Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Charge Code Administration >
Defining Charge Codes
Perform the steps in the following procedure to define charge codes. This task is performed as part of Charge Code Administration, which is a step in Process of Setting Up Charge Codes, Taxes, and Service Charges. To define a charge code
- From the application-level menu, choose View > Site Map > Tax Service Admin > Charge Codes.
- In the Charge Codes list add a record, and then complete the required fields.
- In the More Info form, complete additional fields, and then save the record.
The following table describes some of the fields.
Category |
A group of related products. This field is automatically populated when you enter the subcategory. |
Business Type |
The type of business of the customer organization. Choices are group and local. |
End Date |
The date the charge code becomes inactive. |
General Ledger Number |
An identifier that maps the charge code to the general ledger. |
Sub Category |
A subcategory allows you to group products more precisely within a larger category and assign different taxes to each subcategory. For example, Appetizers can be a subcategory of the category Food. |
Start Date |
The date the charge code becomes active. |
Repeat Step 2 and Step 3 for each charge code.
