| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal Installation Guide For HBA Models SGX-SAS6-R-INT-Z and SG-SAS6-R-INT-Z |
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
To Connect the HBA to Internal Storage Devices
Chapter 3 Creating a Bootable Drive in a Preboot Environment
See the Safety and Compliance documentation for this HBA.
For optimal performance, use like drives (type, speed, and size) when you create virtual drives. You can use different-sized disk drives in the array, but the array will be limited to the capacity of the smallest and slowest disk drive.
For more information, refer to the MegaRAID SAS Software User's Guide at: http://www.lsi.com/sep/Pages/oracle/index.aspx
The HBA supports both SAS and SATA II disk drives.
You will need at least one, straight SAS cable that has a SFF-8087 x4 connector on the host end that will connect to the HBA (the connector on the target end depends on the connection requirement of the hard disk drive enclosure). The SAS cable must meet the SAS specification and must be no longer than 10 meters in length (393.70 inches).
Use only Oracle-provided SAS cables. For more information or to purchase cables for your Oracle system, visit http://www.oracle.com. Cable connectors are keyed so that you cannot insert them incorrectly.
