This chapter discusses these topics:
Section 44.1, "Product Price and Availability Mobile Applications Overview"
Section 44.2, "Setting Up the Product Price and Availability Mobile Applications"
Section 44.3, "Using the Product Price and Availability Mobile Tablet Application (M41062)"
Section 44.4, "Using the Product Price and Availability Mobile Smartphone Application (M41063)"
Important Note: Before using the mobile applications, Oracle strongly recommends that users have a complete understanding of how to use the associated processes and applications in the JD Edwards EnterpriseOne base software.For additional information about the processes and applications associated with the mobile applications discussed in this chapter, see: |
You use the Product Price and Availability mobile applications to search for and review customer-specific price, item price, item detail and availability, and lot detail information.
You can use filters to search for item detail and availability based on item number and stocking type. You can also use filters to search for item price based on customer and branch/plant.
This table lists the applications that are available to review item price and availability information:
| Type of Application | Additional Information |
| Base EnterpriseOne application | To review item and price information, use these applications in the JD Edwards EnterpriseOne system:
| Tablet application | Product Price and Availability (M41062)
To download the application to your tablet, search on the following text in the application store:
| Smartphone application | Product Price and Availability (M41063)
To download the application to your device, search on the following text in the application store:
Before using the Product Price and Availability tablet or smartphone application, set the processing options for the Product Price and Availability mobile tablet application (M41062) and the Product Price and Availability smartphone application (M41063). You set the processing options to specify the versions that the mobile application uses to process data related to item price, item detail and availability, and item lot details.
Mobile applications are intended to be a simplified version of the applications that are available in the base software. In most cases, these applications provide a subset of the functionality available in the base software.
Barcode Scanning (Release 9.1 Update)
This application is designed to scan data from a barcode and populate the item number in the Item Number field. To scan barcode data, you can use the native camera on your device or a third-party handheld bluetooth-enabled scanning device. To use this functionality, you must create barcodes that represent a single field in the JD Edwards EnterpriseOne system. This application does not accept barcodes that consist of data for multiple fields.
You can generate barcodes using services such as those offered by Barcodes Inc.
Note: Oracle is not affiliated with Barcodes, Inc. and does not require or recommend that you use this service to create your barcodes. |
To use the camera device to scan barcodes, you must disable the Bluetooth option on your mobile device settings.
To use a third-party scanning device, you must enable the Bluetooth option on your mobile device settings. You must configure the third-party scanning device to connect to your mobile device. The third-party vendor provides instructions to configure the connection to your device.
Language Support
You should be aware of how a user's language preference can affect the search functionality for business unit and branch/plant records. See Section 1.2.2.1, "Language Support for Business Unit and Branch Plant Searches"
Before using the Product Price and Availability mobile applications (M41062 and M41063), you must verify the processing options setup for each application. The processing options for both the tablet and the smartphone applications specify the versions of the base JD Edwards EnterpriseOne applications that the mobile applications use.
The system administrator must set the processing options for these mobile applications before the applications are made available to end users.
You use processing options to specify default processing information for a program.
Use this processing option to specify which version of the Item Master program (P4101) the system uses to process item master information. The Product Price and Availability tablet application processes item master information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Item Branch program (P41026) the system uses to process item branch information. The Product Price and Availability tablet application processes item branch information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Item Availability program (P41202) the system uses to process item detail and availability information. The Product Price and Availability tablet application processes item detail and availability information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Lot Master program (P4108) the system uses to process lot detail information. The Product Price and Availability tablet application processes lot detail information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Price History program (P4074) the system uses to review price adjustment information. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Item Master program (P4101) the system uses to process item master information. The Product Price and Availability smartphone application processes item master information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Item Branch program (P41026) the system uses to process item branch information. The Product Price and Availability smartphone application processes item branch information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Item Availability program (P41202) the system uses to process item detail and availability information. The Product Price and Availability smartphone application processes item detail and availability information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
Use this processing option to specify which version of the Lot Master program (P4108) the system uses to process lot detail information. The Product Price and Availability smartphone application processes lot detail information based on the processing options of the version that you specify. If you leave this option blank, the system uses version ZJDE0001.
The Product Price and Availability tablet application enables you to search for and review price information, item detail and availability information, and lot detail information.
Before you can use the application, you must download and install the application from the application store on your device.
To open the application, tap the Price and Avail icon and log in.
To review product price and item detail availability information on your tablet:
Open the application by tapping the Price and Avail icon on your device, and then log in.
See Section 3.2, "Logging Into Mobile Enterprise Applications"
To refine the list of items that appear on your screen, tap the Filter button to access the Filters pane. You can use these fields to filter item price and availability:
Item Number (Release 9.1 Update)
To enter data in the Item Number field you have three options. You can:
Use the keyboard on your mobile device to manually enter the data.
