Siebel Assignment Manager Administration Guide > Assignment Rule Administration > Associating Skills with Employees, Positions, and OrganizationsYou use skills to find the best matching candidates to assign to assignment objects. Skills can be associated with individual employees, positions, or organizations. During the assignment process, Assignment Manager identifies candidates that have the relevant skills for assignment to a particular item. For example, a service request requiring an agent who has expertise for a particular product is routed to someone who has that product expertise as a part of their skill set. This task is a step in Process of Defining Assignment Rules. You enable and configure skills at the criteria level by using Siebel Tools. For more information on defining criteria for skills, see Process of Defining Criteria Values as Skills with Expertise Codes and Weighting Factors. NOTE: Assignment Manager caches employee, position, and organization skills when the Siebel Server is started. Every time rules are released, employee, position, and organization skills are updated and cached. If you want to automatically refresh employee, position, and organization skills at a periodic interval, set the value of Refresh people skills interval (the MaxSkillsAge AsgnSrvr component parameter) to the desired interval of update. To associate skills with an employee
NOTE: Employees can also track and update their own skill profiles in the User Preferences Profile view (Navigate > User Preferences > User Profile > Assignment Skills). To associate skills with a position
To associate skills with an organization
| Siebel Assignment Manager Administration Guide |
