Before You Begin
Oracle ILOM supports the creation and storage of up to 10 local user accounts on a single SP or chassis monitoring module (CMM). Oracle ILOM users are assigned a set of privileges that enables them to work with features to the extent they are permissible by their configured account.
For web-based instructions for configuring a local user account with role-based access privileges, see the following instructions.
Before You Begin
Review the Security Guidelines for Managing User Accounts and Passwords.
Review the Figure 7, Table 7, User Account Privilege Descriptions Supported Web Browsers for Oracle ILOM.
The User Management (u) role in Oracle ILOM is required to create a local user account with privileges.
For instance, in the:
The Add User dialog appears.
Create User Account and Assign User Role, Oracle ILOM Administrator's Guide for Configuration and Maintenance (Firmware 3.2.x)
Create User Account and Assign User Role, Oracle ILOM 3.1 Configuration and Maintenance Guide
Add User Account and Assign Roles, Oracle ILOM 3.0 Daily Management - CLI Procedures Guide
Add User Account and Assign Roles, Oracle ILOM 3.0 Daily Management - Web Procedures Guide
