Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IPv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Topologies
Basic SEFOS IPv6 Topology
Route Redistribution Topology in IPv6
General Configurations
Default Settings
Completing Preliminary Configurations
Create an Interface
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configure Switch 1
Configure Switch 2
Configuring the Route Redistribution Topology
Configure Switch 1
Configure Switch 2
Configure Switch 3
IPv6 Feature Configuration
Configuring IPv6 Support in an Interface
Enable IPv6 Support
Disable IPv6 Support
Configuring IPv6 Addressing
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Routing
Enable IPv6 Routing
Disable IPv6 Routing
Configuring IPv6 Static Routes
Add a Static Route
Remove a Static Route
Configuring Static Neighbor Cache Entries
Add a Neighbor Cache Entry
Delete a Neighbor Cache Entry
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Configuring DAD Entries
Set the DAD Attempts
Reset the DAD Attempts
Configuring PMTU Discovery
Enable PMTU Discovery
Disable PMTU Discovery
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Resitribution Policy for Routing Protocols
Configure Switch 2
  1. Shut down the spanning tree.
    SEFOS# configure terminal
    SEFOS(config)# shutdown spanning-tree
  2. Disable GVRP and GMRP.
    SEFOS(config)# set gvrp disable
    SEFOS(config)# set gmrp disable
  3. Create the interface for VLAN 2, and enable IPv6.
    SEFOS(config)# interface vlan 2
    SEFOS(config-if)# shutdown
    SEFOS(config-if)# ipv6 enable
    SEFOS(config-if)# ipv6 address fec0::3333:0:1 96 unicast
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# exit
  4. Create the P15 interface in VLAN 2.
    SEFOS(config)# vlan 2
    SEFOS(config-vlan)# ports extreme-ethernet 0/15 untagged extreme-ethernet 0/15
    SEFOS(config-vlan)# exit
  5. Configure the extreme-ethernet interface.
    SEFOS(config)# interface extreme-ethernet 0/15
    SEFOS(config-if)# switchport pvid 2
  6. Enable IPv6 in VLAN 3.
    SEFOS(config)# interface vlan 3
    SEFOS(config-if)# ipv6 address fec0::2222:0:10 96 unicast
  7. Create the P3 interface in VLAN 3.
    SEFOS(config)# vlan 3
    SEFOS(config-vlan)# ports extreme-ethernet 0/3 untagged extreme-ethernet 0/3
  8. Configure the extreme-ethernet interface.
    SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS(config-if)# switchport pvid 3
    SEFOS(config-if)# end
  9. Configure the IPv6 routing on switch 2.
    SEFOS(config)# ipv6 route fec0::1111:0:0 96 fec0::2222:0:1
    SEFOS(config)# exit
  10. Review the IPv6 information on switch 1.
    SEFOS# show ipv6 interface
    vlan1 is up, line protocol is up
        Link local address:
            fe80::201:2ff:fe03:501
        Global unicast address(es):
            fec0::1111:0:1/96
        Joined group address(es):
            ff02::1
            ff02::2
            ff02::1:ff00:1
            ff02::1:ff03:501
        MTU is 9216
        ICMP redirects are enabled
        ND DAD is enabled, Number of DAD attempts: 1
        ND router advertisement is disabled
    vlan3 is up, line protocol is up
        Link local address:
            fec0::2222:0:1/96
            ff02::1
            ff02::2
            ff02::1:ff00:1
            ff02::1:ff03:501
        MTU is 1500
  11. Review the IPv6 routing table on switch 1.
    SEFOS# show ipv6 route
    IPv6 Routing Table:
    Codes : C - Connected, S - Static
            O - OSPF, R - RIP, B - BGP
    C   fec0::1111:0:0/96   [1/1]
            via ::, vlan1
    C   fec0::2222:0:0/96   [1/1]
            via ::, vlan3
    S   fec0::3333:0:0/96   [1/20]
            via fec0::2222:0:10, vlan3
  12. Review the IPv6 information on switch 2.
        Link local address:
            fe80::202:2ff:fe03:401
            Not Configured.
            ff02::1
            ff02::2
            ff02::1:ff03:401
        MTU is 1500
    vlan2 is up, line protocol is up
        Link local address:
            fec0::3333:0:1/96
            ff02::1
            ff02::2
            ff02::1:ff00:1
            ff02::1:ff03:401
        MTU is 1500
        Link local address:
            fec0::2222:0:10/96
            ff02::1
            ff02::2
            ff02::1:ff00:10
            ff02::1:ff03:401
        MTU is 1500
  13. Review the routing table information in switch 2.
    IPv6 Routing Table:
    S   fec0::1111:0:0/96   [1/20]
            via fec0::2222:0:1, vlan3
            via ::, vlan3
    C   fec0::3333:0:0/96   [1/1]
            via ::, vlan2
