The Sourcing Portal (P43Q01) is an application created in form design aid (FDA) using the portlet form type. The Sourcing Portal enables you to provide online access to the JD Edwards EnterpriseOne Operational Sourcing system for buyers and bidders. The page for buyers displays both the Event Workbench program (P43Q70) and the Bidder Workbench program (P43Q40). The page for bidders displays the Bidder Workbench and the RFx Bidder Registration (P43Q91) programs.
You can also use the Supplier Relationship Management (SRM) portlet with JD Edwards EnterpriseOne Operational Sourcing. The SRM portlet contains alerts for JD Edwards EnterpriseOne Operational Sourcing that you can configure to display events at each status. For example, you can set up an alert for the buyer that displays all events that are at a status of Accepted. When a buyer clicks on an alert link, the system accesses either the Event Workbench program or the Bidder Workbench program, depending on the type of alert. When a bidder clicks on an alert link, the system accesses the Bidder Workbench program.
Below information provides an overview of the general steps involved in installing and configuring the Collaborative Portal and the JD Edwards EnterpriseOne portlets. You should perform the below steps in the order listed:
Verify that you meet the minimum technical requirements (MTRs) to implement the JD Edwards EnterpriseOne Collaborative Portal.
Install and configure the JD Edwards EnterpriseOne system.
Apply the updates, service packs, or Electronic Software Updates (ESUs) specified in the MTRs.
See your JD Edwards EnterpriseOne installation documentation.
Install and configure the IBM WebSphere Portal.
Use one of these guides:
WebSphere Portal 6.0.1.1 – Multiplatforms Installation and Configuration for iSeries
WebSphere Portal 6.0.1.1 – Multiplatforms Installation and Configuration for Unix
WebSphere Portal 6.0.1.1 – Multiplatforms Installation and Configuration for Windows
Install and configure the JD Edwards EnterpriseOne Collaborative Portal.
JD Edwards EnterpriseOne Collaborative Portal Reference Guide
Install the SRMportlets.war file in the Collaborative Portal.
WebSphere Portal for Multiplatforms:
See JD Edwards EnterpriseOne Collaborative Portal Reference Guide.
Create pages and add portlets to pages in the Collaborative Portal.
