Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Charge Code AdministrationCharge codes are collections of tax codes and service charges. A charge code is an identifier that links taxes and service charges to products and can be used to distinguish between group and local business. For each charge code, there is an associated business type. The business type is selected at the event/quote level. The predefined business types are:
NOTE: Additional business types can be added. Charge codes are associated with subcategories, rather than categories, and can be used for calculation and analysis purposes. When defining charge codes, the category field is automatically populated when the subcategory field is specified. Additional charge codes can be defined by extending the List of Values (LOV). For more information about working with the LOV, see Applications Administration Guide. Charge Code administration requires four procedures:
Related Topics |
| Siebel Hospitality Guide |
