Go to main content
SPARC T7-2 Server Installation Guide
Exit Print View
Updated: July 2017
Disassemble Slide Rails
Complete the following task to remove the mounting brackets from the slide rail assemblies before installation.
  1. Unpack the slide rails.
  2. Locate the slide rail lock at the front of one of the slide rail assemblies.
    image:Graphic showing slide rail lock tabs and mounting bracket release button.
    No.
    Description
    1
    Slide rail lock
    2
    Mounting bracket release button
  3. Press and hold the slide rail lock toward the direction of the arrow while you pull the mounting bracket out of the slide rail assembly until it reaches the stop.
  4. Push the mounting bracket release button toward the front of the mounting bracket, and simultaneously withdraw the mounting bracket from the slide rail assembly.
  5. Repeat for the remaining slide rail assembly.
Related Information
