Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PIMv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
SEFOS PIMv6 Overview
Supported Features
Protocol Description
Default Settings
Topology Example
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure PIMv6 in Router A
Configure PIMv6 in Router B
Global Configurations
Enable PIMv6
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configure the PMBR Status
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the LAN Delay
Configure the LAN Prune Delay
Configure the BSR Candidate
Configure the Message Interval
Configuring the PIMv6 Component
Create a PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Hold Time
Configure the RP-Candidate Address
Configure the RP Static Address
Create an RP-Set Table
Create a PIMv6 Neighbor
Create Multicast Routes
The PIMv6 component corresponds to each instance of a PIMv6 domain. The component is classified as being in the sparse mode. Dense mode is not supported in the 1.2 release.
  1. Enable PIMv6.
    SEFOS# configure terminal
    SEFOS(config-if)# set ipv6 pim enable
  2. Enter into PIMv6 component mode for configuring a component.
    SEFOS(config)# ip pim component component_ID
    SEFOS(pim-comp)# end
  3. Review the configuration information for the component (2 in this example).
    SEFOS# show ipv6 pim component 2
    PIM Component Information
    Component-Id: 2
      PIM Mode: sparse,   PIM Version: 2
      Elected BSR: ::
      Candidate RP Holdtime: 0
