man pages section 1M: System Administration Commands
Exit Print View
Updated: July 2014
wanboot_p12split(1M)
Name
wanboot_p12split - split a PKCS #12 file into separate certificate and key files
Synopsis
/usr/lib/inet/wanboot/p12split -i p12file -c out_cert -k out_key
     [-t out_trust -l id -v]
Description
The p12split utility extracts a certificate and private key from the repository specified by p12file, depositing the certificate in out_cert and the key in out_key. If supplied, the –l option specifies the value for the LocalKeyId that will be used in the new certificate and key files. p12split can optionally extract a trust certificate into the out_trust file if the –t option is specified. Use the – v option to get a verbose description of the split displayed to standard output.
Options
The following arguments and options are supported:
–c out_cert
Specifies a repository that receives a extracted certificate.
–i p12file
Specifies a repository from which a certificate and private key is extracted.
–k out_key
Specifies a repository that receives a extracted private key.
–l id
Specifies the value for the LocalKeyId that will be used in the new certificate and key files.
–t out_trust
Specifies a file for receiving an extracted trust certificate.
–v
Displays a verbose description of the split to stdout.
Exit Status
0
Successful operation.
>0
An error occurred.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/boot/wanboot
Interface Stability
Uncommitted
See also
attributes(5)
