Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Charge Code Administration >
Reviewing Charge Codes Associated with a Category
After setting up all the charge codes, perform the following steps to view the charge code associations to each category using the Category Administration view. This task is performed as part of Charge Code Administration, which is a step in Process of Setting Up Charge Codes, Taxes, and Service Charges. To review charge codes associated with a category
- From the application-level menu, choose Navigate > Site Map > Category Administration.
- In the Categories list, query for the category and then click the Charge Codes tab.
The Charge Codes list displays all the charge codes associated with the category record.
