As of firmware release 3.0.8 , Oracle ILOM enables system administrators to display a banner message to all users upon logging in to the Oracle ILOM CLI and web interface. The use of a login banner can help protect against unauthorized system access by remote devices, as well as advise authorized and legitimate users of their obligations relating to acceptable use of the system.
The banner message you implement should be written in accordance with your information security policy. For further guidelines about the written message, consult your site administrator or security officer.
To display a banner message to all users at login or post login, see the following web-based instructions.
Before You Begin
The Admin (a) role is required to create a banner message.
The banner message is available for configuration as of Oracle ILOM firmware release 3.0.8 and later.
Administrators can configure the banner message to display on the Login page, or in a dialog that appears immediately after the user logs in to Oracle ILOM.
For instance, in the:
For CLI instructions, refer to the applicable Oracle ILOM Administration Guide that is listed in the Related Information section of this procedure.
Management of Banner Messages, Oracle ILOM Administrator's Guide for Configuration and Maintenance (Firmware 3.2.x)
Banner Message Configuration Properties, Oracle ILOM 3.1 Configuration and Maintenance Guide
Display Banner Message, Oracle ILOM 3.0 Daily Management - CLI Procedures Guide
Display Banner Message, Oracle ILOM 3.0 Daily Management - Web Procedures Guide
