Skip Navigation Links
Exit Print View
Oracle® x86 Servers Diagnostics Guide For Servers Supporting Oracle ILOM 3.0.x
search filter icon
search icon
Document Information
Preface
1.  Introduction to Diagnostic Tools
About Diagnostic Tools
Strategy for Diagnostics
To Diagnose Server Problems
Service Processor
Standalone Package-Based Diagnostics
Offline Operating System-Based Diagnostics
Online Operating System-Based Diagnostics
Diagnostic Tools for Oracle Servers
BIOS POST
U-Boot
Pc-Check
Oracle VTS
Snapshot Utility
Using the Diagnostic Tools to Troubleshoot a Server
Troubleshooting Scenarios
Diagnostic Test Coverage
Setting Up a Server for Testing
2.  U-Boot Diagnostic Start-Up Tests
U-Boot Diagnostic Start-Up Tests Overview
Server Diagnostic Test Options at Start-Up
U-Boot Diagnostic Test Modes - Normal, Quick, and Extended
Reporting of Diagnostic Failures at Server Start-Up
Running the U-Boot Diagnostic Tests
Before You Begin
To Select a U-Boot Diagnostic Mode to Run at Start-Up
Sample U-Boot Test Output
U-Boot Normal Mode - Test Output Sample
U-Boot Quick Mode - Test Output Sample
U-Boot Extended Mode - Test Output Sample
Sample SP Environmental Variables Showing U-Boot Test Status
3.  Pc-Check Diagnostics Utility
Pc-Check Diagnostics Overview
Accessing the Pc-Check Diagnostics Utility
To Access Pc-Check Using the Oracle ILOM Web Interface
To Access Pc-Check Using the Oracle ILOM CLI
System Information Menu
System Information Menu Options
Advanced Diagnostics Tests
Advanced Diagnostics Tests Menu Options
Immediate Burn-in Testing
Immediate Burn-in Testing Menu Options
Deferred Burn-in Testing
To Create and Save Scripts for Deferred Burn-in Testing
Show Results Summary
Show Results Summary Menu Options
Print Results Report
About Pc-Check
Exit to DOS
Index
Chapter 2
This chapter describes the U-Boot diagnostic tests that automatically run each time you start or reboot your server. Specifically, this chapter includes information about the purpose of U-Boot start-up diagnostic tests, how to run the tests, and finally, it presents sample test outputs for each U-Boot test mode.
Topics contained in this chapter include:
