You can load, store or remove option files. Storing an Option file saves the current test settings to a file in the /var/opt/SUNWvts/options directory.
Click the Option Files button to display the Option Files pop-up window (Figure 4-31).
Type the file name or select a file from the pull-down menu.
Load, store or remove the specified option file.
