Siebel Hospitality Guide > Booking Hospitality Assets >
Viewing Assets Associated with a Product
You can view the assets associated with a specific hospitality product using the Function Line Items Assets view. This task is a step in Process of Booking Hospitality Assets. To view assets associated with a product
- Navigate to the Functions screen and query for the function.
- In the Functions list, select the function and click the link in the Function Name field.
- In the Line Items list, select the line item, and then click the Assets view tab to view the assets for a product at a particular property.
The following table describes some of the fields in the asset record.
Asset # |
The asset identifier |
Product |
The product with which the asset is associated |
Status |
The asset inventory status |
Installed |
The date the asset was installed |
Serial # |
The asset serial number |
