Average Travel Speed Per Hour |
The average travel speed for field service engineers in the service region, used when the Optimizer calculates costs. See Defining Cost Functions for the Optimizer for more information. |
Average Travel Time (Minutes) |
The amount of travel time that the ABS adds to an activity when calculating the duration of an activity (work time + average travel time). |
Constraint Set |
The constraint set that the ABS and Optimizer use in optimizing the schedule for the selected service region, defined in the Administration - Scheduling screen > Constraint Sets view and the Administration - Scheduling screen > Constraints view. |
Cost Function |
The cost function that the Optimizer uses in optimizing the schedule for the selected service region. See Defining Cost Functions for the Optimizer for more information. |
Cost List |
A cost list for labor, used for calculating overtime costs. Costs Lists are defined in the Administration - Pricing screen > Cost List view. See the Pricing Administration Guide for more information. |
Minimum Travel Time |
If the calculated travel time between two activities is less than this time, the Optimizer uses this time. |
Parent Region |
Select an existing service region as the parent region for the current record. See Specifying Parent Service Regions for more information. |
Parameter Set |
The set of parameters that the ABS and Optimizer use. See Creating Parameter Sets for Scheduling for more information. |
Schedule |
The name of a schedule that the ABS uses. See Defining Schedule Hours for more information. |
Time Window |
The name of a set of time windows that the ABS uses. See Creating Time Windows for Scheduling. |
Time Zone |
The name of a time zone used by the ABS and Optimizer. Time zones are defined in the Administration - Data screen > Time Zone Administration view. See the Applications Administration Guide for more information. |
Travel Cost |
The cost of travel per unit of travel. The Optimizer uses this value when calculating the Cost Function for a schedule. |
Travel Unit of Measure |
The unit of travel (miles or KM) that the Optimizer uses when calculating the Cost Function for a schedule. |
