Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IPv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Topologies
Basic SEFOS IPv6 Topology
Route Redistribution Topology in IPv6
General Configurations
Default Settings
Completing Preliminary Configurations
Create an Interface
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configure Switch 1
Configure Switch 2
Configuring the Route Redistribution Topology
Configure Switch 1
Configure Switch 2
Configure Switch 3
IPv6 Feature Configuration
Configuring IPv6 Support in an Interface
Enable IPv6 Support
Disable IPv6 Support
Configuring IPv6 Addressing
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Routing
Enable IPv6 Routing
Disable IPv6 Routing
Configuring IPv6 Static Routes
Add a Static Route
Remove a Static Route
Configuring Static Neighbor Cache Entries
Add a Neighbor Cache Entry
Delete a Neighbor Cache Entry
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Configuring DAD Entries
Set the DAD Attempts
Reset the DAD Attempts
Configuring PMTU Discovery
Enable PMTU Discovery
Disable PMTU Discovery
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Resitribution Policy for Routing Protocols
  1. Enter Global Configuration mode.
    SEFOS# configure terminal
  2. Set the MTU value for use in PMTU discovery.
    SEFOS(config)# ipv6 path mtu 2004::0 1500
    where:
    • 2400::0 is the prefix address.
    • 1500 is the MTU value.
  3. Use the ping command to connect to host B from switch 1 with the packet sizing as 1800.
    SEFOS# ping ipv6 fec0::3333:0:10 size 1800
    ping6 fec0::3333:0:10 1800 bytes of data
    1800 bytes from fec0::3333:0:10 : icmp_seq = 0
    1800 bytes from fec0::3333:0:10 : icmp_seq = 1
    1800 bytes from fec0::3333:0:10 : icmp_seq = 2
    1800 bytes from fec0::3333:0:10 : icmp_seq = 3
    1800 bytes from fec0::3333:0:10 : icmp_seq = 4
     --- Ping Statistics ---
    5 Packets Transmitted, 5 Packets Received, 0% Packet Loss
  4. On switch 1, review the MTU value.
    SEFOS# show ipv6 pmtu
    PMTU discovery is enabled
      Ipv6 Path MTU Table
    Destination     PMTU
    fec0::1111:0:01200
