Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide
search filter icon
search icon
Document Information
Using This Documentation
1.  Preparing to Install the Server
Tools and Equipment Needed
Server Installation Task Checklist
Opening the Box
Server Box Contents
Options
ESD Precautions
Server Description
Front Panel Features
Back Panel Features
Server Supported Components
Sun Server X2-4 Supported Components and Capabilities
Server Specifications
Physical Specifications
Electrical Specifications
Environmental Requirements
Managing Your Server
2.  Installing the Server Into a Rack With Slide-Rails
Before You Begin
Server Installation Process Overview
Rack Compatibility
Disassembling the Slide-Rails
Disassemble Slide-Rails
Installing the Mounting Brackets Onto the Server
Install Mounting Brackets
Attaching the Slide-Rail Assemblies to the Rack
Attach Slide-Rail Assemblies
Installing the Server Into the Slide-Rail Assemblies
Install Server Into the Slide-Rail Assemblies
Installing the Cable Management Arm
Install Cable Management Arm
Verifying Operation of the Slide-Rails and CMA
Verify Operation of Slide-Rails and CMA
3.  Attaching Cables and Power Cords
Back Panel Connectors and Ports
Attaching Cables to the Server
Cable the Server
Connecting Power Cords to the Server
Connect the Power Cords
4.  Connecting to Oracle ILOM and Applying Main Power to the Server
Network Defaults
Log In to Oracle ILOM Using a Local Serial Connection
Log In to Oracle ILOM Using a Remote Ethernet Connection
Modify Network Settings From the Oracle ILOM CLI
Modify Network Settings From the Oracle ILOM Web Interface
Test IPv4 or IPv6 Network Configuration From the Oracle ILOM CLI
Test IPv4 or IPv6 Network Configuration From the Oracle ILOM Web Interface
Exit Oracle ILOM
Apply Main Power to the Server
Power Off From Main Power
5.  Configuring the Preinstalled Oracle Solaris OS or the Oracle VM Software
Operating System Options
Preparing for the Oracle Solaris Configuration
Preinstalled Oracle Solaris Operating System RAID Limitations
Oracle Solaris 10 and 11 Configuration Worksheet
Configuring the Preinstalled Oracle Solaris 11 Operating System
Configure the Preinstalled Oracle Solaris 11 Operating System
Oracle Solaris 11 Operating System Documentation
Configuring the Preinstalled Oracle Solaris 10 Operating System
Configure the Preinstalled Oracle Solaris 10 Operating System
Oracle Solaris 10 Operating System Documentation
Reinstalling the Oracle Solaris 10 or 11 Operating System
Download the Oracle Solaris Operating System
Preparing for the Oracle VM Configuration
Preinstalled Oracle VM Server Compatiblitiy Requirements
Oracle VM Configuration Worksheet
Configuring the Preinstalled Oracle VM 3.0 Software
Configure the Preinstalled Oracle VM Server
Oracle VM Documentation
6.  Installing an Operating System
7.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
Downloads on My Oracle Support are grouped by product family, then product, then version. The version contains one or more downloads (patches).
For servers and blades, the pattern is similar. The product is the server. Each server contains a set of releases. These releases are not true software product releases, but rather are releases of updates for the server. These updates are called software releases and comprise several downloads, all tested together. Each download contains firmware, drivers, or utilities.
My Oracle Support has the same set of download types for this server family as shown in the following table. These can also be requested through a physical media request (PMR).
Package Name
Description
When to Download This Package
X4470 M2 SERVER SW 1.3 – ILOM_AND_BIOS
Oracle ILOM and BIOS.
You need the latest platform firmware.
X4470 M2 SERVER SW 1.3 – ORACLE_HARDWARE_ INSTALLATION_ASSISTANT
Oracle Hardware Installation Assistant recovery and ISO update image.
You need to manually recover or update Oracle Hardware Installation Assistant.
X4470 M2 SERVER SW 1.3 – TOOLS_DRIVERS_AND_ FIRMWARE_DVD
Includes the tools and drivers and platform firmware. This DVD image does not include Oracle VTS.
You need to update a combination of system firmware and OS-specific software.
X4470 M2 SERVER SW 1.0 – DIAGNOSTICS
Oracle VTS diagnostics image.
You need the Oracle VTS diagnostics image.
