This chapter contains the following topics:
If you work with VAT in the United Kingdom, you should understand these terms and principles:
If tax is payable, businesses must submit quarterly VAT returns to HM Customs and Excise.
You must pay any excess output VAT over input VAT at the time of filing.
Certain types of supplies are exempt from VAT.
Businesses can obtain a list of these types of supplies from the local tax office.
This table lists the country-specific setup and functionality for the United Kingdom:
| Setup or Process | Description |
| Supplier bank account information | Country-specific values are required when you enter supplier bank account information. |
| Next numbers | Set up next numbers for the Text File Processor program (P007101).
When you run the SEMDEC interface for Intrastat reporting, the Text File Processor program assigns the batch number and interchange from line 7 of Next Numbers System 00. The Text File Processor assigns the message number from line 5 of Next Numbers System 74. |
| User-defined codes (UDCs) | In addition to the base software UDCs:
| AAIs | No country-specific AAI setup exists for the United Kingdom.
You set up standard AAIs to work with SPC. |
| Payment processing | To work with payment processing in the United Kingdom:
| Invoice processing | In addition to standard invoice processing, you can print invoices with an attached International Payment Instructions (IPI). To print these invoices and attachments:
| Automatic debit formats | Before working with automatic debits for the United Kingdom, set the processing options for the Bank File and Statement Diskette (R03B575GB) format for automatic debits.
See Setting Up Automatic Debit Formats for the United Kingdom. |
| Construction Industry Scheme (CIS) | To complete withholding tax processing administered through CIS, you must:
| Real Estate | The Enhanced Real Estate system provides extra functionality to meet the requirements of the real estate market in the United Kingdom. |
| Subcontractor Payment Control (SPC) | To enter and process SPC applications and certificates:
| Intrastat and other European Union reporting | See "Working with Intrastat Reporting" in the JD Edwards EnterpriseOne Applications Localizations for European Reporting and SEPA Processing Implementation Guide . |
| Oracle Business Accelerator | The JD Edwards EnterpriseOne Oracle Business Accelerator solution is available for the United Kingdom, as well as other countries. The preconfigured data that are part of the Oracle Business Accelerator solution is based on business processes that have been designed according to the best business practices for a specific country and industry. |
