Go to main content
Oracle® Exadata Storage Server X6-2 Extreme Flash Service Manual
Exit Print View
Updated: January 2018
Configure SP Network Settings
Choose one of the following methods to specify service processor (SP) network settings:
  • BIOS – Assign the IP address for the server SP from the BIOS Setup Utility on the Advanced Menu.
  • Oracle ILOM – For instructions on setting the IP address for the server SP using Oracle ILOM, refer to the Oracle Integrated Lights Out Manager (ILOM) 3.2 Documentation Library at http://www.oracle.com./goto/ilom/docs.
  1. Access the BIOS Setup Utility menus.
    See Access BIOS Setup Utility Menus.
  2. In the BIOS Setup Utility menus, navigate to the Advanced Menu.
    The Advanced Menu screen appears.
    image:This figure shows the Advanced Menu.
  3. In the Advanced Menu, select BMC Network Configuration, and then press Enter.
    The BMC Network Configuration screen appears.
    The BMC is the Baseboard Management Controller.
    image:This figure shows the BMC Network screen.
  4. Select Refresh, and then press Enter to display the current BMC network settings.
    The BMC Network Configuration screen refreshes. Scroll down to review BMC network settings.
    image:This figure shows the BMC Network Configuration screen.
  5. Select Commit to update the BMC network settings with the latest values.
  6. Press the F10 key to save the changes and exit the BIOS Setup Utility.
Related Information
