| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM RAID HBA Installation Guide For HBA Models SGX-SAS6-R-REM-Z and SG-SAS6-R-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
MegaRAID Storage Manager-Related Issues
BackingStoreException Error Messages Occur When Trying to Start the GUI
Debug Messages Are Displayed in the Terminal Window
Error Messages Are Displayed When Attempting to Connect to Another Host
Cannot Enter the Login Password for the GUI and CLI
Administrative Actions Are Inaccessible Through the MSM GUI
Cannot Create a Drive Group Through the MSM GUI
sas_snmp and sas_ir_snmp Errors Occur During the MSM GUI Installation
Connection Refusal Error Messages Occur When Trying to Start the MSM GUI
Monitoring System Is Displayed as a MegaRAID Server in the MSM GUI
MSM GUI Is Not Starting After Becoming the root User
Application Event Notifications Are Not Displaying in the MSM GUI
Cannot Locate a Disk Because the Blue Ready-to-Remove LED Is Not Illuminated
Cannot Clear Controller Events From the UEFI HII Menu
MegaCLI Log Files Are in the /tmp Directory
Unsupported RAID Levels Are Displayed in the MegaCLI Utility
Error Message Occurs After Issuing the MegaCli64 -AdpAlILog -aALL Command
The Advanced Software Options Feature on the WebBIOS Utility Menu Is Not Supported
Mouse Clicks Are Not Detected by the WebBIOS Utility
Cannot Tell, Through the WebBIOS Utility, When the Copyback Process Is Completed
“Invalid SAS Topology Detected” Error Occurs, Preventing the System From Booting
Cannot Boot the Operating System
NEM Removal Causes Virtual Disk Members to Be Displayed as (FOREIGN) Unconfigured Bad
CR 6904623
Issue: From the WebBIOS utility, when you execute a Prepare Removal command on a drive in a system that has more than eight physical drives, if the drive is pulled out and then re-inserted in a different slot, the blue Ready-to-Remove LED might illuminate in that new/different slot.
Workaround: To extinguish the blue LED, undo the Prepare Removal command by doing one of the following:
From the WebBIOS utility, select Undo Removal > OK for the slot in which the drive is now located.
From the MSM GUI, right-click on the drive and select the Undo Prepare for Removal menu option.
From the MegaCLI utility, type the following:
MegaCli -PdPrpRmv -UnDo -physdrv[enclosure-number:slot-number] -anumber-of-adapter-that-is-controlling-the-drive
