Skip Navigation Links | |
Exit Print View | |
Sun Blade 6000 Virtualized 40 GbE Network Express Module Product Notes |
Product Compatibility Information
Supported Software and Firmware
Available Firmware and Software
Hardware and Networking Issues
sxge Device Corresponding to Port 1 Cannot Communicate with External Hosts in 40G or 1G Mode
CMM Minimum Version and CMM ILOM Upgrade Requirement (7046303)
Cannot Unload sxge When Interfaces are Unplumbed (7045733)
Hot Plug is Not Supported by VMware
PCI Correctable Errors Might Occur When Using NEM (7012350 and 7064505)
Hot Plug is Not Supported by Windows 2008 R2 with Sun Blade X6270 M2 and NEM (7050066)
Sometimes sxge Ports Fail to Enumerate During Hot-plug with Sun Blade X6270 M2 Blades (7087921)
ILOM Web GUI Reports Error: “Command Failed” (16092938)
Highest Lane Number in show peu Output is Incorrect (7039713)
Unable to Access NEM by Clicking on Graphic from the CMM ILOM Web GUI (7099903)
# lspci -n |grep 2078 1b:00.0 0200: 108e:2078 (rev 01) 1c:00.0 0200: 108e:2078 (rev 01)
# lsmod | grep sxge sxge 70408 0
# ifconfig -a eth0 Link encap:Ethernet HWaddr 00:21:28:57:3E:43 inet addr:10.134.172.42 Bcast:10.134.172.255 Mask:255.255.255.0 inet6 addr: fe80::221:28ff:fe57:3e43/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1664879 errors:0 dropped:0 overruns:0 frame:0 TX packets:286457 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1021881508 (974.5 MiB) TX bytes:34428397 (32.8 MiB) Memory:fafe0000-fb000000 eth1 Link encap:Ethernet HWaddr 00:21:28:57:3E:42 BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 b) TX bytes:0 (0.0 b) Memory:faf60000-faf80000 eth2 Link encap:Ethernet HWaddr FA:DE:00:00:FC:0F inet6 addr: fe80::f8de:ff:fe00:fc0f/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 b) TX bytes:0 (0.0 b) Interrupt:177 eth3 Link encap:Ethernet HWaddr FA:CE:00:00:FC:0F inet6 addr: fe80::f8ce:ff:fe00:fc0f/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:58080 errors:0 dropped:0 overruns:0 frame:0 TX packets:26224 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6721340 (6.4 MiB) TX bytes:4038704 (3.8 MiB) Interrupt:169 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:582 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:83168 (81.2 KiB) TX bytes:83168 (81.2 KiB) sit0 Link encap:IPv6-in-IPv4 NOARP MTU:1480 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:26224 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
# ethtool -i eth3 driver: sxge version: 0.01202011 firmware-version: bus-info: 0000:1b:00.0
The driver used by the ethx device associated with the NEM is sxge.
After you complete this procedure, the NEM can be configured and used. If the issue persists, please contact your Oracle Service representative.
