Start Admintool, if it's not already running. Select Users from the Browse menu.
See "How to Start Admintool" for more information.
Select the user account entry that needs the password changed.
Choose Modify from the Edit menu.
The Modify User window is displayed containing the selected user account entry.
Choose Normal Password from the Password menu.
Click on OK.
This is the pop-up window used to change user's passwords that is available from the Add User or Modify User windows.
