| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System PIMv6 Administration Guide |
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the Message Interval
Configuring the PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Hold Time
An RP-candidate router is a router that is configured to send periodic RP-candidate advertisement messages to the BSR. This router also processes join or prune messages or registers messages for the advertised group prefix when it is elected as an RP. When you configure the RP-candidate address, you set the address of the interface that is advertised as an RP-candidate.
SEFOS(config)# interface vlan 7 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# exit
SEFOS(config)# ip pim component 1
SEFOS(pim-comp)# rp-candidate holdtime 30
SEFOS(pim-comp)# ipv6 pim rp-candidate rp-address ff02::e001:0 128 7777::11 SEFOS(pim-comp)# end
SEFOS# show ipv6 pim rp-candidate
CompId GroupAddress/PrefixLength RPAddress/Priority
1 ff02::e001:1/128 7777::11/4SEFOS# show ipv6 pim rp-candidate 1
