Go to main content
Oracle® Server X6-2L Installation Guide
Exit Print View
Updated: January 2021
Receiving and Unpacking Guidelines
The following table lists the dimensions and weights for the shipping cartons that contain the Oracle Server X6-2L.
Table 3  Shipping Carton Specifications
Requirement
Specification
Shipping carton height
30.5 cm (12 inches)
Shipping carton width
59.9 cm (23.6 inches)
Shipping carton length
98.4 cm (38.7 inches)
Shipping carton weight
5.8 kg (12.8 lbs)
When the server is unloaded at your site, leave the server in its shipping carton until it arrives in its installation location. Use a separate area in which to remove the packaging material to reduce particle contamination before the server is taken to the data center. Ensure that there is enough clearance and clear pathways to move the server from the unpacking area to the installation location.
