Siebel Hospitality Guide > Setting Up Products and Assets > Simple and Complex Products in HospitalityIn Siebel Hospitality, a simple product is a single component product, such as table, chair, beverage, and so on. A complex product is a group of simple products, such as menu, package, and so on. For example, a beverage is a simple product that can be part of a complex product such as a menu. Another example of a complex product is a projector that includes simple products such as an extension cord, a lens cap, and so on. For more information about products, see Product Administration Guide. The administrator uses the Product Administration screen to create simple and complex products for Siebel Hospitality. Within the product record, the Effective Start Date and Effective End Date values determine the product's availability. A product is considered discontinued if the Effective End Date has passed. If you need to reference a complex product that has different child products associated with it, you can either:
When defining simple and complex products, perform the procedures in the following order: This task is a step in Process of Setting Up Products and Assets. |
| Siebel Hospitality Guide |
