The Physical Presence
Check mode in Oracle ILOM is enabled by default.
Firmware version 3.1 or later is required to use
the Physical Presence Check mode in Oracle ILOM.
In
the Oracle ILOM web interface, click ILOM Administration -> Identification
In the Identification page, navigate
to the Physical Presence Check property, and then perform one of
the following:
Select the
Physical Presence check box to enable. When enabled, the Locator button
on the physical system must be pressed in order to recover the default Oracle
ILOM password.
-or-
Clear the Physical Presence check
box to disable. When disabled, the default Oracle ILOM administrator
root password can be reset without pressing the Locator button on
the physical system.