Use the camera application on your mobile device to scan the data. To use this option, you must:
a. Disable the Bluetooth option in your device settings.
b. Access the device camera by tapping the QR Code button next to the Item Number field.
c. Use the camera to scan the barcode of the item.
Use a Bluetooth-enabled scanning device to scan the data. To use this option, you must:
a. Enable the Bluetooth option in your device settings.
b. Configure the third-party scanning device to connect to your mobile device.
c. Tap the Item Number field to activate the scanning device.
d. Scan the barcode of the item.
Stocking Type
In the Filters pane to continue the search using the specified filters, tap the Apply button. When you tap the Apply button, the system:
Takes you to the list of branch plants that stock the item based on your filter values. The default view is the information on the Availability tab.
You can tap the Filter button in the right pane to refine your search to a specific branch plant.
Saves the filter values that you entered. The system displays the saved filter values the next time you open the filter screen.
To discontinue the use of filter values in your search, tap the Cancel button. When you tap the Cancel button, the system:
Takes you to the list of branch plants that stock the item with the last saved filter values, if applicable.
Ignores the filter values that you entered, and restores the last saved filter values to the filter fields.
To delete all the filter values that you specified, and to enter new filter values, tap the Clear button.
On the Availability tab, review the item availability information, which includes:
Branch plant.
Quantity available.
Whether you can back order the item.
To review the lot details information, tap Lot Details at the lower right of the right pane.
The system displays the Lot Availability Details screen. The left pane displays a list of the available quantity for the item in each branch plant. The right pane displays the item information for the first record listed in the left pane.
To filter items by branch plant, tap the filter button at the top of the left pane. Enter the branch plant and tap the Apply button.
To refine the lot availability information that appears on your screen, tap the Filter button at the top of the right pane.
You can use these fields to filter the lot availability information:
Country of Origin
Lot/Serial Status Code
Lot Expiration Date
Tap the Items button to return to the Price and Availability screen.
To review price information, tap the List Price tab.
The system displays the item in each respective branch, along with the following information:
Unit of measure
Unit price
Effective date from
Effective date thru
Location
Lot number
Figure 44-3 Price and Availability - List Price Screen: Tablet
To refine the price information that appears on your screen, tap the Filter button at the top of the right pane.
You can use these fields to filter the price information:
Branch Plant
Currency Code
Price Effective Date
To review customer price information, tap the Customer Price tab.
Figure 44-4 Price and Availability - Customer Price Screen: Tablet
You can use these fields to filter the customer price information:
Customer
Branch Plant
Tap the Get Price button.
The system displays the unit price, the customer price, effective price date and any applicable adjustment schedules and discounts.
Additionally, you can attach a price adjustment schedule to further define your search. To do so, tap the filter button next to the Get Price button, and use these fields to define your criteria:
Adjustment Schedule
Quantity From
Pricing UOM
To log out of the application, tap the Menu button at the bottom left of the screen, and then tap Logout.
The Product Price and Availability smartphone application enables you to search for and review price information, item detail and availability information, and lot detail information.
To review product price and item detail availability information on your smartphone:
To refine the list of items that appear on your screen, tap the Filter button to access the Filters screen. You can use these fields to filter item product price and item detail availability:
Stocking Type
On the Filters screen to continue the search using the specified filters, tap the Apply button. When you tap the Apply button, the system:
Displays the item that you specified in the Filter screen. Tap the Next Field button to display a list of branch plants that stock the item based on your filter values. The default view is the information on the Availability tab.
You can tap the Filter button to refine your search to a specific branch plant.
Branch plant.
Quantity available.
Figure 44-5 Price Information - Availability Screen: Smartphone
To filter items by branch plant, tap the Filter button. On the Filters screen, enter the branch plant and tap the Apply button.
To review lot availability details information, tap the item from a list of the items that appear on the Availability tab.
The system displays the Lot Details screen.
Figure 44-6 Lot Details Screen: Smartphone
To refine the lot availability information that appears on your screen, tap the Filter button. You can used these fields to filter the lot availability information:
Country of Origin
Lot Expiration Date
Tap the Item Info button to return to the Price Information screen.
To review price information, tap the List tab.
Unit of measure
Unit price
Effective date from
Effective date thru
Location
Lot number
To refine the price information that appears on your screen, tap the Filter button. You can use these fields to filter the price information:
Branch Plant
Currency Code
To review customer price information, tap the Customer tab.
Figure 44-8 Price Information - Customer Screen: Smartphone
To view and use additional filter fields for customer price information, tap the Selection Criteria option at the top of the screen. You can then complete these options:
Customer (Required)
Branch Plant (Required)
The system displays the unit price, the customer price, effective price date and any applicable adjustment schedules and discounts. Also note that the Foreign button appears only if the version the P03013 that is used by the mobile application is set up to display this option.
Additionally, you can attach a price adjustment schedule to further define your search. To do so, tap the filter button at the top right of the screen, and use these fields to define your criteria:
Adjustment Schedule
Quantity From
Pricing UOM
