Go to main content
Sun Network 10GbE Switch 72p Product Notes
Exit Print View
Updated: November 2016
SSL V3.0 POODLE DISABLE SSL V3 (19842635)
Workaround: Disable SSLv3 from ILOM under /SP/service/https.
-> cd /SP/services/https
/SP/services/https
-> set sslv3=disabled
Set 'sslv3' to 'disabled'
-> show
/SP/services/https
   Targets:
       ssl
   Properties:
       port = 443
       servicestate = enabled
       sslv2 = disabled
       sslv3 = disabled
       tlsv1 = enabled
       weak_ciphers = disabled
   Commands:
       cd
       set
       show
