The real-time clock (RTC) battery maintains system time when the storage server is powered off and a time storage server is unavailable. If the storage server fails to maintain the proper time when the system is powered off and not connected to a network, replace the battery.
Caution - Ensure that all power is removed from the storage server before removing or installing the battery. You must disconnect the power cables from the system before performing this procedure. |
This section covers the following procedures:
