Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Glossary
A
ANSI SIS
American National Standards Institute Status Indicator Standard.
ASF
Alert standard format (Netra products only).
AWG
American wire gauge.
B
blade
Generic term for server modules and storage modules. See server module and storage module.
blade server
Server module. See server module.
BMC
Baseboard management controller.
BOB
Memory buffer on board.
C
chassis
For servers, refers to the server enclosure. For server modules, refers to the modular system enclosure.
CMA
Cable management assembly.
CMM
Chassis monitoring module (server modules only). The CMM is the service processor in the modular system that contains server modules. Oracle ILOM runs on the CMM, providing lights out management of the components in the modular system chassis. See modular system and Oracle ILOM.
CMP
Chip multiprocessor.
D
DHCP
Dynamic Host Configuration Protocol.
disk module or disk blade
Interchangeable terms for storage module. See storage module.
DTE
Data terminal equipment.
E
EIA
Electronics Industries Alliance.
ESD
Electrostatic discharge.
F
FEM
Fabric expansion module (server modules only). FEMs enable server modules to use the 10GbE connections provided by certain NEMs. See NEM.
FRU
Field-replaceable unit.
H
HBA
Host bus adapter.
host
The part of the server or server module with the CPU and other hardware that runs the Oracle Solaris OS and other applications. The term host is used to distinguish the primary computer from the SP. See SP.
hot-pluggable
Describes a component that can be replaced with power applied, but the component must be prepared for removal.
hot-swappable
Describes a component that can be replaced with power applied, and no preparation is required.
I
ID PROM
Chip that contains system information for the server or server module.
IP
Internet Protocol.
K
KVM
Keyboard, video, mouse. Refers to using a switch to enable sharing of one keyboard, one display, and one mouse with more than one computer.
L
LwA
Sound power level.
M
MAC
Machine access code.
MAC address
Media access controller address.
modular system
The rackmountable chassis that holds server modules, storage modules, NEMs, and PCI EMs (server modules only). The modular system provides Oracle ILOM through its CMM.
MSGID
Message identifier.
N
name space
Top-level Oracle ILOM target.
NEBS
Network Equipment-Building System (Netra products only).
NEM
Network express module (server modules only). NEMs provide Ethernet and SAS connectivity to storage modules.
NET MGT
Network management port. An Ethernet port on the server SP, the server module SP, and the CMM.
NIC
Network interface card or controller.
NMI
Nonmaskable interrupt.
O
OBP
OpenBoot PROM. Sometimes OBP is used in file names and messages to indicate a relationship to OpenBoot.
Oracle ILOM
Oracle Integrated Lights Out Manager. Oracle ILOM firmware is preinstalled on a variety of Oracle systems. Oracle ILOM enables you to remotely manage your Oracle servers regardless of the state of the host system.
Oracle ILOM CMM
Oracle ILOM that runs on the CMM (server modules only). See Oracle ILOM.
Oracle Solaris OS
Oracle Solaris operating system.
P
PCI
Peripheral component interconnect.
PEM
PCIe ExpressModule (server modules only). Modular components that are based on the PCI Express industry-standard form factor and offer I/O features such as Gigabit Ethernet and Fibre Channel.
POST
Power-on self-test.
PROM
Programmable read-only memory.
PSH
Predictive self healing.
R
REM
RAID expansion module (server modules only). Sometimes referred to as an HBA See HBA. Supports the creation of RAID volumes on drives.
S
SAS
Serial attached SCSI.
SCC
System configuration chip.
SER MGT
Serial management port. A serial port on the server SP, the server module SP, and the CMM.
server module
Modular component that provides the main compute resources (CPU and memory) in a modular system. Server modules also might have on-board storage and connectors that hold FEMs.
SP
Service processor. In the server or server module, the SP is a card with its own OS. The SP processes Oracle ILOM commands providing lights out management control of the host. See host.
SSD
Solid-state drive.
SSH
Secure shell.
storage module
Modular component that provides computing storage to the server modules.
T
TIA
Telecommunications Industry Association (Netra products only).
Tma
Maximum ambient temperature.
U
UCP
Universal connector port.
UI
User interface.
UL
Underwriters Laboratory Inc.
U.S. NEC
United States National Electrical Code.
UTC
Coordinated Universal Time.
UUID
Universal unique identifier.
W
WWN
World wide name. A unique number that identifies a SAS target.
