Skip Navigation Links
Exit Print View
Configuring Oracle Java CAPS Master Indexes (Repository)     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
Master Index Configuration Overview (Repository)
About the Master Index Configuration Files (Repository)
Object Definition
Candidate Select
Match Field
Threshold
Best Record
Field Validation
Security
Enterprise Data Manager
Modifying the Master Index XML Files Directly (Repository)
Using the Master Index Configuration Editor-Repository
Object Definition File
Candidate Select File
Threshold File
Match Field File
Best Record File
Field Validation File
Enterprise Data Manager File
Match Configuration File (matchConfigFile.cfg)
Maintaining Version Control in the Master Index (Repository) Configuration Files
Checking Configuration Files Out With the Configuration Editor-Repository
Checking Configuration Files In With the Configuration Editor-Repository
Working With the XML Editor
Saving a Configuration File to the Repository
Validating XML Files
Copying, Cutting, and Pasting Files
Configuring the Master Index Object Structure (Repository)
Adding an Object to the Master Index Object Structure (Repository)
To Add an Undefined Object (Configuration Editor)
To Add a Predefined Object (Configuration Editor)
To Add an Undefined Object (XML editor)
Modifying an Object's Name In the Master Index Object Definition (Repository)
To Modify an Object's Name (Configuration Editor)
To Modify an Object's Name (XML Editor)
Deleting an Object From the Master Index Object Structure (Repository)
To Delete an Object (Configuration Editor)
To Delete an Object (XML Editor)
Adding a Field to the Master Index Object Structure (Repository)
To Add a Field (Configuration Editor)
To Add a Field (XML Editor)
Deleting a Field from the Master Index Object Structure (Repository)
To Delete a Field (Configuration Editor)
To Delete a Field (XML Editor)
Modifying Master Field Properties (Repository)
To Modify Field Properties (Configuration Editor)
To Modify Field Properties (XML Editor)
Defining Relationships Between Master Index Objects (Repository)
To Define Object Relationships (XML Editor)
Master Index Field Properties and Name Restrictions (Repository)
Master Index Field Name Restrictions (Repository)
Master Index Configuration Editor Field Properties (Repository)
Master Index Field Property Elements (Repository)
Creating a Master Index Basic Query (Repository)
To Create a Basic Query (Configuration Editor)
To Create a Basic Query (XML Editor)
Master Index Query Builder Dialog Box Fields and XML Elements (Repository)
Creating Master Index Blocking Queries (Repository)
To Create a Blocking Query (Configuration Editor)
To Create a Blocking Query (XML Editor)
Master Index Query Block Fields and XML Elements (Repository)
Modifying Master Index Queries (Repository)
Modifying a Master Index Query (Repository)
To Modify a Basic Query (Configuration Editor)
To Modify a Query (XML Editor)
Adding a Query Block to a Master Index Query (Repository)
To Add a Query Block (Configuration Editor)
To Add a Query Block (XML Editor)
Modifying a Query Block for a Master Index Query (Repository)
To Modify a Query Block (Configuration Editor)
To Modify a Query Block (XML Editor)
Deleting a Query Block From a Master Index Query (Repository)
To Delete a Query Block (Configuration Editor)
To Delete a Query Block (XML Editor)
Deleting a Master Index Query (Repository)
To Delete a Query (Configuration Editor)
To Delete a Query
Configuring Master Index Processing Options (Repository)
Specifying Master Index Custom Logic Classes (Repository)
To Specify Custom Logic for External System Messages
To Specify Custom Logic for the Enterprise Data Manager
Specifying the Master Index Update Mode (Repository)
To Specify Potential Duplicates be Reevaluated at Each Update
To Specify Potential Duplicates not be Reevaluated at Each Update
Configuring Master Index Merged Record Updates (Repository)
To Allow Merged Record Updates
To Prevent Merged Record Updates
Specifying the Master Index Blocking Query for Matching (Repository)
To Specify the Blocking Query for Matching
Setting Master Index Blocking Query Options (Repository)
To Set Blocking Query Options
Configuring Matching Parameters (Repository)
Specifying the Master Index Decision Maker Class (Repository)
To Specify the Decision Maker Class
Defining How to Handle Multiple Assumed Matches (OneExactMatch) (Repository)
To Create Potential Duplicates When Multiple Records Match
To Match the Highest Weighted Records When Multiple Records Match
Specifying Whether Same System Matches are Allowed (SameSystemMatch) (Repository)
To Allow Same System Records to be Automatically Merged
To Prevent Same System Records From Being Automatically Merged
Specifying the Master Index Duplicate Threshold (Repository)
To Specify the Duplicate Threshold (Configuration Editor)
