Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IPv6 Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Topologies
Basic SEFOS IPv6 Topology
Route Redistribution Topology in IPv6
General Configurations
Default Settings
Completing Preliminary Configurations
Create an Interface
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configure Switch 1
Configure Switch 2
Configuring the Route Redistribution Topology
Configure Switch 1
Configure Switch 2
Configure Switch 3
IPv6 Feature Configuration
Configuring IPv6 Support in an Interface
Enable IPv6 Support
Disable IPv6 Support
Configuring IPv6 Addressing
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Routing
Enable IPv6 Routing
Disable IPv6 Routing
Configuring IPv6 Static Routes
Add a Static Route
Remove a Static Route
Configuring Static Neighbor Cache Entries
Add a Neighbor Cache Entry
Delete a Neighbor Cache Entry
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Configuring DAD Entries
Set the DAD Attempts
Reset the DAD Attempts
Configuring PMTU Discovery
Enable PMTU Discovery
Disable PMTU Discovery
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Resitribution Policy for Routing Protocols
Acronym or Abbreviation
Explanation
DAD
Duplicate address detection
ICMPv6
Internet Control Message Protocol version 6
IETF
Internet Engineering Task Force
IP
Internet Protocol
IPv4
Internet Protocol version 4
IPv6
Internet Protocol version 6
MTU
Maximum transmission unit
ND
Neighbor discovery
NDP
Neighbor Discovery Protocol
NEM
Network express module
OSPF
Open shortest path first
PMTU
Path MTU
RA
Router advertisement
RIP6
Routing Information Protocol version 6
RRD
Route redistribution
RTMv6
Route table manager version 6
SNMP
Simple Network Management Protocol
TOR
Top of the rack
TTL
Time-to-live
VLAN
Virtual LAN
