Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IPv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Topologies
Basic SEFOS IPv6 Topology
Route Redistribution Topology in IPv6
General Configurations
Default Settings
Completing Preliminary Configurations
Create an Interface
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configure Switch 1
Configure Switch 2
Configuring the Route Redistribution Topology
Configure Switch 1
Configure Switch 2
Configure Switch 3
IPv6 Feature Configuration
Configuring IPv6 Support in an Interface
Enable IPv6 Support
Disable IPv6 Support
Configuring IPv6 Addressing
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Routing
Enable IPv6 Routing
Disable IPv6 Routing
Configuring IPv6 Static Routes
Add a Static Route
Remove a Static Route
Configuring Static Neighbor Cache Entries
Add a Neighbor Cache Entry
Delete a Neighbor Cache Entry
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Configuring DAD Entries
Set the DAD Attempts
Reset the DAD Attempts
Configuring PMTU Discovery
Enable PMTU Discovery
Disable PMTU Discovery
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Resitribution Policy for Routing Protocols
  1. Enter Interface Configuration mode for the VLAN 1 interface.
    SEFOS# configure terminal
    SEFOS(config)# interface vlan 1
  2. Enable IPv6 support, and assign a unicast address for the interface.
    SEFOS(config-if)# ipv6 enable
    SEFOS(config-if)# ipv6 address fec0::1111:0:1/96
  3. Enable IPv6 RA in the interface.
    SEFOS(config-if)# no ipv6 nd suppress-ra
  4. Configure RA-related parameters, such as RA flags, hop-limit, and lifetime.
  5. Set the M-bit in the router advertisement to either stateful or stateless.
    1. To indicate that the host should configure an address using the stateful address configuration, use the following command:
      SEFOS(config-if)# ipv6 nd managed-config flag
    2. To indicate that the host should configure an address using the stateless address configuration, use the following command:
      SEFOS(config-if)# no ipv6 nd managed-config flag
  6. Set the O-bit in the router advertisement to either stateful or stateless.
    1. To indicate that the host should configure nonaddress information by statelful means, use the following command
      SEFOS(config-if)# ipv6 nd other-config flag
    2. To indicate that the host should configure nonaddress information by stateless means, use the following command
      SEFOS(config-if)# no ipv6 nd other-config flag
  7. Configure the hop-limit to be placed in the router advertisements sent from the IPv6 interface.
    SEFOS(config-if)# ipv6 hop-limit 10
  8. Configure the default router time.
    The default router time is given in seconds. This value represents the time taken until the entity acts as the default router for all of the hosts on the interface.
    SEFOS(config-if)# ipv6 nd ra-lifetime 1000
  9. Configure the reachable-time.
    The reachable-time is given in milliseconds. This value represents the time taken until a neighboring node is considered to be reachable after having received the reachability confirmation from that node.
    SEFOS(config-if)# ipv6 nd reachable-time msec 500000
  10. Configure the retransmit time.
    The retransmit time is given in milliseconds. This value represents the time taken between retransmitted neighbor solicitations, and it is used during address resolution, reachability detection, and duplicate address detection.
    SEFOS(config-if)# ipv6 nd ns-interval 500000
  11. Configure the value to be placed in the MTU options sent by the router on the interface.
    SEFOS(config-if)# ipv6 nd ra-mtu 1500
  12. Configure the minimum and maximum router advertisement time.
    Router advertisements are sent periodically at a random interval between the values specified by the minimum and maximum time values.
    SEFOS(config-if)# ipv6 nd ra-interval 300 200
  13. Configure the prefix to be advertised in the IPv6 RA.
    SEFOS(config-if)# ipv6 nd prefix fec0::1111:0:0 96 500 400
  14. Review the IPv6 information for all of the IPv6 interfaces.
    SEFOS# show ipv6 interface vlan 1
    vlan1 is up, line protocol is up
        ICMP redirects are enabled
        ND DAD is enabled, Number of DAD attempts: 1
        ND router advertisement is enabled
        ND reachable time is 500000 milliseconds
        ND retransmit time is 500000 milliseconds
        ND router advertisements are sent every 300 seconds
        ND router advertisement Link MTU 1500
