In addition to the normal SunVTS requirements (refer to "Requirements"), the following requirements must be met to run SunVTS on a remote system:
There must be network connectivity between the local and remote system.
The same revision of the SunVTS must be installed on both the local and remote system.
| # /opt/SUNWvts/bin/sunvts -h remote_hostname |
Replace remote_hostname with the hostname or IP address of the remote system.
The sunvts command starts the SunVTS kernel (vtsk) on the remote system, and starts the SunVTS user interface on the local system. The user interface connects to the kernel and the displays the test session of the remote system. Refer to Figure 3-1 below.
The term system under test (SUT) refers to the system running the SunVTS kernel, which is the remote system in this example.
If the user interface is already running on your local system, you can use the "Connect to" button to connect to a remote machine's SunVTS kernel. See "To Use the Connect to Button".
Configure SunVTS for the test session and start the tests as described in the following sections:
Review the SunVTS logs for test results.
You can view the remote system test logs through the local SunVTS interface. The log files are stored on the system under test (SUT).
Use the xhost command to allow the remote system to display on your local system.
| % /usr/openwin/bin/xhost + remote_hostname |
Replace remote_hostname with the name of the remote system.
Log in to the remote system as superuser.
Using a command such as rlogin.
| # /opt/SUNWvts/bin/sunvts -display local_hostname:0 |
Replace local_hostname with the name of the local system.
The SunVTS kernel starts on the remote system and the user interface displays on your system.
Configure SunVTS for the test session and start the tests.
You can run SunVTS on a remote system, with the TTY interface, through a telnet or tip session.
You need to set the correct terminal type and number of columns and rows before starting the interface. The steps below describe this process.
Use the echo command to display the value of the TERM variable:
This example, the TERM variable is a Korn or Bourne shell variable and the value is sun-cmd. Your display device may be something else like a Wyse, TeleVideo, or other kind of terminal. In this case your TERM value will be something different.
$ echo $TERM sun-cmd
Use the stty command to display the settings of your terminal:
$ stty speed 9600 baud; -parity hupcl rows = 60; columns = 80; ypixels = 780; xpixels = 568; swtch = <undef>; brkint -inpck -istrip icrnl -ixany imaxbel onlcr echo echoe echok echoctl echoke iexten
You must have a minimum of 80 columns and 24 rows to run the SunVTS TTY interface.
Write down the values of your TERM variable and rows and columns settings.
You will need these values later.
Connect to the remote system using either the telnet or tip commands.
Refer to the telnet(1) and tip(1) man pages for more information about these commands.
Become superuser on the remote system.
Identify your terminal type and settings in the telnet (or tip) session window:
# TERM=sun-cmd # stty rows 60 # stty columns 80
Start SunVTS with the TTY interface:
# /opt/SUNWvts/bin/sunvts -t
Refer to "Running SunVTS With the TTY Interface (Tutorial)" and "TTY Interface" for information on testing with the TTY interface.
You can view the remote system test logs through the local SunVTS TTY interface. The log files are stored on the system under test (SUT).
