Siebel Hospitality Guide > Setting Up Properties >
Updating the Property Team
After a property is defined, individual employees are assigned to a team that is associated with the property. This task is a step in Process of Setting Up Properties. To assign an employee to a property team
- From the application-level menu, choose Navigate > Site Map > Property Administration.
- In the Properties list, query for the property record, and then click the More Info view tab.
- In the More Info view, click the show more button and scroll to the Detailed Specifications section of the form.
- In the Property Team field, click the select button.
- In the Property Team Members dialog box, query for and select the team member.
- In the Selected list, select the Primary check box in the primary team member record, and then click OK.
To remove an employee from a property team
- In the Properties list, query for the property record.
- In the Property Team Members dialog box, select the team member in the Selected list.
- Click Remove, and then click OK.
Repeat this step for each member you want to remove.
