Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Power On the Server (Oracle ILOM CLI)
Note - By default, the host automatically attempts to boot when the host is reset or powered on. To learn about the parameters that control this action, see Configuring Boot Parameters.
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM.
    Note - If you have a modular system, ensure that you are logged in to the desired server module.
  2. At the Oracle ILOM prompt, type:
    -> start /System
    Are you sure you want to start /System (y/n) ? y
    Starting /System
    Note - To skip being prompted for confirmation, use the start -script /System command.
  3. Switch to the host console to view host output.
    -> start /HOST/console
    Are you sure you want to start /HOST/console (y/n)? y
Related Information
