The corners of windows are the handles you use for resizing. To resize a window:
Position the pointer on one of the window corners.
The pointer turns into a tiny bull's eye. This means that the pointer is in the correct location for resizing.
Press SELECT and drag the pointer to the desired size.
An outline shows the size of the window.
Release SELECT.
Figure 1-23 shows the pointer positioned on a window's handle for resizing.