To Specify the Duplicate Threshold (XML Editor)
Specifying the Master Index Match Threshold (Repository)
To Specify the Match Threshold (Configuration Editor)
To Specify the Match Threshold (XML Editor)
Adding and Deleting Master Index Decision Maker Parameters (Repository)
To Add a New Decision Maker Parameter
To Delete a Decision Maker Parameter
Configuring Master Index EUIDs (Repository)
Specifying the Master Index EUID Generator Class (Repository)
To Specify the EUID Generator Class
Specifying the Master Index EUID Length (Repository)
To Specify the EUID Length
Specifying a Master Index Checksum Length (Repository)
To Specify a Checksum Length
Specifying the Master Index Chunk Size (Repository)
To Specify the Chunk Size
Adding and Deleting Master Index EUID Generator Parameters (Repository)
To Add EUID Generator Parameters
To Delete EUID Generator Parameters
Defining Master Index Normalization Rules (Repository)
Defining a Master Index Field to be Normalized (Repository)
To Define a Field to be Normalized (Configuration Editor)
To Define a Field to be Normalized (XML Editor)
Master Index Normalization and Standardization Structure Properties (Repository)
Master Index Locale Codes Properties (Repository)
Modifying a Master Index Normalization Definition (Repository)
To Modify a Normalization Definition (Configuration Editor)
To Modify a Normalization Structure (XML Editor)
Deleting a Master Index Normalization Definition (Repository)
To Delete a Normalization Definition
To Delete a Normalization Structure
Defining Master Index Standardization Rules (Repository)
Defining Master Index Fields to be Standardized (Repository)
To Define Fields to be Standardized (Configuration Editor)
To Define Fields to be Standardized (XML Editor)
Master Index Standardization Source and Target Field Elements (Repository)
Modifying a Master Index Standardization Definition (Repository)
To Modify a Standardization Definition (Configuration Editor)
To Modify a Standardization Definition (XML Editor)
Deleting a Master Index Standardization Definition (Repository)
To Delete a Standardization Definition (Configuration Editor)
Defining Phonetic Encoding for the Master Index (Repository)
Defining Master Index Fields for Phonetic Encoding (Repository)
To Define a Field for Phonetic Encoding (Configuration Editor)
To Define a Field for Phonetic Encoding (XML Editor)
Master Index Phonetic Encoding Fields and Elements (Repository)
Modifying a Master Index Phonetic Encoding Definition (Repository)
To Modify a Phonetic Encoding Definition (Configuration Editor)
To Modify a Phonetic Encoding Definition (XML Editor)
Deleting a Master Index Phonetic Encoding Definition (Repository)
To Delete a Phonetic Encoding Definition (Configuration Editor)
To Delete a Phonetic Encoding Definition (XML Editor)
Defining a Master Index Phonetic Encoder (Repository)
To Define a Phonetic Encoder (Configuration Editor)
To Define a Phonetic Encoder (XML Editor)
Master Index Encoder Elements and Types (Repository)
Modifying a Master Index Phonetic Encoder (Repository)
To Modify a Phonetic Encoder (Configuration Editor)
To Modify a Phonetic Encoder (XML Editor)
Deleting a Master Index Phonetic Encoder (Repository)
To Delete a Phonetic Encoder (Configuration Editor)
To Delete a Phonetic Encoder (XML Editor)
Defining the Master Index Match String (Repository)
Creating the Master Index Match String (Repository)
To Create the Match String (Configuration Editor)
To Create the Match String (XML Editor)
Modifying the Master Index Match String (Repository)
To Modify the Match String (Configuration Editor)
To Modify the Match String (XML Editor)
Defining how Master Index Query Blocks are Processed (Repository)
To Specify the Block Picker
To Specify the Pass Controller Class
Defining the Master Index Survivor Calculator (Repository)
Specifying the Master Index Survivor Helper (Repository)
To Specify the Survivor Helper
Specifying a Master Index Default Survivor Strategy (Repository)
To Specify a Default Survivor Strategy
Configuring the Default Survivor Strategy
Master Index Default Survivor Strategy Parameter Elements (Repository)
Defining the Master Index Single Best Record Structure (Repository)
To Specify a Candidate Field
Deleting Candidate Fields
Defining a Master Index Survivor Strategy for a Field or Object (Repository)
To Define a Survivor Strategy for a Field
Defining Master Index Custom Weighted Strategies (Repository)
Defining Custom Weighted Strategies
Configuring Weighted Strategies
Modifying Weighted Calculator Parameters
Deleting Weighted Calculator Parameters
Master Index Weighted Calculator Parameter Elements (Repository)
Configuring Master Index Update Policies (Repository)
Defining Master Index Update Policies (Repository)
To Define Update Policies
Setting the Master Index Update Policy Flag (Repository)
