Siebel Hospitality Guide > Setting Up Properties >
Defining Property Day Parts
After the property record is defined, an administrator sets up the property's day parts, segmenting the operational day into periods of time. This task is a step in Process of Setting Up Properties. To set up day parts
- From the application-level menu, choose Navigate > Site Map > Property Administration.
- In the Properties list, query for the property, and then click the Day Parts view tab.
- In the Day Parts list, create new records, complete the fields for each record, and save the records.
The table that follows describes some of the fields.
Day Part Name |
The name of the day part. For example, Morning. |
Start Time |
The start time of the day part. For example, 6 A.M. |
End Time |
The time that the day part ends. For example, 12 P.M. |
Effective Start Date |
The date on which the day part becomes effective. For example, 1/1/2004. |
Effective End Date |
The date on which the day part becomes inactive. For example, 12/31/2004. |
