Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Charge Code Administration > Associating Charge Codes with Service ChargesPerform the steps in the following procedure to associate a charge code with a service charge. This task is performed as part of Charge Code Administration, which is a step in Process of Setting Up Charge Codes, Taxes, and Service Charges. To associate a charge code with a service charge
Repeat Step 3 and Step 3 for each tax you want to associate with the charge code. |
| Siebel Hospitality Guide |
