Establish a secure dedicated management connection to Oracle ILOM.
All firmware versions
Decide whether FIPS 140-2 security compliance is required at or after deployment; or, not at
all.
Firmware versions 3.2.4 and later
Set Password Policy for All Local User Accounts
Firmware version 3.2.5 and later
Modify the default password provided for the preconfigured Administrator root
account.
Decide whether the preconfigured Oracle ILOM services and their open network ports are
applicable for your target environment.
Configure user access to Oracle ILOM.
Decide whether access to the host operating system should be locked upon exiting a remote KVMS
session.
Firmware versions 3.0.4 and later
Decide whether to limit other SP users from viewing remote KVMS sessions launched from the
SP.
Decide whether to display a security banner message at user login or immediately following
user login.
Firmware versions 3.0.8 and later
Ensure that the proper security properties are set for all Oracle ILOM user interfaces.
For ASR Client configurations, choose to keep the preinstalled SSL
Certificate or upload a user-specified SSL Certificate.
Firmware versions 4.0.x and later.
Ensure that the servicetagprotocol is properly configured to
use HTTPS and a passphrase.
