11
Setting Up Vehicle Equipment
12.3
Setting Up Vehicle Maintenance Information
12.3.1
Understanding Vehicle Maintenance Information Setup
12.3.1.1
Vehicle Master Information Setup
12.3.1.2
Vehicle License Setup
12.3.1.3
Vehicle Out-of-Service Date Setup
12.3.1.4
Connected Vehicle Setup
12.3.2
Forms Used to Set Up Vehicle Maintenance Information
12.3.3
Setting Up Vehicle Master Information
12.3.4
Set Processing Options for Vehicle Master Maintenance (P4930)
12.3.5
Setting Up Vehicle Licenses
12.3.6
Setting Up Vehicle Out-of-Service Dates
12.3.7
Setting Up Connected Vehicles
13
Setting Up Staff
13.1
Understanding Staff Setup
13.1.1
Prerequisites
13.2
Setting Up Depot or Vehicle Staff
13.2.1
Form Used to Set Up Staff
13.2.2
14
Planning Transportation
14.1
Understanding Shipment Information
14.1.1
What Is a Shipment?
14.1.2
What Is a Load?
14.2
Understanding the Transportation Process Flow
14.2.1
Shipment Planning
14.2.2
Load-Building
14.2.3
Approval
14.2.4
Confirmation
14.2.5
Printing Delivery Documents
14.2.6
Delivery Confirmation
14.2.7
Freight Update
14.2.8
Freight Audit
14.3
Planning Transportation Shipments
14.3.1
Understanding Shipment Planning
14.3.1.1
Shipment Revision
14.3.1.2
Shipment Creation During Order Entry
14.3.1.3
Shipment Consolidation
14.3.1.4
Freight Quotes
14.3.1.5
Shipment Revision Information
14.3.1.6
Shipment Pieces
14.3.1.7
Kit Component Processing
14.3.1.8
Shipment Options and Equipment
14.3.1.9
Routing Options
14.3.1.10
Bypass Shipment Rating and Routing
14.3.1.11
Shipment Approval
14.3.2
Prerequisites
14.3.3
Forms Used to Plan Transportation Shipments
14.3.4
Creating Shipments During Order Entry
14.3.5
Selecting Order Lines for Shipment Consolidation
14.3.6
Removing Order Lines from a Consolidated Shipment
14.3.7
Quoting Freight in an Online Invoice
14.3.8
Revising Shipment Information
14.3.9
Defining Shipment Pieces
14.3.10
Assigning Options and Equipment to a Shipment
14.3.11
Reviewing Routing Options
14.3.12
Approving Shipments
14.3.13
Setting Processing Options for Work With Shipments (P4915)
14.3.13.1
Display
14.3.13.2
Process
14.3.13.3
Approval
14.3.13.4
Versions
14.3.13.5
Manual Shipment Consolidation
14.4
Working with Loads
14.4.1
Understanding Loads
14.4.1.1
Load Uses
14.4.1.2
Load Builds
14.4.1.3
Manual Shipment Additions
14.4.1.4
Options and Equipment Assignment
14.4.1.5
Stop Sequence
14.4.1.6
Pooled Shipments
14.4.1.7
Load Review
14.4.1.8
Load Approval
14.4.1.9
Status Change
14.4.1.10
One-Time Rates
14.4.1.11
Delivery Options
14.4.2
Prerequisites
14.4.3
Forms Used to Work With Loads
14.4.4
Defining the Attributes of Loads
14.4.4.1
Vehicle
14.4.4.2
Origins/Destination
14.4.4.3
Additional
14.4.5
Selecting Shipments for Loads
14.4.6
Adding Shipments Manually
14.4.7
Assigning Options and Equipment to a Load
14.4.8
Reviewing the Stop Sequence for a Load
14.4.9
Creating Pooled Shipments
14.4.10
Assigning Shipments on a Load to Compartments
14.4.11
Reviewing Loads
14.4.12
Approving Loads
14.4.13
Changing the Status to Unapprove a Load
14.4.14
Setting Processing Options for Work With Loads (P4960)
14.4.14.1
Defaults
14.4.14.2
Shipment Apprv
14.4.14.3
Versions
14.4.14.4
Process
14.4.15
Working with Tendered Loads
14.4.16
Setting Processing Options for Load Tender History (P4918)
14.4.16.1
Load Status
14.4.16.2
Processing
14.4.17
Spot-Quoting a Load
14.4.18
Deleting a Spot-Quote from a Load
14.5
Working with Deliveries
14.5.1
Understanding Load and Delivery Operations
14.5.1.1
Load and Delivery Process
14.5.1.2
Shipment Confirmation
14.5.1.3
Seal Number Entry
14.5.1.4
Tracking and Reference Numbers Entry
14.5.1.5
In-Transit Inventory
14.5.1.6
Delivery Document Printing
14.5.1.7
Document Register
14.5.1.8
Load Confirmation
14.5.1.9
14.5.1.10
Unscheduled Deliveries
14.5.1.11
Disposition Recording
14.5.2
Prerequisites
14.5.3
