Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Power Off a Server With Multiple Active Domains (Oracle VM Server for SPARC)
If the server is configured with multiple Oracle VM for SPARC domains, use this procedure to shut down the domains and power off the server.
  1. If needed, ensure that the domain configurations are saved to the SP.
    # ldm add-config config-name
  2. Access and shut down the OS in all of the nonprimary domains.
    The method you use to access a domain depends on how you have configured the consoles for your domains.
    To shut down the OS, see Shut Down the OS (init Command) or Shut Down the OS (shutdown Command).
    1. From the primary domain, list the domains and their states.
      # ldm ls
      Note which domains are non-I/O domains or active I/O domains.
    2. Stop and unbind all the non-I/O domains.
      # ldm stop-domain domain-name
      # ldm unbind domain-name
    3. Stop and unbind any active I/O domains.
    4. Verify that the nonprimary domains are inactive.
      # ldm ls
  3. Shut down the primary domain.
  4. Switch from the system console prompt to the Oracle ILOM prompt.
    {0} ok #.
  5. From the Oracle ILOM prompt, type:
    -> stop /System
    Are you sure you want to stop /System (y/n)? y
    Stopping /System
    Note - To perform an immediate shutdown, use the stop -force /System command. Ensure that all data is saved before typing this command.
Related Information