To Set the Update Policy Flag
Defining Custom Field Validations for the Master Index (Repository)
To Implement a Validation Rule
Configuring the Match Engine (Repository)
Specifying a Match Engine for the Master Index (Repository)
To Configure the Match Engine
Configuring the Comparison Functions for a Master Index Application (Repository)
To Configure the Comparison Functions (Configuration Editor)
To Configure the Comparison Functions (Text Editor)
Match Comparator Configuration Properties for Oracle Java CAPS Master Index (Repository)
Configuring the Standardization Engine (Repository)
Specifying a Standardization Engine for the Master Index (Repository)
To Specify the Standardization Engine
Modifying Master Index Standardization Files (Repository)
To Modify Standardization Data Configuration Files
Loading Standardization Files to a Master Index Application (Repository)
To Load Standardization Files
Configuring the Master Index EDM Appearance (Repository)
Adding Objects to the EDM
To Add an Object to the EDM
Modifying EDM Objects
To Modify an EDM Object
Deleting Objects From the EDM
To Delete an Object
Adding Fields to the EDM
To Define New Fields
EDM Field Configuration Elements
Removing Fields From the EDM
To Remove a Field From the EDM
Modifying EDM Field Display Options
To Modify a Field's Display Options
Specifying a Drop-Down List for an EDM Field
To Specify a Drop-Down List
Specifying an EDM Field's Length and Format
To Modify a Field's Length and Format
Modifying an EDM Field's Data Type
To Modify the Data Type
Defining Key Fields for an Object (Repository)
To Modify the Key Status
Masking Field Values on the EDM
To Mask Field Values on the EDM
Defining EDM Object Relationships (Repository)
To Define Relationships
Defining EDM Local ID Labels (Repository)
To Define Local ID Labels
Configuring the Master Index EDM Search Pages (Repository)
Specifying Standard EDM Search Page Properties (Repository)
To Specify Standard Search Page Properties
Creating a Search Page for the EDM (Repository)
Step 1: Define the Search Page
Step 2: Define the Search Fields
Step 3: Specify Search Options
EDM Search Page Definition Elements
EDM Search Field Definition Elements
EDM Search Option Elements
Modifying a Search Page on the EDM (Repository)
Modifying a Search Page Definition
Modifying Search Fields
Modifying Search Options
Configuring Master Index EDM Page Layouts (Repository)
Specifying the Initial View for the EDM (Repository)
To Specify the Initial View
Configuring the EDM Search Results Page (Repository)
To Configure the Search Results Page
Configuring the EDM View/Edit Page (Repository)
To Configure the View/Edit Page
Configuring the EDM Create System Record Page (Repository)
To Configure the Create EO Page
Configuring the EDM History Page (Repository)
To Configure the History Page
Configuring the EDM Match Review Page (Repository)
To Configure the Match Review Page
Configuring the EDM Reports and Reports Page (Repository)
Configuring the Reports Page
Configuring Reports
EDM Reports and Reports Page Configuration Elements (Repository)
Configuring the EDM Audit Log Pages (Repository)
To Configure the Audit Log Pages
Configuring Master Index EDM Implementation Information (Repository)
Specifying the Master Controller JNDI Class (Repository)
To Specify the Master Controller JNDI Class
Specifying the Master Index Report Generator JNDI Class (Repository)
To Specify the Report Generator JNDI Class
Specifying Master Index Validation Services (Repository)
To Specify the Validation Service
Setting Master Index Debug Options (Repository)
To Set Debug Options
Specifying a Master Index Field Masking Class (Repository)
To Specify a Field Masking Class
By default, two basic queries are predefined in the Candidate Select file, one phonetic and one exact alphanumeric. If the default queries do not meet your query requirements, you can define new queries for the master index application. You can either use an existing query builder class or create a custom query builder by creating a custom plug-in (for more information, see Custom Plug-Ins for Master Index Custom Components (Repository) in Developing Oracle Java CAPS Master Indexes (Repository)).
The changes you make on the Query page of the Configuration Editor are reflected in the Candidate Select file. For more information about this file and the configurable query options, see Candidate Select Configuration (Repository) in Understanding Oracle Java CAPS Master Index Configuration Options (Repository). If you create a new query to use from the EDM, make sure to add that query to one of the search definitions in the Enterprise Data Manager file. Unless specifically defined for range searching in the Enterprise Data Manager file, basic queries use exact searching. No configuration is required in the Candidate Select file for basic exact or range searching.
You can create basic queries either through the Configuration Editor or by modifying the XML file directly. Both methods are described here.
  1. In the Projects window, right-click the master index application you want to modify, and then click Open.
  2. If the Configuration Editor dialog box appears, click Edit to check out the listed files.
    The Configuration Editor appears.
  3. Click the Query tab.
    The Query page appears.
  4. In the Basic Queries section, click Add.
    The Basic Query Builder dialog box appears.
  5. Enter values and select options for the fields described in Master Index Query Builder Dialog Box Fields and XML Elements (Repository).
  6. On the Configuration Editor toolbar, click Save.
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click the Candidate Select file.
    The file opens in the NetBeans XML editor.
  2. Create a new query-builder element in the QueryBuilderConfig element.
    Make sure the new element is created outside of any existing query-builder elements.
  3. For the new query-builder element, define the attributes listed in Master Index Query Builder Dialog Box Fields and XML Elements (Repository).
    For example:
    <query-builder name="PHONETIC-SEARCH" class=
      "com.stc.eindex.user.CustomQueryBuilder"
      parser-class=
      "com.stc.eindex.configurator.impl.querybuilder.KeyValueConfiguration"
       standardize="false" phoneticize="true">
    </query-builder>
  4. To configure the query to use wildcard characters, do the following:
    1. Add a new config element after the opening query-builder element.
      For example:
      <query-builder name="ALPHA-SEARCH" class=
        "com.stc.eindex.querybuilder.BasicQueryBuilder"
        parser-class=
        standardize="true" phoneticize="true">
         <config>
         </config>
      </query-builder>
  5. In the new config element, create an option element and then define key and value attributes for the new element.
    For example:
    <config>
     <option key="UseWildcard" value="true"/>
    </config>
    Note - For the default basic query, only the UseWildcard parameter is supported. If you create a custom basic query builder, you can use these elements to define additional parameters. For more information, see Master Index Query Builder Dialog Box Fields and XML Elements (Repository).
  6. Save and close the file.
The following table lists and describes the fields on the Basic Query Builder and Blocking Query Builder dialog boxes on the Configuration Editor, along with the corresponding elements and attributes in the Candidate Select file.
XML Element/Attribute
Description
Query Builder Name
query-builder/name
A unique ID that identifies the Query Builder and is referenced from the Enterprise Data Manager file when specifying the query to use on a search page. It is also referenced from the Match Field file when specifying the query to use for matching. No spaces are allowed in the name.
Query Builder Class
query-builder/class
The fully qualified name of the query class. Two default Query Builder classes are provided.
  • com.stc.eindex.querybuilder.BasicQueryBuilder – Builds dynamic queries using all the available input fields. When configured to use normalized and phonetic data, this query performs phonetic searches; when configured to not use normalized and phonetic data, this query is used for exact alphanumeric searches.
  • com.stc.eindex.querybuilder.BlockerQueryBuilder – Builds queries using the criteria defined in the block definitions defined for the query. When a blocking query is performed, the application searches only on the blocks for which they query has complete data.
Parser Class
query-builder/ parser-class
The fully qualified name of the class that parses the configuration elements for each query. The default parser class is com.stc.eindex.configurator.impl.querybuilder. KeyValueConfiguration.
Standardize
query-builder/ standardize
An indicator of whether any of the query criteria is standardized before being passed to the query. On the Configuration Editor, select this check box if any search fields are standardized. In the XML file, enter true if any search fields are standardized; otherwise enter false.
Phoneticize
query-builder/ phoneticize
An indicator of whether any of the query criteria is phonetically encoded before being passed to the query. On the Configuration Editor, select this check box if any search fields are phonetically encoded. In the XML file, enter true if any search fields are phonetically encoded; otherwise enter false.
Use Wildcard
option/key
option/value
An indicator of whether wildcard characters are allowed when executing this search. This parameter is available for basic queries only. On the Configuration Editor, select this check box if wildcard characters are allowed in any of the search fields.
In the XML file, each option element configures one parameter for the query and contains a key and value pair. The key attribute names the parameter. For the default basic query, the name is UseWildCard. The value attribute specifies the value of the corresponding key attribute. For the UseWildCard parameter, specify true to allow wildcard characters for that query type; otherwise specify false.
When wildcard characters are enabled, you can enter a percent sign (%) into search criteria to represent multiple unknown characters.
Note - If you define a custom query, you can use key and value options to define any required parameters.