Forms Used to Work With Deliveries
14.5.4
Confirming Shipments Interactively
14.5.5
Entering Seal Numbers at Shipment Confirmation
14.5.6
Adding a Range of Seal Numbers
14.5.7
Setting Processing Options for Transportation Shipment Confirmation (P49645)
14.5.7.1
Process
14.5.7.2
Versions
14.5.8
Confirming Shipments by Batch
14.5.8.1
Taxed Prices
14.5.9
Setting Processing Options for Batch Transportation Shipment Confirmation (R49500)
14.5.9.1
Process
14.5.9.2
Versions
14.5.10
Entering Tracking Numbers
14.5.11
Printing Delivery Documents for a Single Shipment
14.5.12
Printing Delivery Documents for a Single Load
14.5.13
Printing Delivery Documents for Multiple Shipments or Loads
14.5.14
Setting Processing Options for Batch Delivery Documents for Shipments (R49549)
14.5.14.1
Print Control
14.5.15
Setting Processing Options for Batch Delivery Documents for Loads (R49548)
14.5.15.1
Print Control
14.5.16
Reviewing the Document Batch
14.5.17
Setting Processing Options for Document Print - Interactive (P49590)
14.5.17.1
Versions
14.5.17.2
Print Control
14.5.18
Reviewing the Document Register
14.5.19
Recording Proof of Delivery
14.5.20
Confirming Loads
14.5.21
Specifying Codes for Excess Transportation Charges
14.5.22
Setting Processing Options for Transportation Load Confirmation (P49640)
14.5.22.1
Process
14.5.22.2
Agreements
14.5.22.3
Versions
14.5.22.4
Cartons
14.5.23
Working with Seals
14.5.24
Confirming Delivery
14.5.25
Creating Unscheduled Deliveries
14.5.26
Recording Disposition
14.5.27
Reviewing In-Transit Inventory Information by Item
14.5.28
Reviewing the In-Transit Ledger
15
Tracking Shipments
15.1
15.2
Tracking Shipments
15.3
Reviewing Shipment Status
15.3.1
Forms Used to Review Shipment Status
15.3.2
15.4
Tracking Shipments or Pieces
15.4.1
15.4.2
Prerequisite
15.4.3
Forms Used to Track Shipments or Pieces
15.4.4
Setting Processing Options for Shipment Tracking (P4947)
15.4.4.1
Display
15.4.4.2
Process
15.4.5
Tracking by Shipment
15.4.6
Tracking by Piece
15.4.7
Recording Shipment Status
15.5
Inquiring on a Shipment Sequencing Sales Order
15.5.1
Form Used for Shipment Sequencing Sales Order Inquiry
15.5.2
Setting Processing Options for Shipment Sequencing Sales Order Inquiry (P49211)
15.5.2.1
Defaults
15.5.2.2
Versions
15.5.3
16
Updating Freight
16.1
Understanding the Freight Update Process
16.2
Updating Freight Charges
16.2.1
Understanding the Freight Update and Report Program
16.2.1.1
Allocating Freight Costs by Item for Outbound Transactions
16.2.1.2
Allocating Freight Costs by Item for Inbound Transactions
16.2.2
Setting Processing Options for Freight Update and Report (R4981)
16.2.2.1
Updates
16.2.2.2
Defaults
16.2.2.3
Process
16.2.2.4
Outbound SOs
16.2.2.5
Loads
16.2.2.6
Versions
16.2.2.7
Print
16.3
Matching Freight Invoices
16.3.1
Understanding Invoice Matching
16.3.2
Prerequisite
16.3.3
Forms Used to Match Freight Invoices
16.3.4
16.3.5
Setting Processing Options for Accounts Payable Standard Voucher Entry (P0411)
16.3.5.1
Display
16.3.5.2
Currency
16.3.5.3
Manual Payments
16.3.5.4
Purchasing
16.3.5.5
Voucher Match
16.3.5.6
Multi Company
16.3.5.7
Multi Vouchers
16.3.5.8
Logging
16.3.5.9
Prepayments
16.3.5.10
Versions
16.3.5.11
Process
16.3.5.12
Edits
16.4
Reviewing Freight Update
16.4.1
Understanding Freight Update Options
16.4.2
Forms Used to Review Freight Update
16.4.3
Reviewing the Freight Journal
16.4.4
Reviewing the Freight Payables Journal
16.5
Adjusting the Freight Audit History
16.5.1
Understanding Freight Audit History
16.5.2
Forms Used to Adjust Freight Audit History
16.5.3
Adjusting Freight Audit History
A
Delivered Workflow for JD Edwards EnterpriseOne Transportation Management
A.1
A.1.1
ASN Tracking
A.1.1.1
Description
A.1.1.2
Workflow Objects
Glossary
Index
Scripting on this page enhances content navigation, but does not change the content in any way.
